    New RepRap Config tool an Absolute Headache
    Config Tool
    • Igniteundefined
      Ignite
      Okay I will begin by listing hardware, software, and firmware data.
      I am running the Duet 3 6HC mainboard, and it is running in SBC mode with a 4GB Raspberry Pi 4. I use an ethernet cable for comms and the Duet Web Control for controlling the board.
      Up till now I have run config files generated by the old RRF tool with some modification. And then recently I decided I would add a poor man's BL touch, so I figured I would switch and use the new RRF tool.
      Right off I started setting up the optical sensor for the poor man's bltouch and got it working, but when I went to home my X and Y it acted like the end-stops were already triggered so I tried changing the S1 in the config.g in the end-stop section to S0 but it said the S0 value is invalid so I put it back to S1 and tried rewiring my end-stops using every possible combination and no luck. So I switched out my end-stops for optical triggers and rigged up flags. That worked. Is there an explanation for the other end-stops?
      Next, the servo motor I am using for the poor man's bltouch buzzes, jumps up and down and gets hot when I go to print is it just the servo motor or is it something I got wrong in setup?
      Here is config.g the RRF tool v3.5.0-rc.3+2 please note that this config file is unmodified and the reason it is different in the Esteps and driver mapping is because I could set those up in the new tool but not in the old, and would have to modify them manually.
      ; Configuration file for RepRapFirmware on Duet 3 Main Board 6HC
      ; generated by RepRapFirmware Configuration Tool v3.5.0-rc.3+2 on Wed Apr 03 2024 22:07:59 GMT-0700 (Pacific Daylight Time)
      ; General
      M550 P"Duet 3" ; set hostname
      M551 P"reprap" ; set UI password
      ; Smart Drivers
      M569 P0.0 S1 D2 ; driver 0.0 goes forwards (X axis)
      M569 P0.1 S1 D2 ; driver 0.1 goes forwards (Y axis)
      M569 P0.2 S1 D2 ; driver 0.2 goes forwards (Y axis)
      M569 P0.3 S1 D2 ; driver 0.3 goes forwards (Z axis)
      M569 P0.4 S1 D2 ; driver 0.4 goes forwards (Z axis)
      M569 P0.5 S1 D2 ; driver 0.5 goes forwards (extruder 0)
      ; Motor Idle Current Reduction
      M906 I30 ; set motor current idle factor
      M84 S30 ; set motor current idle timeout
      ; Axes
      M584 X0.0 Y0.1:0.2 Z0.3:0.4 ; set axis mapping
      M350 X64 Y64 Z64 I1 ; configure microstepping with interpolation
      M906 X1200 Y1200 Z1200 ; set axis driver currents
      M92 X320 Y320 Z1600 ; configure steps per mm
      M208 X0:500 Y0:500 Z0:600 ; set minimum and maximum axis limits
      M566 X900 Y900 Z12 ; set maximum instantaneous speed changes (mm/min)
      M203 X9000 Y9000 Z180 ; set maximum speeds (mm/min)
      M201 X1000 Y1000 Z60 ; set accelerations (mm/s^2)
      ; Extruders
      M584 E0.5 ; set extruder mapping
      M350 E64 I1 ; configure microstepping with interpolation
      M906 E1200 ; set extruder driver currents
      M92 E1746.16 ; configure steps per mm
      M566 E120 ; set maximum instantaneous speed changes (mm/min)
      M203 E3600 ; set maximum speeds (mm/min)
      M201 E250 ; set accelerations (mm/s^2)
      ; Kinematics
      M669 K0 ; configure Cartesian kinematics
      ; Probes
      M558 K0 P9 C"io5.in" H5 F120 T6000 ; configure BLTouch probe via slot #0
      G31 P500 X20 Y20 Z0.7 ; set Z probe trigger value, offset and trigger height
      M950 S0 C"io7.out" ; create servo #0 for BLtouch
      M574 X1 P"io1.in" S1 ; configure X axis endstop
      M574 Y1 P"io2.in" S1 ; configure Y axis endstop
      M574 Z1 S2 ; configure Z axis endstop
      ; Mesh Bed Compensation
      M557 X25:475 Y25:475 S40:40 ; define grid for mesh bed compensation
      ; Sensors
      M308 S0 P"temp0" Y"thermistor" A"Heated Bed" T100000 B4725 C7.06e-8 ; configure sensor #0
      M308 S1 P"temp1" Y"thermistor" A"Nozzle" T100000 B4725 C7.06e-8 ; configure sensor #1
      M950 H0 C"out0" T0 ; create heater #0
      M143 H0 P0 T0 C0 S140 A0 ; configure heater monitor #0 for heater #0
      M307 H0 R2.43 D5.5 E1.35 K0.56 B0 ; configure model of heater #0
      M950 H1 C"out1" T1 ; create heater #1
      M143 H1 P0 T1 C0 S285 A0 ; configure heater monitor #0 for heater #1
      M307 H1 R2.43 D5.5 E1.35 K0.56 B0 ; configure model of heater #1
      ; Heated beds
      M140 P0 H0 ; configure heated bed #0
      M950 F0 C"out5" ; create fan #0
      M106 P0 S0 L0 X1 B0.1 ; configure fan #0
      M950 F1 C"out4" ; create fan #1
      M106 P1 S0 B0.1 H1 T45 ; configure fan #1
      M950 F2 C"out6" ; create fan #2
      M106 P2 S0 L0 X1 B0.1 ; configure fan #2
      M563 P0 D0 H1 F0 ; create tool #0
      M568 P0 R0 S0 ; set initial tool #0 active and standby temperatures to 0C
      Here is the config.g from RRF tool v3.4.1 please note the E-steps and driver mapping in this config file have not been modified for the printer this is how it looks off the tool.
      ; Configuration file for Duet 3 MB 6HC (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.4.1 on Sat Mar 30 2024 21:49:15 GMT-0700 (Pacific Daylight Time)
      G90                                                ; send absolute coordinates...
      M83                                                ; ...but relative extruder moves
      M550 P"Shawn's Printer"                            ; set printer name
      M551 P"reprap"                                     ; set password
      M540 P192.168.1.15                                 ; set custom MAC address
      M552 P0.0.0.0 S1                                   ; enable network and acquire dynamic address via DHCP
      M586 P0 S1                                         ; enable HTTP
      M586 P1 S0                                         ; disable FTP
      M586 P2 S0                                         ; disable Telnet
      M569 P0.0 S1                                       ; physical drive 0.0 goes forwards
      M569 P0.1 S1                                       ; physical drive 0.1 goes forwards
      M569 P0.2 S1                                       ; physical drive 0.2 goes forwards
      M569 P0.3 S1                                       ; physical drive 0.3 goes forwards
      M584 X0.0 Y0.1 Z0.2 E0.3                           ; set drive mapping
      M350 X64 Y64 Z64 E64 I1                            ; configure microstepping with interpolation
      M92 X320.00 Y320.00 Z16000.00 E4074.37             ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00                ; set maximum instantaneous speed changes (mm/min)
      M203 X12000.00 Y12000.00 Z180.00 E1200.00          ; set maximum speeds (mm/min)
      M201 X2000.00 Y2000.00 Z250.00 E250.00             ; set accelerations (mm/s^2)
      M906 X1200 Y1200 Z1200 E1200 I30                   ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                            ; Set idle timeout
      M208 X0 Y0 Z0 S1                                   ; set axis minima
      M208 X500 Y500 Z600 S0                             ; set axis maxima
      M574 X1 S1 P"!io0.in"                              ; configure switch-type (e.g. microswitch) endstop for low end on X via pin !io0.in
      M574 Y1 S1 P"!io1.in"                              ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin !io1.in
      M574 Z1 S1 P"!io2.in"                              ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin !io2.in
      M558 P0 H5 F120 T6000                              ; disable Z probe but set dive height, probe speed and travel speed
      M557 X15:485 Y15:485 S20                           ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B4138       ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out0" T0                                 ; create bed heater output on out0 and map it to sensor 0
      M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                            ; map heated bed to heater 0
      M143 H0 S120                                       ; set temperature limit for heater 0 to 120C
      M308 S1 P"temp1" Y"thermistor" T100000 B4138       ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out1" T1                                 ; create nozzle heater output on out1 and map it to sensor 1
      M307 H1 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S280                                       ; set temperature limit for heater 1 to 280C
      M950 F0 C"out4" Q500                               ; create fan 0 on pin out4 and set its frequency
      M106 P0 S0 H0:1 T45                                ; set fan 0 value. Thermostatic control is turned on
      M950 F1 C"out5" Q500                               ; create fan 1 on pin out5 and set its frequency
      M106 P1 S1 H T45                                   ; set fan 1 value. Thermostatic control is turned on
      M950 F2 C"out6" Q500                               ; create fan 2 on pin out6 and set its frequency
      M106 P2 C"Print cooling" S1 H T45                  ; set fan 2 name and value. Thermostatic control is turned on
      M563 P0 S"Biqu Extruder" D0 H1 F0                  ; define tool 0
      G10 P0 X0 Y0 Z0                                    ; set tool 0 axis offsets
      G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
      T0                                                 ; select first tool
      Thank you for looking and if anyone has any pointers I would be grateful. Let me know if you need anything or if something is unclear, I am exhausted and I don't know what I miss. Thanks in advance, Shawn
      • jumpedwithbothfeetundefined
        jumpedwithbothfeet
        When you say servo motor you mean like an RC servo? if that`s the case you need an M42 to control it, I didn't spot one in your config, take a look at the link.
        https://docs.duet3d.com/en/User_manual/Connecting_hardware/Motors_servos
        6HC Voron Trident based, 6XD CNC, Mini 5 polar printer
          Phaedrux Moderator @Ignite
          @Ignite said in New RepRap Config tool an Absolute Headache:
          You need to invert the pin by adding a ! to the pin name.
          https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m574-set-endstop-configuration
          P"pin_name" Defines the pin name(s) that the endstop(s) for the specified axis are connected to, see Pin Names. Needed when S=1. May need ! before pin name to invert signal, or ^ to enable the pullup resistor, for example on the Duet 2 expansion header if using the pins directly without a duex5.
          What do you have in deployprobe.g and retractprobe.g to command the servo?
