    CNC Coordinate Systems
    CNC
    8
    45
    7.0k
    • Danalundefined
      Danal
      Dave,
      I've checked G10 L2 and L20, using M408 S1 for response, on Release 1.21 (final), combined with various G1 and G0 moves. Everything appears to behave correctly in every scenario I could think of to test (I did not do a rigorous analysis of test cases).
      • Danalundefined
        Danal
        However…
        Per NIST standard documentation, work offsets are supposed to be persistent, including across reboots and power cycles. In the case of Duet3D/RepRap, they are not.
        In case you are wondering, persistence is an important feature for CNC machinists, because the various G55, G56, etc. are quite often used for "Fixtures" that are mounted to the CNC bed for extended periods of time (weeks or months). Having to "re-find" or "re-touch" fixtures every time the machine is reset would be quite contrary to the way people are accustomed to operating.
          I've added this to the list of thing to look into for the next firmware version.
          • Catalin_ROundefined
            Catalin_RO
            While agreeing on the advantages of persistent work offsets, I don't really miss it with Duet3D. One could write extremely simple one liners with the G10 L20 Pn codes. Having them stored as macros also simplifies usage a lot as those macros can have meaningful names, usually much better than a Post-It on the machine telling the operator that "G56 is for round fixture in right-rear corner"…
            As already mentioned in the other thread (https://www.duet3d.com/forum/thread.php?id=5006) I have re-connected the Duet3D to my WorkBee and did a lot of movement tests, including a camera for finding X/Y on workpiece and a movable tool finder for Z. I simply removed all predefined macros and added three of my own that do all the tricks.
            • Danalundefined
              Danal
              @Catalin_RO:
              While agreeing on the advantages of persistent work offsets, I don't really miss it with Duet3D. One could write extremely simple one liners with the G10 L20 Pn codes. Having them stored as macros also simplifies usage a lot as those macros can have meaningful names, usually much better than a Post-It on the machine telling the operator that "G56 is for round fixture in right-rear corner"….
              That works great if you are willing to transcribe coordinates into the macros. When I mount a fixture, and switch to G55 (or whatever), I then Z Probe it, and use an edge finder to touch the edges (usually the edges of the stock in the fixture, not the fixture itself).
              Anyway… Once the physical part is done, I hit the "Zero Work Coordinates" button and it is now "saved". No human errors copying long numbers from the DRO to the macro.
                What do you all think should be the mechanism for saving coordinate systems to the SD card?
                (a) Automatically save them whenever they are changed. This could result excessive wear on the SD card if they are changed frequently.
                (b) Save them whenever a job is paused.
                (c) Save them when you ask to save them explicitly, using M500 or a similar command.
                (d) Something else?
                mwintermundefined 1 Reply Last reply Reply Quote 0
                • Ryan Lockundefined
                  Ryan Lock
                  Option C would be best in my opinion. If a user wants the coordinate system to autosave, they can setup macros to send the command and then autosave.
                    Catalin_RO
                    Option C sounds best compromise to me as well!
                      Thanks, both of you. I'll add the workplace coordinate settings to the M500 saved parameters.
                      • Danalundefined
                        Danal @dc42
                        @dc42 said in CNC Coordinate Systems:
                        Fantastic!
                        I did not respond quickly enough... option (c) is indeed what I would have voted.
                          Ryan Lock
                          @dc42 Thanks for making them changes. I have tested it out and it all works as expected.
                          One other thing i have noticed is that when pausing a file, and then resuming it, the machine goes back to machine coordinates and forgets which work coordinate system it was in. The way to solve this is to select the work coordinate system at the start of the resume.g file. Selecting the work system through the g-code console while in pause mode doesn't work, it has to be set in resume.g as far as i can see.
                          The effect of this is that the pause button can only practically be used in one coordinate system. As to use it in the others would require the resume file to be changed to select the correct one before resuming.
                          I am sure that before i upgraded the Duet to the latest firmware version it used to remember the work coordinate system when paused.
                          Ryan
                            dc42 administrators @Ryan Lock
                            @ryan-lock said in CNC Coordinate Systems:
                            I am surprised by that, because I don't recall making any changes in that area. In fact, I expect the pause.g and resume.g files to use the current workplace coordinates, which of course means that you would probably need to use G53 before all the movement commands in those files except for any G1 R1 moves at the end of resume.g. Anyway, I'll test it before I do another 2.02RC.
                            PS - are you sure that you don't have any commands in pause.g that reset the coordinate offsets to zero?
                            • resamundefined
                              resam
                              sounds like the same problem I reported here: https://forum.duet3d.com/topic/7940/firmware-2-02rc5-now-available/7
                              @dc42 in RRF, when you call resume.g to run DoFileMacro, there is this line:
                              gb.MachineState().useMachineCoordinatesSticky = true; // running a system macro e.g. homing or tool change, so don't use workplace coordinates
                              Not sure if thats the actual problem - but something to know about.
                              Related question: is pause+resume aware of "relative positioning" and "relative extrusion" and does it reset the correct state as it was before pausing? While paused the user could have changed it to move around...
                                Thanks @resam, that explains it. I now remember making that change so that homing wouldn't be messed up by workplace coordinates.
                                • To fix it, I think I could change it so as not to apply that sticky G53 in the case of running resume.g. That would mean that if resume.g does any moves apart from ones to restore the original position (e.g. wiping the nozzle on a FDM printer), they would need to be prefixed by G53. Does that sound a reasonable solution?
                                • An alternative would be to record all restore point coordinates in machine coordinates, and to use machine coordinates always when the R parameter is used on a G1 command.
                                In answer to your other question, whenever a macro file is run the relative/absolute movement and extrusion states are remembered at the start and restored at the end.
                                • resamundefined
                                  resam
                                  I don't really know what G53 and G54 do - and I don't think I want to bother with them in a 3d-printing task (I guess I can only speak for 3d-printing use cases, as I don't run CNC-style jobs). Most people I believe already have difficulties with G90/G91.
                                  In my case, I just want to move the head to to a parking position during pause, and move back to the last position on resume.
                                  I wasn't even aware that RRF already provides this hard-coded - I assumed it has to be specified in resume.g - thats also what the examples did, so I copied it. I will try to remove my G1 R1 ... commands from my resume.g at let the firmware do it.
                                    This is getting complicated. Currently there is an inconsistency in how tool offsets, workplace coordinate offsets (which includes M206 offsets) and Z-hop offsets are applied to restore points. So I'm trying to find a unified scheme for handling restore point coordinates.
                                    What I think is required is:
                                    1. When moving to a restore point (using the G1 R parameter), tool offsets are taken into account. This means you can create a restore point, switch tool, then send the new tool to the same point even if it has a different offset. This is needed e.g. when switching between extruders on a dual extruder FDM printer.
                                    2. When moving to a restore point at the end of resume.g, the same workplace coordinate offsets that were in effect when the restore point was created should be applied, even though workplace coordinates are not normally applied when running resume.g.
                                    3. So this begs the question: suppose you create a restore point (G60), do something, change to a different workplate coordinate system or change the offsets of the current one, then use G1 R1 to go back to the restore point. Should it go to the same machine position as before, assuming that there has been no change to the tool offset? Or should it go to the same user position, which will be a different machine position if the workplace coordinate offsets have changed?
                                    The NIST standard doesn't define G60, so no help there.
                                    Currently I am considering storing the user coordinates offset by the current workplace offsets in the restore point. This would mean that in case#3, the point in space that the tool moves back to would be unaffected by changes to the workplace coordinate system since the restore point was created. I think that's safe and sensible, although it would preclude the use of a restore point to save position, change workplace coordinates as part of a step-and-repeat operation, and then use G1 R1 to move to the corresponding position in the new coordinate system.
                                    • Danalundefined
                                      Danal
                                      I believe the answer to all scenarios is "consider the control point":
                                      The control point is the "tip" of the tool. All work coordinate offsets, too lengths, etc, contribute to that.
                                      There are ONLY two exceptions, that I'm aware of:
                                      1. Hardware home. This ignores the control point and offsets completely. Axis "hit" something (switch, stall, etc). Control point literally "n/a" during this operation.
                                      2. Tool change. For pragmatic reasons of "tool holders", it also ignores many types of offset. Note that the NIST standard is very unclear about how this really works, but many big CNC makers are quite clear in their documentation: No offsets active.
                                      Those two cases aside, EVERYTHING should result in putting the "Control Point" in the "correct" position.
                                      I realize that's a very 'soft' description... but... with some thought applied to it, it does seem to be a very useful way to validate or invalidate scenarios.
                                        dc42 administrators @Danal
                                        @danal, thanks for your response. However, I'm not clear what is the "correct" position in the case that you save a position using G60, then maybe change workplace coordinate offsets, maybe change tool to one with different offsets, then use G1 R to restore the position.
                                        Is the "correct" position for the (new) control point the same physical position as that of the (old) control point when G60 was executed? If so then I think my approach of storing restore point coordinates as user coordinates with the workplace offsets removed is suitable. That way, in determining the machine position to restore the tool head to, changed tool offsets would affect that machine position but changed workplace coordinates would not.
                                        • botundefined
                                          bot @dc42
                                          Is the "correct" position for the (new) control point the same physical position as that of the (old) control point when G60 was executed? [...]
                                          If the user is changing the WCS, then the tool would presumably going to a different physical location relative to the work piece. This, of course, assumes that the origin of that different WCS is in fact in a different physical space. If the two WCS have the same origin, there would be no reason to change to the new WCS.
                                          Alternate WCS are used to perform the same operations, using the same gcode, on various work pieces all laid out at once on the table. Say you have 6 of the same part you want to perform machining operations on, and they are laid out on the machine table with 6 vises in a 2x3 configuration. You would set the origin for 6 different WCS to a specific corner on each of the 6 different work pieces. You can then load a gcode file, run it on one WCS, then switch to a new WCS to perform the same action on a different part. This way, the gcode file's coordinates don't change, but the physical location (coordinates in MCS) is changing due to selecting new WCS with differing origins.
                                          So, given that (sorry if I'm explaining things you are already aware of) if a user changes WCS during a pause, the tool is usually moving to a new physical location.
                                          *not actually a robot
                                          • Danalundefined
                                            Danal @bot
                                            @bot said in CNC Coordinate Systems:
                                            Correct, with a few caveats, see below.
                                            Agreed, this is one use case. Another is having 0,0 be the corner of a "fixture", even for a single machining operation. Another is to set 0,0,0 as you go, by using an "edge finder" (wiggler) and a Z-probe (often the bit itself in the CNC world, both the bit and the stock are often metal).
                                            In fact, setting "Z-Zero" with a probe operation is probably the most common use of Work Coordinate Systems. Even people who don't realize they are using a WCS when they probe... they really are. Remember, per NIST standard, the machine is ALWAYS in ONE of the Work Coordinate Systems. (Unless executing a line that has G53 on that line). So a probe that sets Z0 is ALWAYS setting the 'current' WCS.
                                            Agreed. Let's start examples without the Pause:
                                            G90 ;Absolute mode
                                            G54
                                            G1 X22.5 Y22.5 Z1
                                            G55
                                            G1 X22.5 Y22.5 Z1
                                            WILL produce a move on the last G1 (assuming G54 and G55 have different offsets)
                                            Whereas:
                                            G90
                                            G54
                                            G1 X22.5 Y22.5 Z1
                                            G54
                                            G1 X22.5 Y22.5 Z1
                                            Will not produce any motion.
                                            Now with a pause:
                                            G90
                                            G54
                                            G1 X22.5 Y22.5 Z1
                                            G60 S0
                                            G55
                                            M226   ; Pause
                                            [...user interaction... for clarity, no moves.]
                                            G1 R0
                                            Reading this, I would expect the machine to move to X22.5 Y22.5 Z1 in the new G55 coordinate space. on the last G1. A physical move will occur (assuming G54 and G55 are different offsets). Having the R0 should be exactly like specifying the X Y Z stored in 'slot 0'. G55 is in effect... so G55 should be in effect. 🙂
                                            Thoughts?
                                            Edit: Corrected a typo in my descriptions.
