Cant build DuetWifiServer
i cant build the DuetWifiServer, and eclipse send this error:make all
Building file: ../src/HSPI.cpp
/bin/sh: xtensa-lx106-elf-g++: command not found
Invoking: Cross G++ Compiler
xtensa-lx106-elf-g++ -std=c++0x -D__ets__ -DICACHE_FLASH -DF_CPU=80000000L -DESP8266 -DARDUINO_ARCH_ESP8266 -DARDUINO_ESP8266_ESP12 -DARDUINO=10606 -U__STRICT_ANSI__ -I"/Users/xxx/Workspace/c++/CoreESP8266/cores/esp8266" -I"/Users/xxx/Workspace/c++/CoreESP8266/variants/nodemcu" -I"/Users/xxx/Workspace/c++/CoreESP8266/libraries/ESP8266WiFi/src" -I"/Users/xxx/Workspace/c++/CoreESP8266/libraries/ESP8266mDNS" -I"/Users/xxx/Workspace/c++/CoreESP8266/libraries/DNSServer/src" -I"/Users/xxx/Workspace/c++/CoreESP8266/libraries/EEPROM" -I"/Users/xxx/Workspace/c++/CoreESP8266/sdk/include" -Os -Wall -c -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -ffunction-sections -fdata-sections -MMD -MP -MF"src/HSPI.d" -MT"src/HSPI.o" -o "src/HSPI.o" "../src/HSPI.cpp"
make: *** [src/HSPI.o] Error 127I have read , that i also need the CoreESP8266 in my eclipse workspace, but when i try to build this first, i get this errorMessage:
make all
Building file: ../libraries/ESP8266mDNS/ESP8266mDNS.cpp
xtensa-lx106-elf-g++ -std=gnu++11 -D__ets__ -DICACHE_FLASH -DF_CPU=80000000L -DARDUINO=10606 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DESP8266 -I"/Users/xxx/Workspace/c++/CoreESP8266/cores/esp8266" -I"/Users/xxx/Workspace/c++/CoreESP8266/variants/nodemcu" -I"/Users/xxx/Workspace/c++/CoreESP8266/libraries/ESP8266WiFi/src" -I"/Users/xxx/Workspace/c++/CoreESP8266/libraries/ESP8266mDNS" -I"/Users/xxx/Workspace/c++/CoreESP8266/sdk/include" -Os -g -Wall -c -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -ffunction-sections -fdata-sections -MMD -MP -MF"libraries/ESP8266mDNS/ESP8266mDNS.d" -MT"libraries/ESP8266mDNS/ESP8266mDNS.o" -o "libraries/ESP8266mDNS/ESP8266mDNS.o" "../libraries/ESP8266mDNS/ESP8266mDNS.cpp"
In file included from /Users/xxx/Workspace/c++/CoreESP8266/libraries/ESP8266WiFi/src/ESP8266WiFi.h:40:0,
from ../libraries/ESP8266mDNS/ESP8266mDNS.h:46,
from ../libraries/ESP8266mDNS/ESP8266mDNS.cpp:41:
/Users/xxx/Workspace/c++/CoreESP8266/libraries/ESP8266WiFi/src/WiFiServer.h:28:39: fatal error: lwip/err.h: No such file or directory
#include "lwip/err.h" // for err_t
compilation terminated.
make: *** [libraries/ESP8266mDNS/ESP8266mDNS.o] Error 1I think the main problem is, that eclipse cant find the command xtensa-lx106-elf-g++ . I already linked this to my environment variable , and my shell knows the command. Iam working with a mac and Eclipse IDE for C/C++ Developers. For the first steps , i used this manual : https://github.com/dc42/RepRapFirmware/blob/dev/BuildInstructions.md
Best regards
Erik -
You need the LwipESP8266 project in your Eclipse workspace too.
oh ok , thanks.
but i get the error:/bin/sh: xtensa-lx106-elf-gcc: command not found
how can i fix that ?
@eberlin said in Cant build DuetWifiServer:
oh ok , thanks.
Make sure that the compiler is on your PATH. The earlier message indicates that it did find xtensa-lx106-elf-g++. I think you should have the xtensa-lx106-elf-gcc file in the same directory.
ok,
I have built "LwipESP8266" at first and "CoreESP8266" at second.without any errors.
but when i building "DuetWifiServer" i got this error:make all
Building file: ../src/Parsing.cpp
xtensa-lx106-elf-g++ -std=c++0x -D__ets__ -DICACHE_FLASH -DF_CPU=80000000L -DESP8266 -DARDUINO_ARCH_ESP8266 -DARDUINO_ESP8266_ESP12 -DARDUINO=10606 -U__STRICT_ANSI__ -I"/Users/xxx/Workspace/c++/CoreESP8266/cores/esp8266" -I"/Users/xxx/Workspace/c++/CoreESP8266/variants/nodemcu" -I"/Users/xxx/Workspace/c++/CoreESP8266/libraries/ESP8266WiFi/src" -I"/Users/xxx/Workspace/c++/CoreESP8266/libraries/ESP8266mDNS" -I"/Users/xxx/Workspace/c++/CoreESP8266/libraries/DNSServer/src" -I"/Users/xxx/Workspace/c++/CoreESP8266/libraries/EEPROM" -I"/Users/xxx/Workspace/c++/CoreESP8266/sdk/include" -Os -Wall -c -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -ffunction-sections -fdata-sections -MMD -MP -MF"src/Parsing.d" -MT"src/Parsing.o" -o "src/Parsing.o" "../src/Parsing.cpp"
In file included from ../src/Parsing.cpp:23:0:
make: *** [src/Parsing.o] Error 1 -
Project DuetWiFiServer is obsolete. Use project DuetWiFiSocketServer instead.
thanks a lot,
I have built "LwipESP8266" and "CoreESP8266" , again without any errors, but when i building "DuetWifiSocketServer" i got his error message :
Building target: DuetWiFiSocketServer.elf
Invoking: Cross G++ Linker
xtensa-lx106-elf-g++ -nostdlib -L"/Users/xxx/Workspace/c++/CoreESP8266/Release" -L"/Users/xxx/Workspace/c++/CoreESP8266/sdk/lib" -L"/Users/xxx/Workspace/c++/DuetWiFiSocketServer/src/ld" -TDuetWiFiSocketServer.ld -Wl,--no-check-sections -u call_user_start -u _printf_float -u _scanf_float -Wl,-static -Wl,--gc-sections -Wl,-wrap,system_restart_local -Wl,-wrap,spi_flash_read -Wl,-Map,DuetWiFiSocketServer.map -o "DuetWiFiSocketServer.elf" -Wl,--start-group ./src/Connection.o ./src/HSPI.o ./src/Listener.o ./src/Misc.o ./src/SocketServer.o -lCoreESP8266 -lhal -lphy -lpp -lnet80211 -lLwipESP8266 -lwpa -lcrypto -lmain -lwps -laxtls -lespnow -lsmartconfig -lairkiss -lmesh -lwpa2 -lstdc++ -lm -lc -lgcc -Wl,--end-group
/Users/xxx/Documents/esp8266-Arduino-master/esp8266com/esp8266/tools/macosx/xtensa-lx106-elf/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld: cannot find -lLwipESP8266
collect2: error: ld returned 1 exit status
make: *** [DuetWiFiSocketServer.elf] Error 1 -
I think you are using incompatible versions of the various GitHub projects. I am out of the office, but AFAIR you need to use the dev branches of the 3 projects.
ok , this makes sense , thank you.
i tried to use the projects from the dev branches , and when i built the "duetWifiServerSocket" project, i got this error :Building target: DuetWiFiSocketServer.elf
xtensa-lx106-elf-g++ -nostdlib -L"/Users/xxx/Workspace/c++/LwipESP8266/Release" -L"/Users/xxx/Workspace/c++/CoreESP8266/Release" -L"/Users/xxx/Workspace/c++/CoreESP8266/sdk/lib" -L"/Users/xxx/Workspace/c++/DuetWiFiSocketServer/src/ld" -TDuetWiFiSocketServer.ld -Wl,--no-check-sections -u call_user_start -u _printf_float -u _scanf_float -Wl,-static -Wl,--gc-sections -Wl,-wrap,system_restart_local -Wl,-wrap,spi_flash_read -Wl,-Map,DuetWiFiSocketServer.map -o "DuetWiFiSocketServer.elf" -Wl,--start-group /Users/xxx/Workspace/c++/CoreESP8266/Release/cores/esp8266/heap.o ./src/Connection.o ./src/HSPI.o ./src/Listener.o ./src/Misc.o ./src/SocketServer.o -lCoreESP8266 -lhal -lphy -lpp -lnet80211 -lLwipESP8266 -lwpa -lcrypto -lmain -lwps -laxtls -lespnow -lsmartconfig -lairkiss -lwpa2 -lstdc++ -lm -lc -lgcc -Wl,--end-group
/Users/xxx/Documents/Arduino/hardware/esp8266com/esp8266/tools/macosx/xtensa-lx106-elf/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld: cannot find -lLwipESP8266
Check that you have file libLwipESP8266.a in the Release folder within the LwipESP8266 project. That is the output file from building that project.
I confirm that you need to use the dev branch of all 3 projects to build version 1.21.
hmm ok ,
but i already use the dev branches for each of the 3 projects and i have a file named : "libLwipESP8266.a in the release folder of the LwipESP8266 project. -
In that case I suggest you check what the library path is set to in the linker settings for project DuetWiFiSocketServer, because that folder should be included in it.
Yes, that looks OK. Looking at your command line from one of your previous posts:
the settings concerned (in bold) look OK to me too. Did you check that the case of the letters in the actual output file in /Users/xxx/Workspace/c++/
CoreLwipESP8266/Release was exactly correct? I build under Windows, so an error in the letter case wouldn't matter on my system. -
Sorry, I meant /Users/xxx/Workspace/c++/LwipESP8266/Release.
Looks like it's got the right file there, assuming that it is a sensible file and not zero length or something like that. I suggest you clean and rebuild project LwipESP8266. After that, if DuetWiFiSocketServer still won't link, try copying the libLwipESP8266.a file into one of the other library search directories, and/or ask for help with Eclipse and/or gcc.
i cleaned an rebuilt the project, and it still dont work. i also copied the file into some search directories, but it returned the same error ...
Wierd, it's finding -lCoreESP8266 but not -lLwipESP8266 which has a similar format and the same number of characters. Does the libLwipESP8266.a file look a sensible size, and does it have the correct date/time corresponding to when you built it? My copy of that file is 423 KB (433,816 bytes) long. Were any errors reported when you cleaned and built project LwipESP8266 ?
EDIT: for reference, this is what I get:
'Invoking: Cross G++ Linker'
xtensa-lx106-elf-g++ -nostdlib -L"C:\Eclipse\Firmware/LwipESP8266/Release" -L"C:\Eclipse\Firmware/CoreESP8266/Release" -L"C:\Eclipse\Firmware/CoreESP8266/sdk/lib" -L"C:\Eclipse\Firmware/DuetWiFiSocketServer/src/ld" -TDuetWiFiSocketServer.ld -Wl,--no-check-sections -u call_user_start -u _printf_float -u _scanf_float -Wl,-static -Wl,--gc-sections -Wl,-wrap,system_restart_local -Wl,-wrap,spi_flash_read -Wl,-Map,DuetWiFiSocketServer.map -o "DuetWiFiSocketServer.elf" -Wl,--start-group C:\Eclipse\Firmware/CoreESP8266/Release/cores/esp8266/heap.o ./src/Connection.o ./src/HSPI.o ./src/Listener.o ./src/Misc.o ./src/SocketServer.o -lCoreESP8266 -lhal -lphy -lpp -lnet80211 -lLwipESP8266 -lwpa -lcrypto -lmain -lwps -laxtls -lespnow -lsmartconfig -lairkiss -lwpa2 -lstdc++ -lm -lc -lgcc -Wl,--end-group
'Finished building target: DuetWiFiSocketServer.elf'
