    Thermostatically controlled fans ARE Incorrectly displayed
    Duet Web Control
    • Grant_fmundefined
      Grant_fm
      I upgraded to 3.5 and DWC and ever since the thermostatically controlled fans are now being displayed. Is this a bug or a feature? I would like them to be removed from the DWC
      Duet Web Control 3.4.4
      Board: Duet 2 WiFi (2WiFi)
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.5.0-rc.3 (2024-01-24)
      Duet WiFi Server Version: 1.27
      config.g
      ; Water Cooling System
      M308 S3 P"duex.e2_temp" Y"thermistor" T9500 B4700 ; configure sensor 1 as thermistor on pin e0temp
      M308 S3 A"Coolant Return" ;
      ;M950 H3 C"e2heat" T3 ; create chamber heater output on e1heat and map it to sensor 2
      M308 S4 P"duex.e3_temp" Y"thermistor" T9500 B4700 ; configure sensor 1 as thermistor on pin e0temp
      M308 S4 A"Coolant Out" ;
      M950 F1 C"duex.fan7" Q250 ; create fan 0 on pin fan0 set frequency
      M106 P1 S1.0 B0.2 H1 T40 C"Water Pump" ; Water Pump linked to H1
      ;M106 P1 H-1 C"Water Pump"
      M950 F2 C"duex.fan6" Q250
      M106 P2 S1.0 B0.2 H3 T30 C"Radiator" ; Cooling Fan linked to H1 Set P to P1 to test otherwise P=2
        droftarts administrators @Grant_fm
        @Grant_fm
        Update your version of DWC to the 3.5.0-rc3 release candidate here: https://github.com/Duet3D/RepRapFirmware/releases/tag/3.5.0-rc.3
        Use "DuetWebControl-SD.zip".
