    Homing delta not working, possible configuration issue?
    Firmware installation
    1.2k
    • martinbogoundefined
      martinbogo
      I am configuring my new delta printer, a 1M tall, 500mm side three-tower. I have upgraded my Duet WiFi to 1.20, and my paneldue is still running 1.16. Right now I am just working out the kinematics of the machine, so I have not connected the fans, extruder motor, extruder heater, thermistor, bed heater, or the IR probe.
      Since I will be using an IR probe, I deleted the files related to deploying the probe as documented in 1.19's Changelog.
      When I press the "Home" button on the PanelDue, or send G28, the three delta carriages move up about 1-2mm, and then nothing else happens. Every G28/Home Press moves them up a little bit more, but the carriages do not act as they should. I am using Kysan bipolar 1.8 degree steppers @24V, 16 microsteps, 48T pulleys, and GT2 belts. My configured axis steps/mm is therefore 33.33 steps per mm. (200*16)/48/2
      As far as I can tell, the steppers are moving smoothly and quietly, in the correct direction… I'm just not seeing the right behavior.
      The configuration files in sys:
      My config.g is:
      [[language]]
      M550 PMartinDelta		; Machine name and Netbios name (can be anything you like)
      M551 Preprap                      	; Machine password (used for FTP)
      ;*** If you have more than one Duet on your network, they must all have different MAC addresses, so change the last digits
      M540 P0xBE:0xEF:0xDE:0xAD:0xa3:0x22 	; MAC Address
      ;*** Wifi Networking
      M552 S1				; Enable WiFi
      M555 P2               ; Set output to look like Marlin
      M575 P1 B57600 S1			; Comms parameters for PanelDue
      G21                                 	; Work in millimetres
      G90                                	; Send absolute coordinates...
      M83                                 	; ...but relative extruder moves
      ; Axis and motor configuration
      M569 P0 S1				; Drive 0 goes forwards
      M569 P1 S1				; Drive 1 goes forwards
      M569 P2 S1				; Drive 2 goes forwards
      M569 P3 S1				; Drive 3 goes forwards
      M569 P4 S1				; Drive 4 goes forwards
      M574 X2 Y2 Z2 S1			; set endstop configuration (all endstops at high end, active high)
      ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration
      M665 L256 R431.8 H500 B155 X0 Y0	; set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0				; put your endstop adjustments here, or let auto calibration find them
      M350 X16 Y16 E16 I1    			; Set 16x microstepping with interpolation
      M92 X33.33 Y33.33 Z33.33					; Set axis steps/mm
      M906 X1200 Y1200 Z1200 E800 I60		; Set motor currents (mA) and increase idle current to 60%
      M201 X1000 Y1000 Z1000 E1000		; Accelerations (mm/s^2)
      M203 X20000 Y20000 Z20000 E3600		; Maximum speeds (mm/min)
      M566 X1200 Y1200 Z1200 E1200		; Maximum instant speed changes mm/minute
      ; Thermistors
      ; M305 P0 T100000 B3950 R4700 H30 L0	; Put your own H and/or L values here to set the bed thermistor ADC correction
      ; M305 P1 T100000 B3974 R4700 H30 L0	; Put your own H and/or L values here to set the first nozzle thermistor ADC correction
      ; M570 S180				; Hot end may be a little slow to heat up so allow it 180 seconds
      ; M106 P1 T50 H1				; Fan 1 turns on at 50C, cools hotend
      ; M106 P2 H-1
      ; M106 P3 H-1
      ; Tool definitions
      ; M563 P0 D0 H1                       	; Define tool 0
      ; G10 P0 S0 R0                        	; Set tool 0 operating and standby temperatures
      ;*** If you have a single-nozzle build, comment the next 2 lines
      ;M563 P1 D1 H2                      	; Define tool 1
      ;G10 P1 S0 R0                       	; Set tool 1 operating and standby temperatures
      ; M92 E663:663                       	; Set extruder steps per mm
      ; Z probe and compensation definition
      ;*** If you have a switch instead of an IR probe, change P1 to P4 in the following M558 command
      M558 P1 X0 Y0 Z0			; Z probe is an IR probe and is not used for homing any axes
      G31 X0 Y0 Z4.80 P500			; Set the zprobe height and threshold (put your own values here)
      ;*** If you are using axis compensation, put the figures in the following command
      M556 S78 X0 Y0 Z0                   	; Axis compensation here
      M208 S1 Z-0.2				; set minimum Z
      ;T0					; select first hot end
      My homedelta.g is:
      [[language]]
      ; Homing file for RepRapFirmware on Mini Kossel
      G91							; use relative positioning
      G1 S1 X500 Y500 Z500 F2500	; move all carriages up 320mm, stopping at the endstops
      G1 S2 X-3 Y-3 Z-3			; move all carriages down 3mm
      G1 S1 X6 Y6 Z6 F250			; move carriages slowly up 6mm, stopping at the endstops
      G1 Z-5 F2000				; down a few mm so that we can centre the head
      G90							; back to absolute positioning
      G1 X0 Y0 F2000				; centre the head and set a reasonable feed rate
        martinbogo
        D'oh!
        Fiigured it out… two of the axes endstops were swapped ( Y/Z ) and didn't go to the corresponding motors., and because I was using Maker Mechanical 1.2 endstops, the logic was reversed ( S0 vs S1 )
        Now that is fixed, I still have one more mysterious issue. I can run G28 and the machine homes, BUT afterwards I can't get any G0/G1 moves to work, and there are no errors on the console of the paneldue.
        I go into relative mode, then try to instruct the machine to drop down 50mm :
        G91
        G1 Z-10 F2000
        Nada. No errors, just no movement.
          martinbogo
          Follow-up
          I can do G92 X0 Y0 Z360 ( the actual height of my towers to the bed ) and it works
          I can do G91 and run the TOWERS.. i.e. ( G91 S1 X-50 Y-50 Z-50 F2500 ) and the towers move
          I just can't do G91, then G1 Z-10 F2000 for example … no movement, but also no errors
            There is an error in your M665 command. The combination of L and R you have specified is physically impossible. Your R (delta radius) parameter looks to me to be about double what it should be, perhaps more than double.
            • number40fanundefined
              number40fan
              Increase the X, Y and Z in G1 S1 X500 Y500 Z500 F2500 in your homedelta to 800+ so you don't have to double tap home when you are stretched out on the build plate.
