    Cant get my duetwifi to work after new FW.
    Firmware installation
    5.1k
    • Crilleundefined
      Crille
      @dc42:
      If you send M552 S1 from Pronterface, what responses do you get within the next minute? If you don't get a message saying that the connection to your router succeeded or failed, send M552 with no parameters so see what state the module is in.
      I get this.
      SENDING:M552 S1
      WiFi reported error: no known networks found
      Wifi module is idle
      SENDING:M552
      WiFi module is idle
      • Dougal1957undefined
        Dougal1957
        can you send a M587 and report that back?
        • Crilleundefined
          Crille
          @Dougal1957:
          SENDING:M587
          Remembered networks:
          GixxerTurbo IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
            Dougal1957
            ok so it has remembered your Network thenI have seen david say in another thread that sometimes happens due to the new stack and it normally resolves itself after a few reboots (3 or 4 I think he mentioned) worth trying and I am sure he will be along soon to advise.
            https://www.duet3d.com/forum/thread.php?id=3387&p=3 towards if not the very bottom of that page
              @Crille:
              @dc42:
              I get this.
              SENDING:M552 S1
              Wifi module is idle
              SENDING:M552
              WiFi module is idle
              Are you certain that your WiFi network SSID is called exactly GixxerTurbo ? SSIDs are case-sensitive.
              • Crilleundefined
                Crille
                @dc42:
                @Crille:
                @dc42:
                I get this.
                SENDING:M552 S1
                Wifi module is idle
                SENDING:M552
                WiFi module is idle
                Yes im 100% sure that my SSID is this 🙂
                  Strange, it's saying it can't find that network. Have you hidden the SSID on your router? Or could it be a signal strength problem?
                  • Crilleundefined
                    Crille
                    @dc42:
                    No i have not hide my network and signal strength is almost 100%, i have router in same room as printer.
                      Dougal1957
                      Can I ask a silly Question what is the Router make and Model my Wifi since v1.18 will not connect to my Netgear D6400 for more than a few seconds but it works fine with my TP-Linl TL710 or whatever model it is when configured as a wifi extender.
                      • Crilleundefined
                        Crille
                        I have ASUS RT-AC88U and it works great on all other stuff but not on Duetwifi 😞
                        Its realy strange that it dont work.
                        Is it possible to reverse the duetwifi to factory state that it was shipped?…
                          Dougal1957
                          it should work mine does see the router but then boss out which is different to your symptoms I would do M588 to forget all networks and set that bit up again. M588 * to forget all remember when setting it back up again you can't do it with the Paneldue or pronterface as neither of them can pass lowercase characters and as DC42 has said it is case sensitive.
                          • Crilleundefined
                            Crille
                            Ok i try again and set it up in YAT and see if its differense. Have done this several times and still no go 😞
                            • Crilleundefined
                              Crille
                              No it will not work..
                              Printer is now online.
                              m587
                              SENDING:M587
                                Does M552 S1 still report "no known networks found" ?
                                • Crilleundefined
                                  Crille
                                  @dc42:
                                  Yes it does… Is it possible to reverse to older FW this is no fun..
                                  Brand new duetwifi that dont work 😞
                                  • botundefined
                                    bot
                                    Have you configured your router to be compatible with legacy radio modes? Your router is an AC router, and possibly is not configured to work with the the G (or N?) standard that the wifi uses.
                                    *not actually a robot
                                    • Crilleundefined
                                      Crille
                                      @bot:
                                      I have router on automatic and that is both legacy radio and N.
                                      Also tryed to change to only legacy = no go at all.
                                      I start to belive this is a faulty duetwifi, i have tryed out all now and still no go, change my network name and delete all Connections, reflashed several times…
                                        Please try the just-released firmware 1.20 (both main and WiFi). Note the correct installation order as detailed on the release page of GitHub. If you still can't get it working, you can revert to older firmware.
                                        • Crilleundefined
                                          Crille
                                          @dc42:
                                          Have now try this out, but sorry to say its the same… It remember my network but no IP number... This cant be FW issue at all i have try out all
                                          options now. OR do i miss someting?...
                                          SENDING:M587
                                          gixxerturbo IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
                                          SENDING:M552 S1
                                          Wifi module is idle
                                            Dougal1957
                                            Check the Case of the names it is important
                                            earlier you had SSI with caps in it now you dont please check carefully
