    Firmware 1.21 release candidate 2 now available
    Firmware installation
    22
    81
    11.2k
    • nickpgreundefined
      nickpgre
      Came here to report.
      CoreXY with bltouch and multitouch probing enabled with Probe 5 (P5), prints and everything works fine. Also the web interface feels more responsive.
      • BMMalundefined
        BMMal
        I just installed this RC so I have not yet reached the end of a print with this firmware but it seems that the slowdown issue here: https://www.duet3d.com/forum/thread.php?id=4045#p36659 still persists. I recently noticed that sometimes my machine would enter this state at the beginning of a print as well as consistently at the end (on RC1). It got stuck in this slow state with RC2 at the beginning of the first print I just started.
        I expect that it will enter this slow state at the end of the print as well but if not I will be sure to report back.
        Duet Ethernet - Most likely the most recent Edge firmware
        Duet X5
        7" Panel Due V2
        Cartesian, 4 Nozzles with Flex3Drives, Heated Chamber, Simple Switch Filament Sensing
        • BMMalundefined
          BMMal
          On RC1, I got 3 of my simple switch filament sensors working, using the following configurations:
          T0 M591 D0 P2 C3
          T1 unused for now
          T2 M591 D2 P2 C5
          T3 M591 D3 P2 C5
          I am now getting errors that C5 is not acceptable. Is this correct?
          With X, Y, and Z endstops connected what are the C numbers that I can use for 4 filament sensors?
          If I went to sensor less homing, what would the C numbers be?
          Can some C numbers be used with only certain types of sensors (P)?
          Does it matter if an expansion board is present?
          It looks like the pad printing on the boards and C numbers correspond as follows, correct?
          X C0
          Y C1
          Z C2
          E0 C3
          E1 C4
          E2 C5
          E3 C6
          E4 C7
          E5 C8
          E6 C9
          Sorry to ask so many questions but I'm having a hard time figuring this out from the wiki: https://duet3d.dozuki.com/Wiki/Gcode#Section_M591_Configure_filament_sensing
          Duet X5
          7" Panel Due V2
            Thanks for spotting this, it will be fixed in RC3.
            • BMMalundefined
              BMMal
              After installing RC1 (at least that is when I noticed), my machine stopped reporting layer times and therefore estimates based on layer time. This issue persists in RC2. My gcodes are generated using KISSlicer. This may have started because I began using Z hop in Kisslicer (an no FW z hop) since it can filter hops out for really short travel moves.
              Duet X5
              7" Panel Due V2
              • kazolarundefined
                kazolar
                I was going to submit a new bug report, but my machine is doing this SLOW CRAWL right now – it's a slow state of 12 hours into 15 hour print. Which is really frustrating. The DWC disconnects -- I don't know if there is away to save the print as I know where it is,
                  @kazolar:
                  Which Duet are you using? Does the machine print each move at normal speed but pause between moves, or does it do moves continuously but at slower than normal speed?
                  • kazolarundefined
                    kazolar
                    I have the Duet Ethernet Duex5 7 inch LCD. And 2 external driver pins used as well. It moves very slowly in jerky fashion.
                    It seems that it's thinking a lot for each move, so DWC becomes unable to connect. Last time this happened it was doing another 12+ hour print but it was quad color, I saw checksum errors on the screen, so I figured it was a bad SD card, and I swapped SD cards, and was able to do 20 hour prints since. It looks like it started doing it pretty late into the print – I have 19 puzzle pieces on the bed and the artifcats of this movement is only 2 -- so I caught it in time to save the other 17.
                    I was finally able to connect to DWC -- pause the print, and it saved resurrect.g -- then I adjusted my homing (z probe points are away from the print, and the print was not tall enough to bother the gantry system. I was able to trigger a stop to reboot it -- then I homed it -- then did g32 with the H value set high so the dual lead screw compensation can run (can that be saved as part of resurrect, my machine when powered off -- Z doesn't move at all) -- I'd like to just save Z position, and any lead screw adjustments which were made.
                    It's printing now -- and looks like I was able to recover most of the print
                    thanks
                    • kazolarundefined
                      kazolar
                      I think as I look at the artifacts it is doing each straight line move at normal speed, but then sits there creating a blob. There are a lot of curves in this print, so it was doing those at a jerky pace since I believe curves are a combination of small straight lines. Hope that helps
                        Thanks. Can you confirm that you are definitely running firmware 1.21RC2? Please check using M115.
                        • kazolarundefined
                          kazolar
                          in DWC:
                          Firmware Name: RepRapFirmware for Duet WiFi and Duet Ethernet
                          Firmware Electronics: Duet Ethernet 1.02 or later + DueX5
                          Firmware Version: 1.21RC2 (2018-02-15 build 2)
                          Web Interface Version: 1.20-RC3
                          M115
                          FIRMWARE_NAME: RepRapFirmware for Duet WiFi and Duet Ethernet FIRMWARE_VERSION: 1.21RC2 ELECTRONICS: Duet Ethernet 1.02 or later + DueX5 FIRMWARE_DATE: 2018-02-15 build 2
                            Thanks. I've had similar reports from a small number of Duet Ethernet users, but not with 1.21RC2. You've confirmed that this issue hasn't gone away in the new combined Duet WiFi/Duet Ethernet firmware.
                            If it happens again, please try the following:
                            1. See if you can connect to a PC via USB and Pronterface or a terminal emulator and run simple non-movement commands e.g. M115.
                            2. If so, send M552 S0 to stop the network interface, then wait for the acknowledgment. See if normal speed is resumed.
                            3. If normal speed is resumed, send M552 S1 to start the network interface.
                            Alternatively, if you are able to connect DWC you can just send M552 S0 and see if normal speed is resumed. Obviously you will lose the connection, and you will need to restart the network from USB or PanelDue.
                            • kazolarundefined
                              kazolar
                              My duet is connected to constant 5V power, so it's always "on" – so does it make sense to run disable/enable network at start of each print? Or include those commands in my power off/power on macros? Is it a side effect of it being on all the time?
                              • BMMalundefined
                                BMMal
                                @dc42:
                                I think you may have missed my comment reporting that this persisted for me on RC2 as well. It is on the previous page of the thread.
                                I can also confirm that mine still does this at the end of prints and often when idle.
                                Duet X5
                                7" Panel Due V2
                                • resamundefined
                                  resam
                                  I just installed firmware RC2 and also the WifiServer RC2. It seems like I'm having FTP issues again.
                                  [c]wget -r -nH ftp://10.0.0.42/[/c] just hangs at trying to transfer/load [c].listing[/c].
                                  As soon as I execute wget, DWC gets a request timeout. After a few seconds I can reconnect with DWC, but wget still hangs and I have to kill it.
                                  M122 doesn't show anything - not even an active FTP socket.
                                  The console on PanelDue shows the well known message that it (re-) connected to my WiFi, no error message, just that it is connected now.
                                  Reverting back to WifiServer 1.21RC1 solves it.
                                    Thanks for the report, added to my list to investigate.
                                    • JohnOCFIIundefined
                                      JohnOCFII
                                      Just as a datapoint - I installed RC2 over RC1 on DuetWiFi and did a quick G32 calibration and test print on my Kossel Mini. All when well.
                                      • SantiagoMTundefined
                                        SantiagoMT
                                        good morning, 5 days ago I updated the duet to 1.21rc2 and for more that I change the config.g the hot bed to pid keeps showing up in bang bang, I do not know what file to play to change it to pid, in 1.20 and 1.19 it could change without problem, what may be happening?
                                          The bed heater will run in PID mode if you have a M307 command for it that includes the B0 parameter.
                                          • S1lencerundefined
                                            S1lencer
                                            Currently iam printing a lot of parts over night, i think the funktion of Enable autosleep in DWC does not work correctly if not at all.
                                            Came to the Printer in the morning and it had still the printing tempretures on the nozzle an bed.
