    New firmware 1.21RC3 available
    Firmware installation
    31
    159
    24.3k
      deckingman
      @whosrdaddy:
      @garyd9:
      Finally, I think this change is taking something away from users instead of giving something to them. It adds an (IMO) unneeded restriction that I'm not even sure makes sense (for cartesian printers.)
      Taking a WAG, it sounds like something an OEM might want in their firmware so the end-user doesn't drive an axis beyond a stop hear the steppers skipping. If that's the case, please make this an OPTION that OEM's can enable in config.g (or an option that everyone else can turn OFF in config.g) and not a requirement.
      Yes this should be a configurable feature!
      +1
      • Markdndundefined
        Markdnd
        @dc42:
        @Markdnd:
        Has current layer been removed from DWC in 1.21RC3?
        I can’t see it anywhere just a very inaccurate completion percentage where it used to be.
        (It claims I am 57.5% of the way through but the print has only 2mm to go of a 30mm print and is, in reality, at least 90% complete)
        Was the GCode file sliced by Cura? There is an issue with displaying the current layer when printing files generated by Cura.
        No, it was Simplify3D
        • Mikeundefined
          Mike
          I'm getting "Error: Attempt to seek on a non-open file." upon trying to print files from slic3r PE on 1.21RC3. The same files work OK on 1.20.
          • DjDemonDundefined
            DjDemonD
            I'm getting the same error on my corexy.
            M122 - https://1drv.ms/t/s!Apv79JfGbPIwg5QsmYhl9eYy6yVTZg
            when I try to downgrade to 1.21 rc2 I get
            M997 S0
            Error: M997: Firmware binary "Duet2CombinedFirmware.bin" not found
            I managed to restore RC2 after hitting erase and flashing it using SAM-BA.
            Working normally now, but still using wifiserver rc3, DWC rc3
            www.precisionpiezo.co.uk
            • Mikeundefined
              Mike
              Same, the error pops on a CoreXY machine. As for reverting to an older version… Just rename the old firmware to Duet2CombinedFirmware.bin and proceed as usual. Worked for me.
              • DjDemonDundefined
                DjDemonD
                I tried that, it didn't work, perhaps I didn't get the filename exactly right but I copy and paste it knowing it would need to be.
                • tjb1undefined
                  tjb1
                  @kraegar:
                  Kind of odd. If I power on, go to the gcode console, and send G1 Z-10 S2 it'll move as expected. If I send the same thing again, though, no movement. But if I change the Z value to something else, like G1 Z-20 S2, then it'll move as expected.
                  To further confuse me, now it's moving the opposite direction I should after a few more Z moves before homing.
                  9:44:10 AMG1 Z-20 S2
                  9:44:02 AMG1 Z-30 S2
                  9:43:53 AMG1 Z-40 S2
                  9:43:44 AMG1 Z-20 S2
                  9:43:39 AMG1 Z-20 S2
                  The Z-30 and Z-20 both moved the bed in positive Z instead of negative.
                  Those commands are being sent as absolute, once you move to Z-10, it can't go anywhere on the second Z-10 because it's already there. Same thing with the second issue, you are already at Z-40 and going back in the positive direction to Z-30 and Z-20, both are 10+ moves.
                  • garyd9undefined
                    garyd9
                    I don't know if this was fixed in RC3 or not, but I just noticed the following issue in RC2:
                    When setting up a z-probe with P5 (It's a BLtouch) A3 (probe each location up to 3 times) and B1 (turn off bed heater while probing), the heater gets turned off for the FIRST of multi-tap probes, but not subsequent multi-tap probes.
                    So, assuming a M558 of:
                    M558 P5 X0 Y0 Z1 H5 F100 T4000 A3 B1
                    and a bed.g containing the following:
                    G30 P0 X1.1 Y-69.2 Z-99999
                    G30 P1 X-50 Y65.5 Z-99999
                    G30 P2 X49 Y65.5 Z-99999 S3
                    (and the manual levelling assistant configured.)
                    In each of the above probes, the heater is turned off for the FIRST test in each location, but the heater is turned back on (and stays on) for the SECOND probe. (My probes are apparently within 0.03 of each other, as I don't see a third probe in any location.)
                    • kraegarundefined
                      kraegar
                      @tjb1:
                      @kraegar:
                      Yep, I realized that once I had some more coffee. 🙂
                      • Amiliousundefined
                        Amilious
                        I think that I might have found a bug.
                        When doing the command
                        G1 X4 Y4 F200 S2;
                        only the X-axis moves
                        I am using this in my homeall.g
                        Here is my old homeall.g with added S2 does not work
                        [[language]]
                        G91				               ; Relative Positioning
                        G1 Z5 F6000 S2			; Lower Z
                        G1 X4 Y4 F600 S2             	; move away from the endstops
                        G1 S1 X-305 Y-305 F3000   	; course home X or Y
                        G1 S1 X-305               	        ; course home X
                        G1 S1 Y-305               	        ; course home Y
                        G1 S1 X-10                	        ; fine home X
                        G1 S1 Y-10                	        ; fine home Y
                        G90				                ; Absolute positioning
                        G1 X8 Y30 F5000 S2		; Move to first probe point
                        T0 				                ; select tool
                        M280 P3 S160 I1			; release Z probe alarm
                        G1 Z5 F200 S2 			; lower bed
                        G4 P500 			                ; wait for the bed to lower
                        M401				        ; deploy the probe
                        G30 				                ; calibrate Z-axis
                        M402				        ; Retract Probe
                        G1 x0 y0 F5000			; Move to 0,0
                        G1 Z0 F200			        ; Move to Z 0
                        • Amiliousundefined
                          Amilious
                          @DjDemonD:
                          M997 S0
                          Maybe try renaming the old firmware that you are trying to downgrade to "Duet2CombinedFirmware.bin". The newer versions look for that file name, the same way you had to rename the Duet2CombinedFirmware.bin to DuetWiFiFirmware.bin when upgrading the first time.
                            When upgrading and downgrading between firmware versions in which the expected name of the firmware binary has changed, you need to take account of:
                            1. The binary name that the current installed firmware expects. Firmware 1.21RC3 expects Duet2CombinedFirmware.bin. Firmware 1.21RC2 on the Duet Ethernet expects DuetWiFiFirmware.bin. Firmware 1.21RC1 and earlier expect DuetWiFiFirmware.bin or DuetEthernetFirmware.bin depending on which board you have.
                            2. The binary name that the currently-installed version of DuetWebControl expects. DWC 1.21RC4 expects Duet2CombinedFirmware.bin. Older versions of DWC expect DuetWiFiFirmware.bin or DuetEthernetFirmware.bin depending on which board you have.
                            What always works is:
                            • upload the firmware binary you want to install;
                            • use the System Editor page of DWC to rename it to the name expected by the currently-installed firmware;
                            • send M997 to install it.
                            • DjDemonDundefined
                              DjDemonD
                              Okay, well that's simple enough. That was though just a minor issue, its the fact that RC3 doesn't seem to work on corexy that was the main event for me.
                                @DjDemonD:
                                Please provide more details of why RC3 didn't work for you, along with any relevant GCode files.
                                • kraegarundefined
                                  kraegar
                                  It's working with my CoreXY OK.
                                  (I'm chasing some print artifacts, but they exist on 1.20 as well, so I don't think it's FW related)
                                  • Mikeundefined
                                    Mike
                                    In my case it was "Error: Attempt to seek on a non-open file." when trying to print anything sliced on Slic3r PE on my CoreXY. Reverted to the old firmware and finished the print without issues. I'll run a couple more tests on both my delta and the CoreXY in the evening.
                                    • kraegarundefined
                                      kraegar
                                      I get that right at the end of files from Cura. Not at all from S3D. But it prints the full print for Cura.
                                      • DjDemonDundefined
                                        DjDemonD
                                        @dc42:
                                        @DjDemonD:
                                        Hi David sorry scroll up a bit I provided a report and an M122. Corexy and attempting to print a SlicerPE file, so same issue others have had, downgrading just FW fixed it. Deltas working perfectly on rc3.
                                        • resamundefined
                                          resam
                                          I'm also running a CoreXY - didn't experience any issues with RC3 so far, about 5 prints or so successfully finished.
                                          DC42: I think it would make sense to add the new debug information about SD cluster size to M122 as well.
                                            @Mike:
                                            Thanks. Please can you confirm or otherwise:
                                            1. The fault only occurs when you try to print a file from SD card. In particular, just listing the files on the DWC GCode Files page doesn't provoke the problem;
                                            2. The fault only occurs if the file was sliced by slic3r PE;
                                            3. All files sliced with this version of slicer PE exhibit this issue when you try to print them.
                                            Please supply a small test file that demonstrates the problem.
