    Weird Z behavior with first attempt with RTOS firmware on Delta
    Firmware installation
    • JohnOCFIIundefined
      JohnOCFII
      Greetings All,
      I finally upgraded my DuetWiFi today after not using it since early May. I upgraded from the release version of 1.21 to the current Beta:
      Firmware Name:			RepRapFirmware for Duet 2 WiFi/Ethernet
      Firmware Electronics:	Duet WiFi 1.0 or 1.01
      Firmware Version:		2.01beta1(RTOS) (2018-06-23b1)
      WiFi Server Version:	1.21
      Web Interface Version:	1.21.2-b1
      I've tested each access, the endstops, the fans, and the heaters. All seem to work OK, but when I use the Machine Control tab to try to move X, Y, or Z, the corresponding carriages move, but I was expecting Z to move the effector up and down, X to move left and right, Y to move forward and back. It is acting as if it does not know it is a Delta.
      This is a T3P3 Kossel Mini V3-based machine.
      I'm pretty sure whatever I am doing is user error. Please help this user see the error of his ways. 🙂
      Here is my config.g
      ; Configuration file for Duet WiFi (firmware version 1.20 or newer) - Edited 27 Apr 2018 - osh
      ; generated by RepRapFirmware Configuration Tool on Tue Jan 02 2018 16:25:12 GMT-0600 (CST)
      M111 S0                                            ; Debugging off
      G21                                                ; Work in millimetres
      G90                                                ; Send absolute coordinates...
      M83                                                ; ...but relative extruder moves
      M555 P2                                            ; Set firmware compatibility to look like Marlin
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Configure automatic saving on power loss
      ; *** The homed height is deliberately set too high in the following - you will adjust it during calibration.
      ; Set delta radius, diagonal rod length, printable radius and homed height
      ; M665 R105.6 L215.0 B85 H250                      ; default M665 form T3P3 Kossel Mini
      M665 R87.290 L215.15 B85.0 H222.600 X-0.135 Y-0.180 Z0.00
      M666 X-0.11 Y0.35 Z-0.33                            ; Put your endstop adjustments here
      M208 Z-0.1 S1                                      ; Set minimum Z
      M574 X2 Y2 Z2 S1                                   ; Set active high endstops
      M558 P1 H8 F120 T2400                              ; Set Z probe type to unmodulated and the dive height + speeds
      ;                                                  ; Tip: A larger trigger height in G31 moves you CLOSER to the bed
      G31 P500 X0 Y-11 Z0.235                            ; Set Z probe trigger value, offset and trigger height
      ; G31 P500 X0 Y-11 Z0.240                          ; Starting Point Feb 4 2018
      M557 R75 S20                                       ; Define mesh grid
      M569 P0 S1                                         ; Drive 0 goes forwards
      M569 P1 S1                                         ; Drive 1 goes forwards
      M569 P2 S1                                         ; Drive 2 goes forwards
      M569 P3 S1                                         ; Drive 3 goes forwards
      M350 X16 Y16 Z16 E16 I0                            ; Configure microstepping without interpolation
      M92 X80 Y80 Z80 E402                               ; Set steps per mm - osh - re-set from 404 to 425 now to 402 4/14/2018
      M566 X1200 Y1200 Z1200 E1200                       ; Set maximum instantaneous speed changes (mm/min)
      M203 X18000 Y18000 Z18000 E1200                    ; Set maximum speeds (mm/min)
      ; M201 X1000 Y1000 Z1000 E1000                       ; Set accelerations (mm/s^2) - default
      M201 X1750 Y1750 Z1750 E1500                       ; Set accelerations (mm/s^2) - test 2/25/2018
      M906 X1000 Y1000 Z1000 E800 I40                    ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30                                            ; Set idle timeout
      M305 P0 T100000 B3950 C0 R4700                     ; Set thermistor + ADC parameters for heater 0
      M143 H0 S120                                       ; Set temperature limit for heater 0 to 120C
      M305 P1 T100000 B4388 C0 R4700                     ; Set thermistor + ADC parameters for heater 1
      M143 H1 S280                                       ; Set temperature limit for heater 1 to 280C
      M563 P0 D0 H1                                      ; Define tool 0
      G10 P0 X0 Y0 Z0                                    ; Set tool 0 axis offsets
      G10 P0 R0 S0                                       ; Set initial tool 0 active and standby temperatures to 0C
      M550 PCharlotte3D                                  ; Set machine name
      M552 S1                                            ; Enable network
      M586 P0 S1                                         ; Enable HTTP
      M586 P1 S0                                         ; Disable FTP
      M586 P2 S0                                         ; Disable Telnet
      M106 P0 S0 I0 F500 H-1                             ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H1 T45                          ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S1 I0 F500 H1 T45                          ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M579 X0.998 Y0.993  ; adjusted based on 100mm XY square - 2/12/2018 - osh
      T0                                                 ; Select first tool
      • autschundefined
        autsch
        I had the same problem. Downgrade the web interface (www content) and it's working again. Problem is the Java Script in the Web Interface.
        JohnOCFIIundefined 1 Reply Last reply Reply Quote 0
          JohnOCFII @autsch
          @autsch I will try that - thank you!
            JohnOCFII
            As @autsch suggested, reverting from 1.21.2-b1 to 1.21.1 for the web interface fixed my issue.
            I really appreciate that help. I did not think the DWC would have caused an issue like that!
            • autschundefined
              autsch
              Shit happens, John 😉
              Btw: New Version is out and working
              https://github.com/chrishamm/DuetWebControl/blob/dev/DuetWebControl-1.21.2-b2.zip
