    Reporting variables
    Gcode meta commands
    • St Tawundefined
      St Taw
      Having calibrated my four tool corexy I would like to report the offsets it has found.
      I currently echo the variables by calling a macro
      echo "Camera X",global.CameraX, " Y", global.CameraY, " Z",global.CameraZ
      echo "T0Offset X",global.T0OffsetX," Y", global.T0OffsetY," Z",global.T0OffsetZ
      echo "T1Offset X",global.T1OffsetX," Y", global.T1OffsetY," Z",global.T1OffsetZ
      echo "T2Offset X",global.T2OffsetX," Y", global.T2OffsetY," Z",global.T2OffsetZ
      echo "T3Offset X",global.T3OffsetX," Y", global.T3OffsetY," Z",global.T3OffsetZ
      This results in the console
      03/01/2024, 10:13:40 M98 P"0:/macros/Calibration/Report Offsets.g"
      Camera X 6.577 Y 96.720 Z 0
      T0Offset X 0 Y 0 Z 0
      T1Offset X 0.060 Y 2.200 Z 0
      T2Offset X 0.220 Y 3.620 Z 0
      T3Offset X -0.043 Y 0.120 Z 0
      However not all the lines are always reported. Sometimes T2 and T3 lines are missing. Why could this be?
      What I would really like to do is report the variables with a Message dialog and require the user to Ok the message to continue. Like using a M291. However I have not found a way of reporting variables and putting them on multiple lines using M291.
      Any suggestions?
        dc42 administrators @St Taw
        @St-Taw I suggest you create a feature request on github, to allow M291 to create multi-line messages, perhaps by including \n or similar in the message string.
        St Tawundefined 1 Reply Last reply Reply Quote 0
        • St Tawundefined
          St Taw @dc42
          Thank you for reply.
          I will make the suggestion. However before I do, I have been unable to get a single line message reporting variables. Have tried
          M291 P "Camera X"^global.CameraX S2
          The documentation does not describe anything other than P"message" with no example of variables.
          Also I have an associated question.
          I would like to find out what the current offsets I have applied via the G10 command are during the calibration.
          As a test via the console I did
          G10 P0 X-22
          Then I move tool 0
          G1 X40
          Looking in the object model I find
          move|axes|0|machine position 62
          move|axes|0|userPosition 40
          So I can deduce it believes offset is 40-62 = -22
          Are the offets for all the tools visble in the object model specifically and without selecting the tool?
            @St-Taw whenever a parameter to a GCode command is an expression, the whole parameter expression must be enclosed in { }. So try this:
            M291 P{"Camera X"^global.CameraX} S2
            • St Tawundefined
              St Taw
              Yes that works. So I'll make the request for multi-line.
              Any views on the object model enquiry?
