    FTS Tracking system from Sparklab
    Filament Monitor
    • KevinOundefined
      KevinO
      i have two questions about the compabilty wit the Duet Wifi board.
      the first question is, is the FTS System from Sparklab campatible with the DUet3D? its an magnetig filament monitor wich controlls the jam and the runout.
      FEED Sensor
      so the other question is, is it possible to get an notification via Email or SMS if there is a jam or a filament runout detected via this sensor?
      thanks a lot 🙂
        dc42 administrators @KevinO
        @kevino said in FTS Tracking system from Sparklab:
        FEED Sensor
        I can't answer that without a specification of the output from the sensor.
        Not yet, but adding a notification facility is on the firmware wish list.
        • KevinOundefined
          KevinO
          what do you mean with the outputs?
          for me it looks like the same as the magnetic filament sensor from you...
          it works with an rotating magnet and an Hall-E endstop
            If it is 3.3V-compatible and produces pulses as the filament passes through it, then it should work if you configure it as a "pulse generating sensor" using M591.
