Power failure and DNS name
Firmware installation
1.0k
    TYPPA Albert Einstein
    Hi David DC42 and all
    Two question
    on beta 1.20 8
    This wiki for power failure is corret for this release ? I use new versions 1.20 FW configurator at 12v ( set on 10 at 11 default is right ? I nedd create the file or is write in FW ?
    https://duet3d.com/wiki/Setting_up_to_resume_a_print_after_a_power_failure
    Second question
    Why on my web interface ( Chrome ) I not work nome dns it work on IP address not on name my Delta : M550 PTyppa
    Server not recognize …
    Duet ethernet FW 1.20 8 / web 1.93 last edge
    Sorry my bad English
    I have no special talent. I am only passionately curious.
    -Albert Einstein
      1. The M911 command has changed in release 1.20. See https://duet3d.com/wiki/G-code#M911:_Configure_auto_save_on_loss_of_power for the new command.
      2. Sorry, neither NetBios nor Mdns is implemented on the Duet Ethernet.
        Thanks David for the quick reply 😉
        sorry David …. but the recovery file is written on the SD without my own to create the cone files in the exact version 1.9 or I have to create the files ... am I confused? For the Delta system at 12V in ATX what values tell me ..... I think only a small movement in Z can do
        -Albert Einstein
          You have to put the movement commands that you want to occur when the power fails in the M911 command. You also have to write the resurrect-prologue.g command, which will be called from the resurrect.g file. The resurrect.g file is created automatically.
          However, you may not be able to get auto save on power fail working with 12V power.
            Hi David DC42
            stupid question : on DWC 1.9.3 for printing file resurrect.g ? No option for printing …..use macro ?
            FW 1.20 Beta 11 / DWC 1.93 / Ethernet
            is problem on DWC/ Christian ?
            Ciao
            -Albert Einstein
              In firmware 1.20 you can just send M116 M916. That will run resurrect.g.
                @dc42:
                In firmware 1.20 you can just send M116. That will run resurrect.g.
                Thanks David…. but M116: Wait ?
                Sorry, I meant M916.
                -Albert Einstein
