    'SPI connection has been reset' while tuning
    Beta Firmware
    627
    • NeoDueundefined
      NeoDue @Chorca
      @Chorca I am not too deep into what the M122 output tells us here, but if I interpret that correctly, the Duet is running config.g at the time and just finished a software reset with the reason "User" - a combination which I would interpret in such a way that the Duet actually got the command to reset itself from somewhere - which then logically killed the SPI connection for a brief time.
      Just to rule that out: I have no clue what you did run at that time in order to tune the printer, but if any kind of macro (including any system macros) was involved: did you check if there might be any misplaced code in there that could cause the reset?
      Edit - one more thing, thinking about your plexiglass mounting plate: do you happen to have a physical reset button or such added / configured?
      Chorcaundefined 1 Reply Last reply Reply Quote 0
      • Chorcaundefined
        Chorca @NeoDue
        @NeoDue I was running a "Record" command from the Closed Loop tuning plugin with these settings:
        Upon clicking Record, there's about a 20% chance the move will begin, and while the move is taking place, the printer will stop moving and the board resets.
        After going through plenty of motor tuning, the settings here don't seem to have any effect on the SPI errors. I'm assuming it may have to do with the motor data being transferred out of the controller to the Pi, but not sure if that would cause a reset or some other error may cause it.
        I don't have any physical reset buttons installed anywhere, just the board itself.
        Would any CAN bus commands from other boards cause a reset of the main Duet board?
        NeoDueundefined 1 Reply Last reply Reply Quote 0
        • NeoDueundefined
          NeoDue @Chorca
          @Chorca Okay, that excludes any EMF issues with an external reset button.
          Then I fear I am out, I do not know the plugin you use and do not use CAN here with my Duet as well.
          As I understand your initial post, the setup is new and was not tested before. Therefore, if it works with the printer, I would try to go forward with simplifying the system by disabling and physically removing any parts you deem a possible cause followed repeating your tests. If the error does not occur any more, you know that one of the pieces you unplugged and disabled is the culprit - plug some in, retry, etc. until you have narrowed down the issue.
          While you do that, someone who knows more about this plugin hopefully checks the software side 😉
          • Chorcaundefined
            Chorca @NeoDue
            @NeoDue Sadly, the change here was to move to closed-loop stepper control via the 1HCLs, and the closed-loop tuning is what seems to be instigating this issue, as I've never had this error occur outside running the closed loop tuning commands, so it seems like it's been narrowed down to something going on here.
            I appreciate the help!
            • Chorcaundefined
              Chorca
              A bit more info as I went through attempting to tune the motors again today.. it seems if the motor is oscillating a bit, i.e. running a low P (<20) with all other parameters set to zero, the resets happen more often and i can't get more than about 300ms of data from the board, but setting to higher values seems to make it happen less. An odd thing for sure.
              • Chorcaundefined
                Chorca
                Spent some more time on this tonight.
                I disconnected everything not necessary from the Duet board, leaving only power, 1 endstop, and the Z stepper motors, along with the CAN bus and SPI cable. Curiously I saw a reset or two happen without movement.
                I hooked up a logic analyzer to the SPI lines and checked those. I also enabled debug logging via the USB port.
                I checked the Duet's 3.3v line for any issues, spikes, noise, etc, but it is very quiet and during motor movements I saw no noise on it, so I feel like I've ruled out a brownout on the processor. I looked at some other lines but similarly didn't see much noise at all on them.
                Curiously, with debug enabled, the reset errors became much less frequent, which makes me wonder if there's a race or something that's causing a reset of the board.
                I've included a CSV of the SPI logging, and a text log from the Duet's serial output while the issue happened. The reset is at the end of the files, I stopped logging right after it died. I have the Saleae Logic file which I can send on request as the forum doesn't support that filetype.
                mini5_reset_log.txt
                mini5plus_reset.csv
                • NeoDueundefined
                  NeoDue @Chorca
                  @Chorca okay, that should indeed rule out the "simple" reason I suspected. Then I cross my fingers the devs here will be able to find the issue with your data!
                  (Probably a bit far-fetched, but anyway: I guess the oscilloscope you used to check the lines is fast enough to let you see possible spikes? This might only apply if you are using a rather antique and/or slow piece of equipment (as I do... 😇 ), but it does not hurt to mention it anyway before anyone starts chasing ghosts...)
                  • Chorcaundefined
                    Chorca @NeoDue
                    @NeoDue It is indeed a 250Mhz scope and I tested at a few speeds and triggers, to see if there was any detectable spikes.
                    I saw mentioned in another thread to verify if NC endstops are used, so i'll double-check that too.
                    chrishammundefined 1 Reply Last reply Reply Quote 1
                    • chrishammundefined
                      chrishamm administrators @Chorca
                      @Chorca Can you confirm that this issue persists with 3.5.0-rc.4?
                      Duet software engineer
                      • Chorcaundefined
                        Chorca @chrishamm
                        @chrishamm It appears to be happening much less with 3.5.1, though I was able to trigger a SPI reset; it happened after about 40 moves instead of one or two.
                        Instead it appears the data capture is being cut off somewhere, as the received data should be 1 second long but i am only getting around 150-350ms of data back for each run. Once in awhile (about every 10 runs) I get a complete data log.
                        Here's a screenshot showing my settings and the returned data:
                        EDIT: Looks like I spoke too soon, it seems to be resetting just as often on longer moves (100mm+).
                        I also validated that the endstop wasn't the culprit by unplugging it after homing, it still seems to reset without that connected.
