    New DuetWiFiFirmware 1.14
    Firmware installation
    2.0k
      I have just released new firmware at https://github.com/dc42/RepRapFirmware/blob/dev/Release/DuetWiFiFirmware-1.14.bin (follow the link and press Raw to download it). The changes in this release since 1.13b are:
      • Fix for uncommanded stepper motor movement on some systems following a software reset
      • When multiple motors are due to step, generate simultaneous step pulses for all of them
      • Added support for multiple drivers for a single axis (M584)
      • Added support for extended step pulse width when using external drivers (T parameter on M569 command)
      • Removed XYZE params from M569 (use M584 instead)
      • Added M913 command (set motor % of normal current) to allow motor current to be temporarily reduced
      • Added Z probe type 5, which is a normally-closed switch or active-high 3.3V digital signal connected to the IN pin of the Z probe connector
      • Duet WiFi default Z probe threshold is now 500 (the recommende dvalue for most types of Z probe)
      • Duet WiFi defaults to using a low end homing switch on the X axis (Ormerod and Huxley, users take note!)
      The other firmware files (DuetWiFiServer.bin and DuetWebControl.bin) are unchanged.
      • curieosundefined
        curieos
        I finally got things hooked up today and I was on 1.13b and updated the config file and it did the crazy dance. This update fixed it, great job DC. Also nice to see the other cool improvements.
        She/Her
        I work at a local 3D printing shop.
        Printers: Micron+ w/Duet 3 Mini, in-progress adaptation of the Jubilee REL onto an E3D MS, Prusa i3 MK3S.
        • jerry426undefined
          jerry426
          David,
          Thanks! The crazy dance after software reset is fixed for me too!
          • Huguesundefined
            Hugues
            Also for me ! Great !
            • Huguesundefined
              Hugues
              I noticed today a deconexion of few second after pushing the emergency stop. I didn't notice this with the previous version but i can be wrong…
              • RichRap3Dundefined
                RichRap3D
                @cubexupgrade:
                I had that on the original / previous version. I just assumed that it was reasonable to expect a disconnect after an emergency stop.
                  RichRap3D
                  For some reason I didn't have the iap4e.bin file in /sys
                  So the automatic firmware update failed with the message -
                  17:10:54Error: In-application programming binary "iap4e.bin" not found
                  17:10:53M997
                  Can't rename file or directory /sys/DuetWiFiFirmware-1.14.bin to /sys/DuetWiFiFirmware.bin
                  So I manually copied the new firmware to the /sys and added the missing iap4e.bin
                  Then booted and ran the command M997 S0
                  And it all updated perfectly !
                  The axis wiggle has gone, I'm testing the rest now.
                  Cheers,
                  Rich.
                    @cubexupgrade:
                    This is a known issue, see https://duet3d.com/wiki/Pre-production_hardware_limitations_and_known_firmware_issues. The reason is that DuetWebControl doesn't yet allow for the fact that after a reboot, the networking on the Duet WiFi takes longer to connect than on the Duet, because it has to establish a connection with the access point.
                      @RichRap3D:
                      17:10:53M997
                      Cheers,
                      Rich.
                      Thanks, Rich. I've asked T3P3 to check the contents of the SD card image they use for SD cards sent with the Duet WiFi.
