Error M997
Have a Duet 2 Ethernet with PanelView.
With 3.4.5 config file receiving this error when installing config file.
Error: M997: Firmware binary "0:/firmware/Duet2CombinedFirmware.bin" is not valid for this electronics
What did you download to get your firmware file?
What firmware are you currently running? Send M115 to check.
You may also require IAP files from the firmware bundle to correctly flash the firmware with the M997 command. The better way to flash is to upload the complete firmware zip file via DWC if you have access.
