[3.4.5] DSF-Python - timeout failures
DSF Development
905
    Falcounet @oozeBot
    @oozeBot They are renamed because dsf-python has been refactored mainly to follow DuetAPI
    Your imports should be changed as :
    from dsf.commands.code import CodeType
    from dsf.connections import CommandConnection, InterceptConnection, InterceptionMode
    from dsf.object_model import LogLevel, MessageType
    undefined 1 Reply Last reply 7 Jun 2023, 17:26 Reply Quote 1
      oozeBot @Falcounet
      @Falcounet It's been over 24 hours since the change was made and there have been no timeouts with the service.. however, I did upgrade to the latest version and remove those two lines of code at the same time. I've added the two lines back and will let it run for another 24 hours to see if something else in the latest version fixed the issue and then report back.
      undefined 1 Reply Last reply 8 Jun 2023, 08:01 Reply Quote 2
        chrishamm administrators @oozeBot
        @oozeBot @Falcounet DSF may send zero-byte payloads to check if the socket is still open. I don't know if the Python client can actually detect that, if it does, those two lines should remain removed.
        Duet software engineer
        undefined 1 Reply Last reply 8 Jun 2023, 17:55 Reply Quote 1
          oozeBot @chrishamm
          @chrishamm @Falcounet - just caught an error with the latest version.. so it appears Chris is right - DSF is sending zero-byte payloads which triggers this condition.
          I'll remove those lines and let it run to see if that, in fact, fixes it.
          Jun 08 13:45:59 elevate OCS.py[566]: Traceback (most recent call last):
          Jun 08 13:45:59 elevate OCS.py[566]:   File "/opt/dsf/sd/scripts/OCS.py", line 101, in <module>
          Jun 08 13:45:59 elevate OCS.py[566]:     cde = intercept_connection.receive_code()
          Jun 08 13:45:59 elevate OCS.py[566]:   File "/usr/local/lib/python3.9/dist-packages/dsf/connections/intercept_connectio>
          Jun 08 13:45:59 elevate OCS.py[566]:     return self.receive(commands.code.Code)
          Jun 08 13:45:59 elevate OCS.py[566]:   File "/usr/local/lib/python3.9/dist-packages/dsf/connections/base_connection.py">
          Jun 08 13:45:59 elevate OCS.py[566]:     json_string = self.receive_json()
          Jun 08 13:45:59 elevate OCS.py[566]:     raise TimeoutError
          Jun 08 13:45:59 elevate OCS.py[566]: TimeoutError
          Jun 08 13:46:00 elevate systemd[1]: ocs.service: Main process exited, code=exited, status=1/FAILURE
            oozeBot
            @chrishamm @Falcounet - it has been over 3 days without a service crash since those two lines were removed on the latest version.. so it's pretty clear that's the issue.
            Please let me know when a new official release is available that removes these two lines so we can update all our machines and test once again. Thanks!
            undefined 1 Reply Last reply 30 Oct 2023, 14:18 Reply Quote 0
              oozeBot @oozeBot
              @chrishamm @Falcounet - it has been over 4 months without a service crash since those two lines were removed on the latest version.. so it's pretty clear that's the issue.
              When will the codebase be updated to correct this issue in a new release? Thanks
              undefined 1 Reply Last reply 1 Nov 2023, 17:06 Reply Quote 1
                Falcounet @oozeBot
                @oozeBot The codebase was updated some months ago but I forgot to release the new version, sorry.
                dsf-python 3.4.6 is released today
                undefined 1 Reply Last reply 1 Nov 2023, 18:19 Reply Quote 1
                  oozeBot @Falcounet
                  @Falcounet Thanks! The refactoring broke our code which worked in 3.4.5. I'm still learning and without more examples, I'm not certain what needs to change. Can you guide me through the changes to our declarations to get this working for the new version?
                  Our Code:
                  from dsf.connections import CommandConnection, InterceptConnection, InterceptionMode, SubscribeConnection, SubscriptionMode
                  Errors presented in 3.4.6
                  Nov 01 14:12:45 workbench1 systemd[1]: Started oozeBot Control Server.
                  Nov 01 14:12:45 workbench1 OCS.py[868]: Traceback (most recent call last):
                  Nov 01 14:12:45 workbench1 OCS.py[868]:   File "/opt/dsf/sd/scripts/OCS.py", line 17, in <module>
                  Nov 01 14:12:45 workbench1 OCS.py[868]:     from dsf.commands.code import CodeType
                  Nov 01 14:12:45 workbench1 OCS.py[868]:   File "/usr/local/lib/python3.7/dist-packages/dsf/__init__.py", line 10, in <module>
                  Nov 01 14:12:45 workbench1 OCS.py[868]:     from . import commands, connections, http, object_model
                  Nov 01 14:12:45 workbench1 OCS.py[868]:   File "/usr/local/lib/python3.7/dist-packages/dsf/connections/__init__.py", line 47, in <module>
                  Nov 01 14:12:45 workbench1 OCS.py[868]:     from .base_command_connection import BaseCommandConnection
                  Nov 01 14:12:45 workbench1 OCS.py[868]:   File "/usr/local/lib/python3.7/dist-packages/dsf/connections/base_command_connection.py", line 3, in <module>
                  Nov 01 14:12:45 workbench1 OCS.py[868]:     from .base_connection import BaseConnection
                  Nov 01 14:12:45 workbench1 OCS.py[868]:   File "/usr/local/lib/python3.7/dist-packages/dsf/connections/base_connection.py", line 6, in <module>
                  Nov 01 14:12:45 workbench1 OCS.py[868]:     from .init_messages import client_init_messages, server_init_message
                  Nov 01 14:12:45 workbench1 OCS.py[868]:   File "/usr/local/lib/python3.7/dist-packages/dsf/connections/init_messages/__init__.py", line 1, in <module>
                  Nov 01 14:12:45 workbench1 OCS.py[868]:     from . import client_init_messages, server_init_message
                  Nov 01 14:12:45 workbench1 OCS.py[868]:   File "/usr/local/lib/python3.7/dist-packages/dsf/connections/init_messages/client_init_messages.py", line 43, in <module>
                  Nov 01 14:12:45 workbench1 OCS.py[868]:     auto_flush: bool = True):
                  Nov 01 14:12:45 workbench1 OCS.py[868]: TypeError: 'type' object is not subscriptable
                  Nov 01 14:12:45 workbench1 systemd[1]: ocs.service: Main process exited, code=exited, status=1/FAILURE
                  Nov 01 14:12:45 workbench1 systemd[1]: ocs.service: Failed with result 'exit-code'.
                  undefined 1 Reply Last reply 1 Nov 2023, 18:38 Reply Quote 0
                    Falcounet @oozeBot
                    @oozeBot I will need more of the source code to understand what is going on, not only the imports.
                    undefined 1 Reply Last reply 1 Nov 2023, 18:47 Reply Quote 0
                      oozeBot @Falcounet
                      For posterity - this must have been an issue with Python as upgrading to 3.12 resolved the issue I just reported.
