    Excessive number of disconnections
    Firmware installation
    740
    • appjawsundefined
      appjaws
      Firmware 2.01(RTOS) (2018-07-26b2) Web 1.21.2-dc42
      I am experiencing a large number of time outs.
      I am also running a Duet 6 with a laser and that is experiencing time outs as well
      The results of M122 for the core XYUV printer
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.01(RTOS) running on Duet Ethernet 1.02 or later + DueX5
      Board ID: 08DGM-956GU-DJMSJ-6J9F6-3S86T-9BPVH
      Used output buffers: 3 of 20 (12 max)
      Static ram: 28476
      Dynamic ram: 95968 of which 0 recycled
      Exception stack ram used: 620
      Never used ram: 6008
      Tasks: NETWORK(ready,328) HEAT(blocked,1248) MAIN(running,3132)
      Owned mutexes:
      Last reset 02:23:32 ago, cause: power up
      Last software reset at 2018-07-27 11:42, reason: User, spinning module GCodes, available RAM 6008 bytes (slot 2)
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
      Error status: 0
      Free file entries: 10
      SD card 0 detected, interface speed: 12.0MBytes/sec
      SD card longest block write time: 18.3ms, max retries 0
      MCU temperature: min 38.9, current 56.9, max 59.4
      Supply voltage: min 24.1, current 24.8, max 25.2, under voltage events: 0, over voltage events: 0
      Driver 0: standstill, SG min/max 0/239
      Driver 1: standstill, SG min/max 0/213
      Driver 2: standstill, SG min/max 0/1023
      Driver 3: standstill, SG min/max 0/162
      Driver 4: standstill, SG min/max 0/158
      Driver 5: standstill, SG min/max not available
      Driver 6: standstill, SG min/max 0/0
      Driver 7: standstill, SG min/max 0/126
      Driver 8: standstill, SG min/max 0/127
      Driver 9: standstill, SG min/max 0/131
      Expansion motor(s) stall indication: yes
      Date/time: 2018-08-03 13:02:31
      Slowest loop: 70.04ms; fastest: 0.07ms
      Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 120, MaxWait: 978601ms, Underruns: 3, 0
      Bed compensation in use: none
      Bed probe heights: 0.185 0.153 0.171 0.000 0.000
      Heater 0 is on, I-accum = 0.0
      Heater 1 is on, I-accum = 0.3
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 96.86ms; fastest: 0.02ms
      HTTP sessions: 1 of 8
      Interface state: 5
      === Expansion ===
      DueX I2C errors 0
      appjaws - Core XYUV Duet Ethernet Duex5
      firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
      Ormerod 1-converted to laser engraver, Duet wifi
      OpenSCAD version 2024.03.18
      Simplify3D 5.1.2
        Have you made sure that your two Duets are not both using the same MAC address? The Duet Ethernet will create one from the board ID if you don't have a M540 command to define the MAC address in config.g.
        • appjawsundefined
          appjaws
          Yes one mac ends in EE and the other ends in ED.
          Just to be sue I have just commented out the M54 line in the Due Ethernet board.
          I'll do some more testing
          Simplify3D 5.1.2
            Another possibility is an IP address conflict with something else on your LAN.
            • appjawsundefined
              appjaws
              No I have checked that, I use fixed ip addresses for my machines.
              I'll keep an eye on the issue and see if I can provide more information.
              Simplify3D 5.1.2
              • appjawsundefined
                appjaws
                I only have the laser on today (ormerod- Duet 6), I started a print and the next time I looked at the screen, less than 1 minuet the machine had been disconnected.
                RepRapFirmware for Duet version 1.22 running on Duet 0.6
                Used output buffers: 3 of 16 (9 max)
                === System ===
                Static ram: 44652
                Dynamic ram: 41436 of which 4024 recycled
                Stack ram used: 136 current, 6020 maximum
                Never used ram: 2172
                Last reset 00:05:30 ago, cause: power up
                Last software reset at 2018-08-03 12:50, reason: User, spinning module GCodes, available RAM 1836 bytes (slot 2)
                Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0xffffffff
                Error status: 8
                Free file entries: 9
                SD card 0 detected, interface speed: 21.0MBytes/sec
                MCU temperature: min 27.9, current 41.1, max 45.0
                Date/time: 2018-08-04 12:10:09
                Slowest loop: 245.69ms; fastest: 0.09ms
                Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 88, MinFreeDm: 79, MaxWait: 30493ms, Underruns: 33793, 0
                Scheduled moves: 47007, completed moves: 46997
                Bed heaters = 0, chamberHeaters = -1 -1
                Segments left: 1
                file is doing "G1 X10 Y19.7" in state(s) 0
                Code queue is not empty:
                Queued 'M106 S83.1' for move 46997
                Queued 'M106 S81' for move 46998
                Queued 'M106 S80.5' for move 46999
                Queued 'M106 S80.8' for move 47000
                Queued 'M106 S82.8' for move 47001
                Queued 'M106 S81' for move 47002
                Queued 'M106 S79' for move 47003
                Queued 'M106 S80' for move 47004
                Queued 'M106 S80.3' for move 47005
                Queued 'M106 S79' for move 47006
                Queued 'M106 S0' for move 47006
                11 of 16 codes have been queued.
                === Network ===
                Free connections: 15 of 16
                Free transactions: 23 of 24
                Locked: 0, state: 4, listening: 20071c20, 0, 0
                Simplify3D 5.1.2
                  Disconnections between DWC and a Duet when using Ethernet are rare. The most likely reasons are:
                  • MAC address conflict
                  • IP address conflict (your router could be allocating an IP address that you are using for a Duet to a wireless device)
                  • Faulty cable
                  • Some older Duet 06/085 boards occasionally had poor soldering of the PHY chip to the PCB, which could lead to intermittent connection
                    -Using older firmware versions with microstepping that is too high for the CPU to manage, in particukar when homing the printer. In those older versions this could cause the network system to be starved of CPU cycles. The clue was that the MaxReps figure in the M122 report got very high.
                  I am assuming that the reason for disconnection given by DWC is Timeout. If you are getting a different message, please post it here.
                  appjawsundefined 1 Reply Last reply Reply Quote 0
                  • appjawsundefined
                    appjaws @dc42
                    @dc42 Yes the disconnections are due to Timeout.
                    I have noticed that I do not have a M350 Set micro stepping entry in config. So the default must be used which I believe is 16x. I have now made the entry just in case.
                    Simplify3D 5.1.2
