    Relative movement without using G90 and G91
    Gcode meta commands
    • Phrayzurundefined
      Phrayzur
      I'm using some nested macros and I'm having issues where, when I'm in relative movment mode, the machine returns to absolute movement becaue I've called a macro that has the G90 command. I'm wondering if it's possible to issue a single relative movement command (eg. G1 Z20) in absolute movement mode without using G90 and G91. Alternatively, is it possible to set the value of inputs[0].axesRelative to a variable value like set inputs[0].axesRelative = {RelativeMoveVar}?
      I've tried using M120 and M121 but it also affects feedrate and hotend position.
        dc42 administrators @Phrayzur
        @Phrayzur when a macro finishes the absolute/relative mode returns to what it was when the macro was called.
        Phrayzurundefined 1 Reply Last reply Reply Quote 1
        • Phrayzurundefined
          Phrayzur @dc42
          @dc42 You are absolutely correct! I don't know why I thought otherwise. Thanks!
          • dc42undefined dc42 marked this topic as a question
          • dc42undefined dc42 has marked this topic as solved
