    New beta firmware 1.20.1RC2 and DuetWiFiServer 1.20+1
    Firmware installation
    13
    68
    9.8k
    • garyd9undefined
      garyd9
      There was a report earlier about DWC "layer X of Y" showing the wrong numbers for dual extrusion prints. I have a similar issue with the start (only) of a single layer print. At the end of this message, I'll include a link to the gcode file being referenced, but let me describe what is going on:
      When the print starts (waiting for tools to heat), the DWC shows layer 0 of 111.
      When the print moves to the part of the gcode that displays a message "Purging and Wiping T1", the DWC shows layer 2 of 111. This part of my startup code does two Z movements before moving on to the real print.
      When the print moves on the build plate and actually starts printing the first layer (identified in the gcode with the comment "; layer 1, Z = 0.162"), DWC still shows "layer 2 of 111" and the head position Z is correctly noted as 0.16
      When the print moves to the next layer (identified in the gcode with the comment "; layer 2, Z = 0.342"), DWC still shows "layer 2 of 111", and the head position Z is correctly noted as 0.34
      Finally, when the print moves to the next layer (identified in the gcode with the comment "; layer 3, Z = 0.522"), DWC finally catches up showing "layer 3 of 111."
      My WAG is that my startup gcode that does the "purge and wipe" is confusing the duet because of multiple Z moves up and down. However, if that's the case, I don't understand how it "catches up" at layer 3. If my guess is correct, is there something I can include in my gcode to let the duet know that "here is where the actual print starts, so reset the layer to 1"?
      gcode file: https://drive.google.com/file/d/1MWXt1cxYU0ZMMG2RMMgH25-8_ynrjyHl/view?usp=sharing
      Thanks
      Gary
        @burtoogle:
        Hi David, I think I have discovered why I am seeing underextrusion when I use M592 on my Kossel XL fitted with a flex3drive extruder. With A and B set to 0, the x/y motion and the extruder activity start/stop at the same time (as close as I can tell by eye/ear). When I set non-zero values (e.g A=0.015 and B=0.0012) I notice that the extruder stops before the x/y movement stops. The faster the feedrate, the more obvious the gap becomes.
        Here's the relevant config lines:
        [[language]]
        M350 I1 X16 Y16 Z16 E16			; all axes use x16 microstepping with interpolation (steps/mm will get adjusted automatically)
        M92 X160 Y160 Z160			; Set axis steps/mm (20 tooth pulleys, 0.9deg/step motors)
        M906 X1000 Y1000 Z1000 E1000 I60	; Set motor currents (mA)
        M201 X3000 Y3000 Z3000 E400		; Accelerations (mm/s^2)
        M203 X18000 Y18000 Z18000 E1200		; Maximum speeds (mm/min)
        M566 X300 Y300 Z300 E10			; Maximum instant speed changes
        M92 E4320				; Set extruder steps per mm (flex3drive)
        Thanks, I look into it.
          I found the problem. I'll get a new 1.20.1RC out soon with a fix.
          • burtoogleundefined
            burtoogle
            A new 1.20.1RC would be most welcome!
              burtoogle
              Any chance of a new RC? I am keen to try out the fixed M592.
                I am working through bug reports at the moment, trying to get some fixes implemented before I release it. However, there is a pre-release Duet Wifi build at https://www.dropbox.com/s/8pvnkzaf0hqxf7x/DuetWiFiFirmware.bin?dl=0.
                  burtoogle
                  Thanks, I'm trying it now…
                    burtoogle
                    Appears to work as expected, testing PETG at 240C, 0.4mm v6, flex3drive extruder. Preliminary results indicate A=0.05, B=0.004 work well up to 3.5mm/S. From 4mm/S upwards, compensation not really effective which doesn't surprise me as I've never been able to reliably get much more than approx 6 mm^3/S out of the v6. Will continue to test but it's looking good so far.
                      Thanks for the feedback. I have not tested whether increasing the spring tension on my Titan affects the amount of nonlinearity.
                        burtoogle
                        The flex3drive extruder doesn't appear to have any means of adjusting the "grip" - hasn't been a problem so far except for some TPU like stuff I have which is only 1.55 dia and so I have to add some packing to the over-centre lever otherwise the filament slips. The extruder works OK but it's a shame that it doesn't have any means of adjusting for filament diameters that aren't close to 1.75.
                          burtoogle
                          Done some prints with M592 active and they look very good. I believe the quality in terms of extrusion amounts has been improved. Here's a couple of images…
                            burtoogle
                            Discovered an interesting side effect of the non-linear extrusion - now that it doesn't underextrude (so much) at the higher extrusion rates, I found that a print using TPU like filament failed because the extrusion rate on a skin layer increased sufficiently to reach the throughput limit of the extruder/hotend combo. So a gcode file that had printed OK before, now doesn't print well. The solution was to reslice the part with a reduction in the speed at which the skin was being printed so that the throughput limit was no longer being reached.
                            • BMMalundefined
                              BMMal
                              I did not get my machine to reproduce the slowdown issue I posted about in another thread. However, after updating to this firmware and printing for the last 30 minutes I checked the diagnostics and got the following:
                              [[language]]
                              SENDING:M122
                              Used output buffers: 1 of 32 (16 max)
                              RepRapFirmware for Duet WiFi version 1.21RC0+1 running on Duet WiFi 1.0 + DueX5
                              Board ID: 08D6M-91AST-L23S4-7JTD8-3S86K-1PX1K
                              Static ram used: 15448
                              Dynamic ram used: 100464
                              Recycled dynamic ram: 2872
                              Stack ram used: 3584 current, 8472 maximum
                              Never used ram: 3816
                              Last reset 00:57:06 ago, cause: software
                              Last software reset at 2018-01-22 15:05, reason: User, spinning module GCodes, available RAM 3536 bytes (slot 0)
                              Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
                              Error status: 8
                              [ERROR] Error status: 8
                              Free file entries: 8
                              SD card longest block write time: 177.8ms
                              MCU temperature: min 27.9, current 28.9, max 29.3
                              Supply voltage: min 24.3, current 24.6, max 25.1, under voltage events: 0, over voltage events: 0
                              Driver 0: ok, SG min/max 0/1023
                              Driver 1: ok, SG min/max 0/1023
                              Driver 2: standstill, SG min/max 0/624
                              Driver 3: ok, SG min/max 0/237
                              Driver 5: standstill, SG min/max 0/97
                              Driver 6: standstill, SG min/max not available
                              Driver 7: standstill, SG min/max not available
                              Expansion motor(s) stall indication: yes
                              Date/time: 2018-01-22 16:02:33
                              Slowest main loop (seconds): 0.179090; fastest: 0.000046
                              MaxReps: 4, StepErrors: 0, LaErrors: 0, FreeDm: 220, MinFreeDm 155, MaxWait: 4292717656ms, Underruns: 0, 0
                              Scheduled moves: 2116, completed moves: 2109
                              Bed compensation in use: none
                              Heater 0 is on, I-accum = 0.0
                              Heater 1 is on, I-accum = 0.1
                              Segments left: 1
                              Stack records: 4 allocated, 0 in use
                              Movement lock held by null
                              http is idle in state(s) 0
                              telnet is idle in state(s) 0
                              file is doing "G1 X318.756 Y289.891 E0.00223" in state(s) 0
                              serial is ready with "M122" in state(s) 0
                              aux is idle in state(s) 0
                              daemon is idle in state(s) 0
                              queue is idle in state(s) 0
                              Code queue is empty.
                              === Network ===
                              Network state is running
                              WiFi firmware version 1.20+1
                              WiFi MAC address a0:20:a6:16:e6:c6
                              WiFi Vcc 3.26, reset reason Turned on by main processor
                              WiFi flash size 4194304, free heap 16832
                              WiFi IP address 10.0.0.115
                              WiFi signal strength -38dBm, reconnections 0, sleep mode modem
                              HTTP sessions: 1 of 8
                              Socket states:  0 0 0 0 0 0 0 0
                              Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                              Duet Ethernet - Most likely the most recent Edge firmware
                              Duet X5
                              7" Panel Due V2
                              Cartesian, 4 Nozzles with Flex3Drives, Heated Chamber, Simple Switch Filament Sensing
                                Can you provide a link to your post in the other thread?
                                • BMMalundefined
                                  BMMal
                                  @dc42:
                                  https://www.duet3d.com/forum/thread.php?id=4045#p36563
                                  Duet X5
                                  7" Panel Due V2
