New firmware 2.0RC5 available
Firmware installation
23
88
12.4k
    zerspaner_gerd
    It seems the filament management is broken.
    "filaments.csv" file is no longer updated automatically.
    If I change this hand, I can not load filament via DWC anymore.
    With M701 S"TEST" , an error occurs shortly before completion.
    Can anybody confirm this!
    Board: Duet WiFi 1.03 | Firmware Version: 3.1.1 | WiFi Server Version: 1.23 | Web Interface Version: 3.1.1
    undefined undefined 2 Replies Last reply 26 May 2018, 21:25 Reply Quote 0
      MSquared @zerspaner_gerd
      @zerspaner_gerd I also cannot seem to load filaments anymore.
        zerspaner_gerd @zerspaner_gerd
        @zerspaner_gerd said in New firmware 2.0RC5 available:
        The error with M701 S "test" is due to the M502!
        @dc42 Is this intended the M502, all tools and heaters off?
        undefined 1 Reply Last reply 28 May 2018, 18:31 Reply Quote 0
          DocTrucker
          Running 1.21.1RC5 and Christian Hammacher's 1.21.1.
          I can see the simulation time appended to the end of the file, but not visible on DWC?
          undefined 1 Reply Last reply 28 May 2018, 18:26 Reply Quote 0
            BMMal @dc42
            @dc42 Yes, I'm using your RC5 binary
            I do have simple switch filament monitors. The machine disables/deconfigures the filament monitors at the start of each print to make sure there are not any from a previous print, see start.g.
            Then using KISSlicer's matl gcode tab, it automatically sets them back up appropriately as a tool is selected:
            *G10 P<EXT> S<TEMP> R<TEMP> ; S Active Temp, R standby temp
            M572 D<EXT> S0.045
            ; Retract Settings S Length, R Extra L
            ; F Feedrate, T Unretract Rate, Z Z-hop
            M207 S4 R0 F900 T900 Z0
            M98 P/macros/<EXT>_Config_T<EXT>_Trigger*
            This is my Start.g:
            *M84 ;Turn Motors off so tool change scripts are not exectued when initializing temps
            M140 S85
            G10 P0 S0 R0
            T0
            M207 S0 R0 F1980 T1980 Z0
            G10 P1 S0 R0
            T1
            G10 P2 S0 R0
            T2
            G10 P3 S0 R0
            T3
            T-1
            ;Disable the filament out triggers
            M591 D0 P0
            M591 D1 P0
            M591 D2 P0
            M591 D3 P0
            ;Reset the Flowrate Multipliers to 100% for all drives
            M221 D0 S100
            M221 D1 S100
            M221 D2 S100
            M221 D3 S100
            M220 S100 ;Reset Speed Multiplier to 100%
            M98 P/macros/High_Quality_Mode ; Set quality mode
            M42 P7 S255 ; Turn on Vacuum Pump*
            Duet Ethernet - Most likely the most recent Edge firmware
            Duet X5
            7" Panel Due V2
            Cartesian, 4 Nozzles with Flex3Drives, Heated Chamber, Simple Switch Filament Sensing
              @bmmal said in New firmware 2.0RC5 available:
              Thanks. I found a possible problem with configuring/deconfiguring filament monitors while a print is active. I believe I have fixed it. However, I advise against deleting filament monitors (or changing their type in other ways) once they have been configured. Instead, I suggest you use the M591 S parameter to enable or disable the filament monitor.
              Can you explain what problems you were getting before, i.e. what you mean by "to make sure there are not any from a previous print" ?
              undefined 1 Reply Last reply 29 May 2018, 13:44 Reply Quote 0
                dc42 administrators @DocTrucker
                @doctrucker said in New firmware 2.0RC5 available:
                That's correct, DWC doesn't support it yet (neither does PanelDue).
                undefined 1 Reply Last reply 28 May 2018, 20:08 Reply Quote 0
                  dc42 administrators @zerspaner_gerd
                  M502 used to just reset those configuration parameters that are overridden in config-override.g (if you have it). Following complaints that this doesn't match the behaviour of other firmwares, it now resets the machine by running config.g but not config-override.g. Therefore it redefines the tools - which means deleting the original definitions. That's why all the tool heaters are turned off.
                  Where are you running M502, and why?
                  undefined 1 Reply Last reply 28 May 2018, 23:46 Reply Quote 0
                    DocTrucker @dc42
                    @dc42 In that case the append is working as intended! Very useful with the network drops. There are issues I know I need to wirk on at som point for the latter.
                      zerspaner_gerd @dc42
                      If you choose "Change Filament" via DWC, this error occurs:
                      Error: M701: Unload the current filament before you attempt to load another one
                      Filament loading is then no longer possible via DWC.
                      @dc42 said in New firmware 2.0RC5 available:
                      for example loading the filament, I set the acceleration smaller here.
                      And I was hoping that I can do this with M502 resets without deposit anywhere fixed values.
                      undefined 1 Reply Last reply 29 May 2018, 07:08 Reply Quote 0
                        Just to be clear: you are getting that error only if you run M502. Correct?
                        When you create a tool (for example because you run M502, which will recreate all the tools), if the tool uses exactly one extruder, the code looks to see if there is already a filament assigned to that extruder, and if so then it flags the tool as using that filament. That appears to me to be sensible behaviour. If you disagree, please explain why.
                          BMMal @dc42
                          @dc42 For some reason I didn't realize the S parameter enabled or disabled them. I'll switch things over. I was basically trying to disable them all at the beginning so that only the ones needed for a print would be enabled and I didn't have to have material loaded in an unused extruder.
                          Duet X5
                          7" Panel Due V2
                          undefined 1 Reply Last reply 29 May 2018, 17:22 Reply Quote 0
                            Nuffe @dc42
                            I have strange heater erros with RC5. But I have brand new 24V heater unit so it could be that too. The heater is calibrated, and after the calibration it have had problems maintaining the temperature.
                            But in any case these heater errors look strange, there might be some bug there. See that decreasing expected temperature raise limit after each fault.
                            undefined 1 Reply Last reply 29 May 2018, 17:26 Reply Quote 0
                              dc42 administrators @BMMal
                              The S parameter wasn't supported on filament monitor types 0 and 1, but in 2.0RC6 it is.
                                dc42 administrators @Nuffe
                                @nuffe said in New firmware 2.0RC5 available:
                                That error message normally means that the heater hasn't been tuned. Did you save the calibration values from tuning:
                                • Either by sending M500, if your config.g file is set up to invoke config-override.g using M501;
                                • Or by editing the results of tuning into a M307 command in config.g and making sure there isn't another M307 command for that heater in config-override.g?
                                  I have just released firmware 2.0RC6 so I am closing this thread and starting a new one. Those of you who have outstanding issues with RC5, please test again using RC6 and report any issues that are still present in that thread.
                                  82 out of 88
