    Setting up OrangePi 3 LTS
    DSF Development
    1.5k
    • chrishammundefined
      chrishamm administrators @Dakota
      @Dakota If DCS cannot put that line into event mode, that's usually an indicator that the given pin is either not accessible or it is still allocated by SysFS. You may need to unexport it before DSF can use it (see /sys/class/gpio, maybe you can achieve that by sending echo 2 | sudo tee /sys/class/gpio/unexport according to https://f1atb.fr/index.php/2022/01/20/orange-pi-gpio/).
      Duet software engineer
      Dakotaundefined 1 Reply Last reply Reply Quote 0
      • Dakotaundefined
        Dakota @chrishamm
        @chrishamm thank you for the reply!
        so my specific ability to edit and control the gpio pins is different as orangepi uses a fork of "wiringPi" called "wiringOP". From there I am able to unexport using:
        gpio unexport 13 out
        I am also able to change the mode and value using:
        gpio mode 13 in/out/pwn/clock/up/down/tri
        gpio write 13 0/1
        where I get lost now is I have no idea what mode or value to change it to for DSF to be able to use it...
          @Dakota There are two sets of utilities for controlling GPIO pins, one is SysFS (which WiringPi and probably WiringOP use AFAIR) and the other one is gpiod (which DSF uses for performance reasons). The pin numbering is different depending on the subsystem used. You should use the gpioinfo utility from the gpiod utils instead of gpio readall which probably uses the wrong GPIO interface. Please make sure to follow https://github.com/Duet3D/DuetSoftwareFramework/wiki/SBC-Setup-Guide#link-between-the-duet-and-sbc as some extra steps are also required to get DSF to operate nicely on different SBCs.
          • Falcounetundefined
            Falcounet @Dakota
            @Dakota 117 seems ok from the formula used by the sunxi driver : (position of letter in alphabet - 1) * 32 + pin number
            So in your case, the pin 22 is mapped to PD21 (See the image below but that is also wrote in your gpio readall output)
            as D is the 4th letter : (4-1) * 32 + 21 = 117.
            However, I believe the GPIO chip device /dev/gpiochip1 you are using is incorrect.
            gpioinfo which is provided by gpiod package may give you more clue about that.
            • Dakotaundefined
              Dakota
              @Falcounet I tried using both chip0 and chip1 which didn't change the outcome...
              here is my list from running gpioinfo:
              gpiochip0 - 64 lines:
              line 0: unnamed kernel input active-high [used]
              line 1: unnamed kernel input active-high [used]
              line 2: unnamed unused input active-high
              line 3: unnamed unused input active-high
              line 4: unnamed "red-led" output active-high [used]
              line 5: unnamed unused input active-high
              line 6: unnamed unused input active-high
              line 7: unnamed "green-led" output active-high [used]
              line 8: unnamed unused input active-high
              line 9: unnamed kernel input active-high [used]
              line 10: unnamed unused input active-high
              line 11: unnamed unused input active-high
              line 12: unnamed unused input active-high
              line 13: unnamed unused input active-high
              line 14: unnamed unused input active-high
              line 15: unnamed unused input active-high
              line 16: unnamed unused input active-high
              line 17: unnamed unused input active-high
              line 18: unnamed unused input active-high
              line 19: unnamed unused input active-high
              line 20: unnamed unused input active-high
              line 21: unnamed unused input active-high
              line 22: unnamed unused input active-high
              line 23: unnamed unused input active-high
              line 24: unnamed unused input active-high
              line 25: unnamed unused input active-high
              line 26: unnamed unused input active-high
              line 27: unnamed unused input active-high
              line 28: unnamed unused input active-high
              line 29: unnamed unused input active-high
              line 30: unnamed unused input active-high
              line 31: unnamed unused input active-high
              line 32: unnamed unused input active-high
              line 33: unnamed unused input active-high
              line 34: unnamed unused input active-high
              line 35: unnamed "reset" output active-low [used]
              line 36: unnamed unused input active-high
              line 37: unnamed unused input active-high
              line 38: unnamed unused input active-high
              line 39: unnamed unused input active-high
              line 40: unnamed unused input active-high
              line 41: unnamed unused input active-high
              line 42: unnamed unused input active-high
              line 43: unnamed unused input active-high
              line 44: unnamed unused input active-high
              line 45: unnamed unused input active-high
              line 46: unnamed unused input active-high
              line 47: unnamed unused input active-high
              line 48: unnamed unused input active-high
              line 49: unnamed unused input active-high
              line 50: unnamed unused input active-high
              line 51: unnamed unused input active-high
              line 52: unnamed unused input active-high
              line 53: unnamed unused input active-high
              line 54: unnamed unused input active-high
              line 55: unnamed unused input active-high
              line 56: unnamed unused input active-high
              line 57: unnamed unused input active-high
              line 58: unnamed unused input active-high
              line 59: unnamed unused input active-high
              line 60: unnamed unused input active-high
              line 61: unnamed unused input active-high
              line 62: unnamed unused input active-high
              line 63: unnamed unused input active-high
              • Dakotaundefined
                Dakota @Dakota
                gpiochip1 - 256 lines:
                line 0: unnamed unused input active-high
                line 1: unnamed unused input active-high
                line 4: unnamed unused input active-high
                line 7: unnamed unused input active-high
                line 9: unnamed unused input active-high
                line 35: unnamed unused input active-high
                line 52: unnamed "interrupt" input active-high [used]
                line 64: unnamed unused input active-high
                line 65: unnamed unused input active-high
                line 66: unnamed unused input active-high
                line 67: unnamed unused input active-high
                line 68: unnamed unused input active-high
                line 69: unnamed unused input active-high
                line 70: unnamed unused input active-high
                line 71: unnamed unused input active-high
                line 72: unnamed unused input active-high
                line 73: unnamed unused input active-high
                line 74: unnamed unused input active-high
                line 75: unnamed unused input active-high
                line 76: unnamed unused input active-high
                line 77: unnamed unused input active-high
                line 78: unnamed unused input active-high
                line 79: unnamed "usb0_id_det" input active-high [used]
                line 80: unnamed unused input active-high
                line 81: unnamed unused input active-high
                line 82: unnamed unused input active-high
                line 83: unnamed unused input active-high
                line 84: unnamed unused input active-high
                line 85: unnamed unused input active-high
                line 86: unnamed unused input active-high
                line 87: unnamed unused input active-high
                line 88: unnamed unused input active-high
                line 89: unnamed unused input active-high
                line 90: unnamed unused input active-high
                line 91: unnamed unused input active-high
                line 92: unnamed unused input active-high
                line 93: unnamed unused input active-high
                line 94: unnamed unused input active-high
                line 95: unnamed unused input active-high
                line 96: unnamed unused input active-high
                line 97: unnamed unused input active-high
                line 98: unnamed unused input active-high
                line 99: unnamed unused input active-high
                line 100: unnamed unused input active-high
                line 101: unnamed unused input active-high
                line 102: unnamed "gmac-3v3" output active-high [used]
                line 103: unnamed unused input active-high
                line 104: unnamed unused input active-high
                line 105: unnamed unused input active-high
                line 106: unnamed unused input active-high
                line 107: unnamed unused input active-high
                line 108: unnamed unused input active-high
                line 109: unnamed unused input active-high
                line 110: unnamed "PHY reset" output active-low [used]
                line 111: unnamed unused input active-high
                line 112: unnamed unused input active-high
                line 113: unnamed unused input active-high
                line 114: unnamed unused input active-high
                line 115: unnamed unused input active-high
                line 116: unnamed unused input active-high
                line 117: unnamed unused input active-high
                line 118: unnamed unused input active-high
                line 119: unnamed unused input active-high
                line 120: unnamed unused input active-high
                line 121: unnamed unused input active-high
                line 122: unnamed unused input active-high
                line 123: unnamed unused input active-high
                line 124: unnamed unused input active-high
                line 125: unnamed unused input active-high
                line 126: unnamed unused input active-high
                line 127: unnamed unused input active-high
                line 128: unnamed unused input active-high
                line 129: unnamed unused input active-high
                line 130: unnamed unused input active-high
                line 131: unnamed unused input active-high
                line 132: unnamed unused input active-high
                line 133: unnamed unused input active-high
                line 134: unnamed unused input active-high
                line 135: unnamed unused input active-high
                line 136: unnamed unused input active-high
                line 137: unnamed unused input active-high
                line 138: unnamed unused input active-high
                line 139: unnamed unused input active-high
                line 140: unnamed unused input active-high
                line 141: unnamed unused input active-high
                line 142: unnamed unused input active-high
                line 143: unnamed unused input active-high
                line 144: unnamed unused input active-high
                line 145: unnamed unused input active-high
                line 146: unnamed unused input active-high
                line 147: unnamed unused input active-high
                line 148: unnamed unused input active-high
                line 149: unnamed unused input active-high
                line 150: unnamed unused input active-high
                line 151: unnamed unused input active-high
                line 152: unnamed unused input active-high
                line 153: unnamed unused input active-high
                line 154: unnamed unused input active-high
                line 155: unnamed unused input active-high
                line 156: unnamed unused input active-high
                line 157: unnamed unused input active-high
                line 158: unnamed unused input active-high
                line 159: unnamed unused input active-high
                line 160: unnamed unused input active-high
                line 161: unnamed unused input active-high
                line 162: unnamed unused input active-high
                line 163: unnamed unused input active-high
                line 164: unnamed unused input active-high
                line 165: unnamed unused input active-high
                line 166: unnamed "cd" input active-low [used]
                line 167: unnamed unused input active-high
                line 168: unnamed unused input active-high
                line 169: unnamed unused input active-high
                line 170: unnamed unused input active-high
                line 171: unnamed unused input active-high
                line 172: unnamed unused input active-high
                line 173: unnamed unused input active-high
                line 174: unnamed unused input active-high
                line 175: unnamed unused input active-high
                line 176: unnamed unused input active-high
                line 177: unnamed unused input active-high
                line 178: unnamed unused input active-high
                line 179: unnamed unused input active-high
                line 180: unnamed unused input active-high
                line 181: unnamed unused input active-high
                line 182: unnamed unused input active-high
                line 183: unnamed unused input active-high
                line 184: unnamed unused input active-high
                line 185: unnamed unused input active-high
                line 186: unnamed unused input active-high
                line 187: unnamed unused input active-high
                line 188: unnamed unused input active-high
                line 189: unnamed unused input active-high
                line 190: unnamed unused input active-high
                line 191: unnamed unused input active-high
                line 192: unnamed unused input active-high
                line 193: unnamed unused input active-high
                line 194: unnamed unused input active-high
                line 195: unnamed unused input active-high
                line 196: unnamed unused input active-high
                line 197: unnamed unused input active-high
                line 198: unnamed unused input active-high
                line 199: unnamed unused input active-high
                line 200: unnamed unused input active-high
                line 201: unnamed unused input active-high
                line 202: unnamed unused input active-high
                line 203: unnamed unused input active-high
                line 204: unnamed unused input active-high
                line 205: unnamed unused input active-high
                line 206: unnamed unused input active-high
                line 207: unnamed unused input active-high
                line 208: unnamed unused input active-high
                line 209: unnamed unused input active-high
                line 210: unnamed unused input active-high
                line 211: unnamed unused input active-high
                line 212: unnamed unused input active-high
                line 213: unnamed unused input active-high
                line 214: unnamed unused input active-high
                line 215: unnamed unused input active-high
                line 216: unnamed unused input active-high
                line 217: unnamed unused input active-high
                line 218: unnamed unused input active-high
                line 219: unnamed unused input active-high
                line 220: unnamed unused input active-high
                line 221: unnamed unused input active-high
                line 222: unnamed unused input active-high
                line 223: unnamed unused input active-high
                line 224: unnamed unused input active-high
                line 225: unnamed unused input active-high
                line 226: unnamed "ddc-en" output active-high [used]
                line 227: unnamed unused input active-high
                line 228: unnamed unused input active-high
                line 229: unnamed unused input active-high
                line 230: unnamed unused input active-high
                line 231: unnamed "vcc33-wifi" output active-high [used]
                line 232: unnamed unused input active-high
                line 233: unnamed unused input active-high
                line 234: unnamed unused input active-high
                line 235: unnamed unused input active-high
                line 236: unnamed unused input active-high
                line 237: unnamed unused input active-high
                line 238: unnamed unused input active-high
                line 239: unnamed unused input active-high
                line 240: unnamed unused input active-high
                line 241: unnamed unused input active-high
                line 242: unnamed unused input active-high
                line 243: unnamed unused input active-high
                line 244: unnamed unused input active-high
                line 245: unnamed unused input active-high
                line 246: unnamed unused input active-high
                line 247: unnamed unused input active-high
                line 248: unnamed unused input active-high
                line 249: unnamed unused input active-high
                line 250: unnamed unused input active-high
                line 251: unnamed unused input active-high
                line 252: unnamed unused input active-high
                line 253: unnamed unused input active-high
                line 254: unnamed unused input active-high
                line 255: unnamed unused input active-high
                Falcounetundefined 1 Reply Last reply Reply Quote 0
                • Dakotaundefined
                  Dakota @chrishamm
                  @chrishamm I was able to edit through the directories, however now I get an error saying access denied to /unexport. But after rebooting it returned to error code 19 and unable to connect.
                  • Dakotaundefined
                    Dakota @Falcounet
                    @Falcounet well wait now I'm confused... when I look at the directory it lists chip0 and chip352... gpio info still lists chip0 and chip1.
                    Falcounetundefined 1 Reply Last reply Reply Quote 1
                      Falcounet @Dakota
                      @Dakota Look at chrisamm comment above about sysfs / gpiod
                      You can't use sysfs with DSF.
                        Falcounet @Dakota
                        @Dakota What I did a while ago when I was faced the same issue is :
                        1. To feed 3.3V (or whatever voltage is safe for your GPIO pin to set it to TRUE state) on the pin number 22 on the connector
                        2. Run gpioget in a loop to all the pins and store the ones that reports 1
                        3. Connect the pin number 22 to GND
                        4. Run gpioget in a loop to all the pins again and store the ones that reports 0
                        5. Make an intersection on the results from #2 and 3#
                        If you are lucky, you get only one result but if not, it should reduce the number of potential candidates pins.
                        However, be careful because there is some pins driven by the system so they can get a random state when you poll them.
