Conditional Loops running slow after SBC addition
I've had a duet 3 mini 5+ running on a machine of mine for about two years. Recently I added an RPi 4b and made the switch to having an SBC. Everything went pretty smooth, except I have a startup.g that runs at the end of my config that is behaving a bit odd. All the startup macro does is run a little animation on my neopixel strips. Ever since updating to the SBC (and updating to firmware 3.5.1) the startup script takes considerably longer to run (about 10x as long). I did notice that there were some minor changes to the M150 code, but I made the necessary updates after updating to 3.5.1.
There is a delay variable, but changing the value has had no effect since the upgrade. Anyone have any ideas? Am I missing something? TIA!
var ledbright = 0 var increment = 5 var delay = 0.02 var ledglow = 0 var glowcount = 3 var ledcount = 1 var ubright = 0 var uincrement = 4 var bbright = 50 var bincrement = -1 while var.ledglow < var.glowcount while var.ledbright < 255 M150 R255 U0 B50 P{var.ledbright} S16 G4 S{var.delay} set var.ledbright = var.ledbright + var.increment while var.ledbright > 0 M150 R255 U0 B50 P{var.ledbright} S16 G4 S{var.delay} set var.ledbright = var.ledbright - var.increment set var.ledglow = var.ledglow + 1 M150 P0 S16 while var.bbright > 25 M150 R255 U{var.ubright} B{var.bbright} P255 S{var.ledcount} F1 M150 P0 S16 set var.ubright = var.ubright + var.uincrement set var.bbright = var.bbright + var.bincrement set var.ledcount = var.ledcount + 1 G4 S{var.delay*5} ; M150 R255 U100 B100 P255 S16 M150 R255 U100 B25 P255 S16 -
@wcj97 By default, RRF waits 25ms between SBC data transfers and per meta condition, one data transfer is needed. That may explain why it behaves differently. Note that regular G-codes are buffered by RRF, so movement should remain smooth in any case.
If you can live with some increased CPU usage of the SBC while your macro is being executed, you can put
M576 S0
at the top of your macro andM576 S25
at the bottom. That will basically eliminate delays between transfers while your macro runs and it should speed up conditional G-codes significantly. -
@chrishamm said in Conditional Loops running slow after SBC addition:
M576 S0
That worked perfectly, thank you! I was afraid the issue might have had to do with how the SBC sends commands to the Duet. Startup script is running normally now.
