    [3.4.5] DSF-Python - timeout failures
    DSF Development
    905
    • oozeBotundefined
      oozeBot
      @chrishamm - hoping to get this in front of you. We are seeing timeouts from DSF once or twice a day. The service does restart correctly (most of the time), but we'd obviously prefer it to never timeout and certainly prefer it to never timeout when it doesn't restart itself correctly.
      Is there anything non-blocking that we can do in our python scripts to keep it from timing out? Or is this an issue within DSF?
      Here is a recent log. Please let us know how we can help identify the issue. Thanks!
      May 17 16:04:14 elevate systemd[1]: Started oozeBot Control Server.
      May 18 08:52:18 elevate OCS.py[5029]: Traceback (most recent call last):
      May 18 08:52:18 elevate OCS.py[5029]:   File "/scripts/OCS.py", line 94, in <module>
      May 18 08:52:18 elevate OCS.py[5029]:     cde = intercept_connection.receive_code()
      May 18 08:52:18 elevate OCS.py[5029]:   File "/usr/local/lib/python3.9/dist-packages/dsf/connections.py", line 458, in receive_code
      May 18 08:52:18 elevate OCS.py[5029]:     return self.receive(code.Code)
      May 18 08:52:18 elevate OCS.py[5029]:   File "/usr/local/lib/python3.9/dist-packages/dsf/connections.py", line 122, in receive
      May 18 08:52:18 elevate OCS.py[5029]:     json_string = self.receive_json()
      May 18 08:52:18 elevate OCS.py[5029]:   File "/usr/local/lib/python3.9/dist-packages/dsf/connections.py", line 162, in receive_json
      May 18 08:52:18 elevate OCS.py[5029]:     raise TimeoutError
      May 18 08:52:18 elevate OCS.py[5029]: TimeoutError
      May 18 08:52:18 elevate systemd[1]: ocs.service: Main process exited, code=exited, status=1/FAILURE
      May 18 08:52:18 elevate systemd[1]: ocs.service: Failed with result 'exit-code'.
      May 18 08:52:21 elevate systemd[1]: ocs.service: Scheduled restart job, restart counter is at 4.
      May 18 08:52:21 elevate systemd[1]: Stopped oozeBot Control Server.
      May 18 08:52:22 elevate systemd[1]: Dependency failed for oozeBot Control Server.
      May 18 08:52:22 elevate systemd[1]: ocs.service: Job ocs.service/start failed with result 'dependency'.
      • chrishammundefined
        chrishamm administrators
        @oozeBot It sounds like the Python client library doesn't set the correct timeout for IPC connections - it should be infinite. @Falcounet can you have a look please?
        Duet software engineer
        oozeBotundefined Falcounetundefined 2 Replies Last reply Reply Quote 0
        • oozeBotundefined
          oozeBot @chrishamm
          Thanks! In the meantime, we added a heartbeat that is run within the daemon to see if that protects against it timing out.
          • Falcounetundefined
            Falcounet @chrishamm
            @chrishamm @oozeBot Yes but I'm abroad for now so I couldn't look at this before the end of the week
            oozeBotundefined 1 Reply Last reply Reply Quote 2
            • oozeBotundefined
              oozeBot @Falcounet
              @Falcounet @chrishamm
              FYI - adding a call to a custom mCode every 10 seconds through daemon.g did not fix the issue.. Thanks
              • oozeBotundefined
                oozeBot
                Bumping this so it doesn't get lost.. plus we've noticed that this is not happening on all our machines, yet they all use the same OS image and are all running 3.4.5.
                We've now protected against this through a second "watchdog" service, but we'd obviously like it to not timeout in the first place as it's happening several times a day.
                Please let us know what we can help test/research between our machines to help diagnose the issue. Thanks
                  chrishamm administrators @oozeBot
                  @Falcounet Any idea?
                  Falcounetundefined 1 Reply Last reply Reply Quote 0
                    @chrishamm @oozeBot From what I see, you are not running the last version of dsfPython but that shouldn't change your issue anyway.
                    It doesn't seems easy for me to reproduce your issue so maybe you can try the following :
                    1. Backup /usr/local/lib/python3.9/dist-packages/dsf/connections.py as connections.py.bak
                    2. Edit /usr/local/lib/python3.9/dist-packages/dsf/connections.py and comment lines 161 and 162 : https://github.com/Duet3D/dsf-python/blob/8fd345ed6455102b4750e1e4470e52028e1b291e/src/dsf/connections.py#L161-L162
                    3. See if the issue still persists
                    • oozeBotundefined
                      oozeBot
                      Thanks! We’ll update to the latest version, make the change, and then let it bake for awhile to see if that fixes it. We’ll report back soon..
                        Falcounet @oozeBot
                        @oozeBot If you update first, the file will be /usr/local/lib/python3.9/dist-packages/dsf/connections/base_connection.py at lines 115 & 116 : https://github.com/Duet3D/dsf-python/blob/main/src/dsf/connections/base_connection.py#L115-L116
                        oozeBotundefined 1 Reply Last reply Reply Quote 1
                        • oozeBotundefined
                          oozeBot @Falcounet
                          @Falcounet
                          Maybe we are missing something , but after upgrading to the latest version, it appears something has changed with the imports. The snippet below worked fine in the previous version, but with the latest version, it fails to import MessageType and LogLevel from dsf.commands.basecommands and InterceptionMode from dsf.initmessages.clientinitmessages.
                          Any thoughts on why and how to get past this? Were they renamed? Seems unlikely but reverting to 3.3.2 resolves the issue.
                          Thanks
                          from dsf.commands.basecommands import MessageType
                          from dsf.commands.basecommands import LogLevel
                          from dsf.commands.code import CodeType
                          from dsf.connections import CommandConnection, InterceptConnection
                          from dsf.initmessages.clientinitmessages import InterceptionMode
                          One of the errors..
                          Jun 05 23:41:47 elevate OCS.py[564]:     from dsf.commands.basecommands import MessageType
                          Jun 05 23:41:47 elevate OCS.py[564]: ModuleNotFoundError: No module named 'dsf.commands.basecommands'
                            Falcounet @oozeBot
                            @oozeBot They are renamed because dsf-python has been refactored mainly to follow DuetAPI
                            Your imports should be changed as :
                            from dsf.connections import CommandConnection, InterceptConnection, InterceptionMode
                            from dsf.object_model import LogLevel, MessageType
                            • oozeBotundefined
                              oozeBot @Falcounet
                              @Falcounet It's been over 24 hours since the change was made and there have been no timeouts with the service.. however, I did upgrade to the latest version and remove those two lines of code at the same time. I've added the two lines back and will let it run for another 24 hours to see if something else in the latest version fixed the issue and then report back.
                              chrishammundefined 1 Reply Last reply Reply Quote 2
                                @oozeBot @Falcounet DSF may send zero-byte payloads to check if the socket is still open. I don't know if the Python client can actually detect that, if it does, those two lines should remain removed.
                                • oozeBotundefined
                                  oozeBot @chrishamm
                                  @chrishamm @Falcounet - just caught an error with the latest version.. so it appears Chris is right - DSF is sending zero-byte payloads which triggers this condition.
                                  I'll remove those lines and let it run to see if that, in fact, fixes it.
                                  Jun 08 13:45:59 elevate OCS.py[566]: Traceback (most recent call last):
                                  Jun 08 13:45:59 elevate OCS.py[566]:   File "/opt/dsf/sd/scripts/OCS.py", line 101, in <module>
                                  Jun 08 13:45:59 elevate OCS.py[566]:     cde = intercept_connection.receive_code()
                                  Jun 08 13:45:59 elevate OCS.py[566]:   File "/usr/local/lib/python3.9/dist-packages/dsf/connections/intercept_connectio>
                                  Jun 08 13:45:59 elevate OCS.py[566]:     return self.receive(commands.code.Code)
                                  Jun 08 13:45:59 elevate OCS.py[566]:   File "/usr/local/lib/python3.9/dist-packages/dsf/connections/base_connection.py">
                                  Jun 08 13:45:59 elevate OCS.py[566]:     json_string = self.receive_json()
                                  Jun 08 13:45:59 elevate OCS.py[566]:     raise TimeoutError
                                  Jun 08 13:45:59 elevate OCS.py[566]: TimeoutError
                                  Jun 08 13:46:00 elevate systemd[1]: ocs.service: Main process exited, code=exited, status=1/FAILURE
                                  • oozeBotundefined
                                    oozeBot
                                    @chrishamm @Falcounet - it has been over 3 days without a service crash since those two lines were removed on the latest version.. so it's pretty clear that's the issue.
                                    Please let me know when a new official release is available that removes these two lines so we can update all our machines and test once again. Thanks!
                                    oozeBotundefined 1 Reply Last reply Reply Quote 0
                                    • oozeBotundefined
                                      oozeBot @oozeBot
                                      @chrishamm @Falcounet - it has been over 4 months without a service crash since those two lines were removed on the latest version.. so it's pretty clear that's the issue.
                                      When will the codebase be updated to correct this issue in a new release? Thanks
                                      Falcounetundefined 1 Reply Last reply Reply Quote 1
                                        Falcounet @oozeBot
                                        @oozeBot The codebase was updated some months ago but I forgot to release the new version, sorry.
                                        dsf-python 3.4.6 is released today
                                        • oozeBotundefined
                                          oozeBot @Falcounet
                                          @Falcounet Thanks! The refactoring broke our code which worked in 3.4.5. I'm still learning and without more examples, I'm not certain what needs to change. Can you guide me through the changes to our declarations to get this working for the new version?
                                          Our Code:
                                          from dsf.connections import CommandConnection, InterceptConnection, InterceptionMode, SubscribeConnection, SubscriptionMode
                                          Errors presented in 3.4.6
                                          Nov 01 14:12:45 workbench1 systemd[1]: Started oozeBot Control Server.
                                          Nov 01 14:12:45 workbench1 OCS.py[868]: Traceback (most recent call last):
                                          Nov 01 14:12:45 workbench1 OCS.py[868]:   File "/opt/dsf/sd/scripts/OCS.py", line 17, in <module>
                                          Nov 01 14:12:45 workbench1 OCS.py[868]:     from dsf.commands.code import CodeType
                                          Nov 01 14:12:45 workbench1 OCS.py[868]:   File "/usr/local/lib/python3.7/dist-packages/dsf/__init__.py", line 10, in <module>
                                          Nov 01 14:12:45 workbench1 OCS.py[868]:     from . import commands, connections, http, object_model
                                          Nov 01 14:12:45 workbench1 OCS.py[868]:   File "/usr/local/lib/python3.7/dist-packages/dsf/connections/__init__.py", line 47, in <module>
                                          Nov 01 14:12:45 workbench1 OCS.py[868]:     from .base_command_connection import BaseCommandConnection
                                          Nov 01 14:12:45 workbench1 OCS.py[868]:   File "/usr/local/lib/python3.7/dist-packages/dsf/connections/base_command_connection.py", line 3, in <module>
                                          Nov 01 14:12:45 workbench1 OCS.py[868]:     from .base_connection import BaseConnection
                                          Nov 01 14:12:45 workbench1 OCS.py[868]:   File "/usr/local/lib/python3.7/dist-packages/dsf/connections/base_connection.py", line 6, in <module>
                                          Nov 01 14:12:45 workbench1 OCS.py[868]:     from .init_messages import client_init_messages, server_init_message
                                          Nov 01 14:12:45 workbench1 OCS.py[868]:   File "/usr/local/lib/python3.7/dist-packages/dsf/connections/init_messages/__init__.py", line 1, in <module>
                                          Nov 01 14:12:45 workbench1 OCS.py[868]:     from . import client_init_messages, server_init_message
                                          Nov 01 14:12:45 workbench1 OCS.py[868]:   File "/usr/local/lib/python3.7/dist-packages/dsf/connections/init_messages/client_init_messages.py", line 43, in <module>
                                          Nov 01 14:12:45 workbench1 OCS.py[868]:     auto_flush: bool = True):
                                          Nov 01 14:12:45 workbench1 OCS.py[868]: TypeError: 'type' object is not subscriptable
                                          Nov 01 14:12:45 workbench1 systemd[1]: ocs.service: Main process exited, code=exited, status=1/FAILURE
                                          Nov 01 14:12:45 workbench1 systemd[1]: ocs.service: Failed with result 'exit-code'.
                                            Falcounet @oozeBot
                                            @oozeBot I will need more of the source code to understand what is going on, not only the imports.
