    Filament monitor using HC-020K encoder
    Filament Monitor
    7.9k
      It could be that your sensor pulls the endstop input low enough to light the LED but not low enough to register as low in the processor. Use the Machine Properties tab of DWC to check whether the detected state of that input changes as the wheel rotates and the LED turns on and off.
      • pabomanundefined
        paboman
        In the DWC the E0 is triggered correctly, it change its state from NO to YES as I rotate the encoder wheel
          Thanks. I found the first bug in support for pulsed filament sensors. Please try the firmware at https://www.dropbox.com/s/iq9pzfaugyfei7x/Duet2CombinedFirmware.bin?dl=0.
          • pabomanundefined
            paboman
            Installed the firmware 1.21RC5+ (2018-03-17 build 1) apparently nothing has changed.
            Still [c]M591 D0
            Pulse-type filament monitor on endstop input 3, sensitivity 1.00mm/pulse, check every 3.0mm, tolerance 50.0%, no data received[/c]
            https://youtu.be/nitZGkwWn7s
            Maybe something wrong with my conf.g ?
              Did you get that report after the wheel had spun a few times and the LED flashed off and on?
              • pabomanundefined
                paboman
                yes, after 30 min of printing the report is the same
                  I've rewritten the pulsed filament monitor support based on the code for the rotating magnet sensor, which is know to be working. Also I have changed the configuration parameters to be the same as for the rotating magnet sensor. You are welcome to try it (it's at https://www.dropbox.com/s/iq9pzfaugyfei7x/Duet2CombinedFirmware.bin?dl=0)), but as I haven't had time to test it yet I don't expect it to work.
                  • pabomanundefined
                    paboman
                    I have just upgraded the firmware, should I change something in my config.g ?
                    Right now i have :
                    [c]; Filament Monitor HC-020K
                    M591 D0 P7 C3 S1 R70:130 L24.8 E3.0 ; Duet3D rotating magnet sensor for extruder drive 0 is connected to E0 endstop input, 7 = pulse-generating, sensorsensitivity 24.8mm.rev, 50% to 130% tolerance, 3mm detection length
                    M591 D0 ; display filament sensor parameters for extruder drive 0[/c]
                    • pabomanundefined
                      paboman
                      now after the prints begins i get : [c]Extruder 0 reports too little movement[/c]
                      • pabomanundefined
                        paboman
                        Upgraded to:
                        1.21RC5+ (2018-03-17 build 2)
                        I have changed my settings in config.g to:
                        M591 D0 P7 S23.5 C3 R50 E3.0 ; Duet3d sensor for extruder drive 0 is connected to endstop input 3 (E0), S=23.5mm/rev, R=50% error detection tolerance, C=3mm comparison length
                        Still getting [c]Extruder 0 reports too little movement[/c]
                        the strange thing is that The S parameters is set to 23.5 while after M591 D0 I get :
                        [c]M591 D0
                        Pulse-type filament monitor on endstop input 3, enabled, sensitivity 28.80mm/pulse, allowed movement 50% to 160%, check every 3.0mm, current position 0.0, no calibration data[/c]
                        the S parameter is 28.8 instead of 23.5
                        I will be more than happy to send you one HC-020K encoder, just send me the adress to info@3dbnz.com and on Monday UPS will collect the parcel.
                        in the mean time, thank you
                        • pabomanundefined
                          paboman
                          setting the sensitivity very low to 0.2 makes the print goes thru
                          then issuing M591 D0
                          I get [c]Pulse-type filament monitor on endstop input 3, disabled, sensitivity 28.80mm/pulse, allowed movement 20% to 160%, check every 3.0mm, current position 0.0, measured sensitivity 160.73mm/pulse, measured minimum 0%, maximum 2877% over 63648.7mm [/c]
                          so i set S value to 160 but then i get again:
                          and the printer go to pause
                          PS
                          while the S is 0.2 there is no difference if I remove the sensor from the wheel, the print does not go to pause
                          Why M591 D0 is telling me [c]disabled[/c] ?
                            As I said, I brought the parameters into line with the other filament monitors. So S now enables or disables filament monitoring, and L sets the sensitivity. See https://duet3d.dozuki.com/Wiki/Gcode#Section_M591_Configure_filament_sensing.
                            You will probably need to increase the E parameter.
                            160mm/pulse sounds far too high. Can you measure it?
                            • pabomanundefined
                              paboman
                              what P parameter should I use?
                              still P7 for pulse-generating sensor or P3 for rotating magnet sensor ?
                              One complete rotation of the wheel is 20 pulses
                              Encoder wheel diameter is 26mm
                              E0 stepes per mm is 1166 ( 13to1 gearbox ratio)
                                Strill P7.
                                Are you saying that 26mm filament movement give 20 pulses? If so that's 1.3mm per pulse.
                                I've put a new firmware binary with more sensible default values at https://www.dropbox.com/s/iq9pzfaugyfei7x/Duet2CombinedFirmware.bin?dl=0.
                                • pabomanundefined
                                  paboman
                                  Diameter of the encoder wheel is 26mm so the circumference is 26 x 3.1416 = 81.7 mm
                                  So 81.7mm of extruded filament is one full turn of the encoder wheel which gives 20 pulses
                                  81.7 / 20 = 4
                                  if so 4mm per pulse
                                  upgraded to: 1.21RC5+ (2018-03-18 build 1)
                                  with this config.g:
                                  M591 D0 P7 C3 S0 R70:130 L4.1 E50 ; D= sensor for extruder drive 0, C= E0 endstop input, P=Sensor type, S1= Enable, R=70% to 130% tolerance, L= mm/pulse, E= detection length
                                  i get this response:
                                  [c]10:16:26M591 D0
                                  Pulse-type filament monitor on endstop input 3, disabled, sensitivity 4.10mm/pulse, allowed movement 70% to 130%, check every 50.0mm, current position 0.0, measured sensitivity 12778.21mm/pulse, measured minimum 0%, maximum 33% over 1763392.6mm
                                  10:14:15M591 D0
                                  Pulse-type filament monitor on endstop input 3, disabled, sensitivity 4.10mm/pulse, allowed movement 70% to 130%, check every 50.0mm, current position 0.0, measured sensitivity 12296.81mm/pulse, measured minimum 0%, maximum 25% over 479575.5mm[/c]
                                  If I enable the monitor with S1 i get "Extruder 0 reports too little movement":
                                  [c]10:18:18Printing paused
                                  10:18:17Resume-after-power-fail state saved
                                  10:18:16M591 D0
                                  Pulse-type filament monitor on endstop input 3, enabled, sensitivity 4.10mm/pulse, allowed movement 70% to 130%, check every 50.0mm, current position 0.0, measured sensitivity 25.00mm/pulse, measured minimum 16%, maximum 16% over 50.0mm[/c]
                                  The strange thing is the measured sensitivity of 12778.21mm/pulse while monitor is disabled
                                    So the filament runs on the outside of the 26mm diameter encoder wheel?
                                    The measured sensitivity is clearly absurd, as is the recorded extrusion amount (1.76km in the first report). I'll take another look at the code.
                                    • pabomanundefined
                                      paboman
                                      yes, the filament runs on the outside diameter of the 26mm encoder wheel for now. later I will change that to a smaller diameter
                                        I found a likely explanation for the absurd values. Please pick up a new binary from https://www.dropbox.com/s/iq9pzfaugyfei7x/Duet2CombinedFirmware.bin?dl=0.
                                        • pabomanundefined
                                          paboman
                                          ok, upgraded the firmware, now im getting "Extruder 0 reports too much movement" 🙂
                                          also reducing the E Value from 50 to 10 gives the same result
                                          [c]11:18:53M591 D0
                                          Pulse-type filament monitor on endstop input 3, enabled, sensitivity 4.10mm/pulse, allowed movement 70% to 130%, check every 10.0mm, current position 0.0, measured sensitivity 0.66mm/pulse, measured minimum 439%, maximum 801% over 22.5mm[/c]
                                            Are you certain that he pulse rate of your encoder is 4.10mm of filament per pulse? What happens if you set it to 0.66mm as reported by the calibration?
                                            I'll have the calibration value reported to 3 decimal places in the next build.
