    [3.5.0-rc1] daemon.g keeps running after renaming
    Beta Firmware
    • nikschaundefined
      nikscha
      Hi all,
      my daemon.g looks like this:
      while true
          G4 P2000
          echo "test"
      when remaning it to daemon1.g it keeps running:
      changing daemon1.g to
      while true
          G4 P2000
          echo "test2"
      yields
      Stay in school
      nikschaundefined 1 Reply Last reply Reply Quote 0
      • nikschaundefined
        nikscha @nikscha
        @nikscha
        RepRapFirmware for Duet 3 MB6HC version 3.5.0-rc.1 (2023-08-31 16:19:24) running on Duet 3 MB6HC v1.01 (SBC mode)
        Board ID: 08DJM-9P63L-DJ3S0-7J1F8-3S86T-TBJZ8
        Used output buffers: 1 of 40 (22 max)
        Static ram: 154852
        Dynamic ram: 90516 of which 1452 recycled
        Never used RAM 92980, free system stack 122 words
        Tasks: SBC(2,ready,1.1%,422) HEAT(3,nWait,0.0%,323) Move(4,nWait,0.4%,214) CanReceiv(6,nWait,0.1%,771) CanSender(5,nWait,0.0%,328) CanClock(7,delaying,0.0%,349) TMC(4,nWait,8.5%,59) MAIN(2,running,89.8%,137) IDLE(0,ready,0.1%,30), total 100.0%
        Owned mutexes: HTTP(MAIN)
        Last reset 01:10:35 ago, cause: power up
        Last software reset at 2023-10-16 15:38, reason: User, Expansion spinning, available RAM 92980, slot 0
        Software reset code 0x6012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0043c000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
        Error status: 0x00
        Aux0 errors 0,0,0
        MCU temperature: min 20.1, current 38.5, max 38.9
        Supply voltage: min 24.0, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
        12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
        Heap OK, handles allocated/used 99/15, heap memory allocated/used/recyclable 2048/1572/1248, gc cycles 1
        Events: 0 queued, 0 completed
        Driver 0: standstill, SG min 0, mspos 120, reads 42313, writes 51 timeouts 0
        Driver 1: standstill, SG min 0, mspos 408, reads 42313, writes 51 timeouts 0
        Driver 2: standstill, SG min n/a, mspos 8, reads 42348, writes 16 timeouts 0
        Driver 3: standstill, SG min n/a, mspos 8, reads 42348, writes 16 timeouts 0
        Driver 4: standstill, SG min n/a, mspos 8, reads 42353, writes 11 timeouts 0
        Driver 5: standstill, SG min 0, mspos 856, reads 42321, writes 43 timeouts 0
        Date/time: 2023-10-18 10:41:22
        Slowest loop: 67.45ms; fastest: 0.05ms
        === Storage ===
        Free file entries: 20
        DMs created 125, segments created 39, maxWait 701455ms, bed compensation in use: mesh, height map offset -0.016, ebfmin 0.00, ebfmax 0.00
        no step interrupt scheduled
        Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
        === DDARing 0 ===
        Scheduled moves 29069, completed 29069, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 84], CDDA state -1
        === DDARing 1 ===
        Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
        Heater 0 is on, I-accum = 0.1
        Heater 4 is on, I-accum = 0.2
        Telnet is idle in state(s) 0
        File* is idle in state(s) 0
        USB is idle in state(s) 0
        Aux is idle in state(s) 0
        Queue* is idle in state(s) 0
        LCD is idle in state(s) 0
        SBC is idle in state(s) 0
        Daemon* is idle in state(s) 0 0, running macro
        Aux2 is idle in state(s) 0
        File2* is idle in state(s) 0
        Queue2 is idle in state(s) 0
        Q0 segments left 0, axes/extruders owned 0x10000003
        Code queue 0 is empty
        Code queue 1 is empty
        === CAN ===
        Messages queued 93461, received 237613, lost 0, boc 0
        Longest wait 56ms for reply type 6041, peak Tx sync delay 536, free buffers 50 (min 49), ts 21178/21177/0
        Tx timeouts 0,0,0,0,0,0
        === SBC interface ===
        Transfer state: 5, failed transfers: 0, checksum errors: 0
        RX/TX seq numbers: 36389/36389
        SPI underruns 0, overruns 0
        State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x25a98
        Buffer RX/TX: 0/0-0, open files: 0
        === Duet Control Server ===
        Duet Control Server version 3.5.0-rc.1 (2023-09-01 07:16:31)
        Daemon:
        >> Doing macro daemon.g, started by system
        Code buffer space: 4096
        Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 1
        Full transfers per second: 1.54, max time between full transfers: 83.9ms, max pin wait times: 67.7ms/8.5ms
        Codes per second: 0.84
        Maximum length of RX/TX data transfers: 5684/2152
        Stay in school
          dc42 administrators @nikscha
          @nikscha yes it will keep running until the file terminates. In your case it never will because of the "while true" loop.
          The usual solution is to use a global variable to control it:
          if !exists(global.runDaemon)
            global runDaemon=true
          while global.runDaemon
          Then you can send set global.runDaemon=false from the console to stop the daemon.
          nikschaundefined 1 Reply Last reply Reply Quote 1
          • nikschaundefined
            nikscha @dc42
            @dc42 I see, I expected the file to be "reloaded" after saving and then not being found afterwards because of the renaming. Thank you for the solution!
            Stay in school
            • nikschaundefined nikscha marked this topic as a question
            • nikschaundefined nikscha has marked this topic as solved
