[Solved] Duet 2 wifi Java error
I have installed a new Duet 2 wifi of a Chinese Prusa i3 clone. Everything was working fine except for G29 homing which I was working on, after editing config.g to redefine the grid pattern, the Duet dropped the wifi link and on restart the extruder heater had vanished from the screen on both the pc and Paneldue and the bed heater displayed an incorrect temperature (2000 degrees).
I have checked all thermistors and heaters for continuity and all check out ok
I have reinstalled the the latest RepRap and WebControl Firmware to no effect.
I have tried resetting the board
The test heater macro brings up three heaters, all current temperature are n/a the tool fan also starts up at 35% and an Error Screen displaying the following:A JavaScript error has occurred so the web interface has closed the connection to your board. It is recommended to reload the web interface now. If this happens again, please contact the author and share this error message:
Version: 1.22.4-b1
Message: TypeError: getTool(...) is undefined
URL: http://192.168.1.5/js/dwc.js
Line: 9406:16
Error object {}I'm at a loss as to how to proceed, other than erase the memory and start again which I'm happy to do but need to know the exact procedure ( Is teh Erase jumper bridged with the board powered up?)
All help will be greatly appreciated, thanks in advance
@crazyjane Some further information:
The Duet 2 control panel LED status is as follows:
LED E1 Heat - Off
LED E0 HEAT - Off
LED VIN - On
LED +5V - On
LED +3.3V - On/ -
Wow!!! After countless edits and reloads of config.g everything suddenly miraculously returned to normal.
I'm delighted to be back in action but concerned that there is some intermittent glitch in my setup, so I'd still welcome other opinions, comments and advice! -
Did you upgrade the main firmware, or Duet Web Control? The version of Duet web Control you were running was a beta.
Firmware Upgrades as follows:
RepRap:
https://github.com/dc42/RepRapFirmware/releases/download/2.02RC4/Duet2CombinedFirmware.bin
Web Control:
https://github.com/dc42/RepRapFirmware/releases/download/2.02RC4/DuetWebControl-1.22.5.zip
PanelDue:
https://github.com/dc42/PanelDueFirmware/releases/download/1.22.1/PanelDue-5.0i-7.0i-nologo.bin -
Thanks. My guess is that you either hit a bug in the DWC beta that you were using before, or you were running incompatible versions of main firmware and DWC. I'm glad it's working for you now using the very latest releases.
Thanks for your reply, just to confirm, I had already upgraded the Firmware when the problem file, but I accept that it could have been caused by something that I did when I tried to save the config.g file. The error corrected itself after renaming the config.g.bak config.g
@crazyjane, do you still have the original config.g file that provoked the error?
@dc42, below is the config.g file I was using. I had changed the mesh pattern when the problem occurred:
; generated by RepRapFirmware Configuration Tool v2 on Wed Nov 14 2018 18:01:46 GMT+0000 (Greenwich Mean Time); General preferences
M83 ; ...but relative extruder moves; Network
M550 P"XXXXXX setup" ; Set machine name
M552 S1 ; Enable network
M587 S"vodafone-B51C" P"XXXXXXXX" ; Configure access point. You can delete this line once connected
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M569 P2 S0 ; Drive 2 goes forwards
M92 X80.00 Y80.00 Z462.43 E98.61 ; Set steps per mm
M566 X900.00 Y900.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; Set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z20.00 E250.00 ; Set accelerations (mm/s^2)
M906 X800.00 Y800.00 Z800.00 E800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
M208 X200 Y270 Z200 S0 ; Set axis maxima; Endstops
M574 X1 Y1 S0 ; Set active high endstops
M558 P5 X10 Y-50 Z1 H5 F120 T6000 ; Set Z probe type to switch, the axes for which it is used and the probe + travel speeds
G31 P50 X10 Y-50 Z-.13 ; Set Z probe trigger value, offset and trigger height
;M557 X30:260 Y30:250 S20 ; Define mesh grid; Z-Probe
M574 Z1 S2 ; Set endstops controlled by probe
M558 P5 H5 F1200 T6000 I1 ; Set Z probe type to modulated and the dive height + speeds
G31 P500 X10 Y-50 Z-.13 ; Set Z probe trigger value, offset and trigger height
M557 X15:12 Y15:195 S20 ; Define mesh grid
G29 S1; Heaters
M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit
M305 P0 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0
M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
M143 H1 S280 ; Set temperature limit for heater 1 to 280C; Fans
M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Automatic saving after power loss is not enabled
@crazyjane said in [Solved] Duet 2 wifi Java error:
Thanks. Looks like you accidentally set the upper X limit below the lower X limit. I'm guessing that the firmware doesn't do appropriate error handling in this situation. I will test it.
@dc42 oops, I didn't see that, obviously a typo while I was changing the Z trigger. That might be the cause of the problem, I would also point out that the problem was resolved after reflashing the PanelDue i7, could it have caused the issue?
Anyway, you will be glad to hear that everything is fine and the first job is running for the past 3 hours or so, and I cannot say how delighted I am at the quality of the print, streets ahead of the original MKS 8 bit board.
Thanks for all your help and interest, much appreciated -
I don't think that M557 line was the cause of the problem, because the error handling does seem to work properly:
m557 x15:12 y15:150 s20 Error: M557: bad grid definition: X range too small m557 Grid is not defined g29 Error: G29: No valid grid defined for bed probing It could be that after upgrading Duet Web Control, your browser still had old versions of some of the web files cached, and the mismatched files caused the problem. It's wise to clear the browser cache when upgrading DWC.
I'll do that in future!
