    How did the firmware update evaporate from my board?
    Firmware installation
    4.2k
      dc42 administrators @NOVAprint
      @novaprint said in How did the firmware update evaporate from my board?:
      @dc42 This great advice, but I use a MAC is there a MAC procedure? I am sure that there is one but it has not been widely published. So the third options is of course a decent one, but man Apple was the largest company on the planet for a few weeks. I suspect that I need to figure the process out from that aspect which really is so much more of a challenge than I bargained for. Is there a fallback 3 that you know of for mac?
      Yes, there is a version of Bossa for Mac. What I don't know (because I don't have a Mac) is how you identify the correct USB port.
      Ignore messages from Pronterface saying the device isn't configured, it's probably assuming that it's talking to Marlin, and you may have Marlin emulation turned off. Use a terminal emulator instead.
      NOVAprintundefined 2 Replies Last reply Reply Quote 0
      • NOVAprintundefined
        NOVAprint @dc42
        @dc42 MACs have a terminal program that they come with as the standard MAC suite. The dev.tty command yields no information about any connected boards for me right now. It DID say that I hada USB connection and then there was none. This is so confounding.
          NOVAprint @dc42
          @dc42 As I said before I am no compuer expert, is it possible to use the lennox based SAM-BA version 2.17 using a raspberry Pi?
          • chrishammundefined
            chrishamm administrators @NOVAprint
            @novaprint On Mac OS X the Bossa port shows up as /dev/tty.usbmodem17101 or similar. This is what you'd have to specify in BOSSA (available here for Mac: https://github.com/shumatech/BOSSA/releases)
            The command to flash your DuetM would look like this: bossac --port=/dev/tty.usbmodem17101-b -U -e -w -v ./DuetMaestroFirmware.bin -R
            This should be run from a Terminal.
            Duet software engineer
              NOVAprint @chrishamm
              @chrishamm Thank you I will try those when I get home tonight.
                @chrishamm well, I tried to install the bossa, and the version newwest version would not work with my operating system. I used the 1.8 instead of the 1.9 and true to form the interface came up and I was going to start using it and the icon disappeared. I have reinstalled it a few too many times and the same result happens. I tried to use SAMBA on my raspberry pi and that did not work either. I need these things to work! Urgently.
                  NOVAprint
                  @chrishamm I will use a work PC to see if I can get a result that is workable.
                  meanwhile here is the report from 1.9.1 Process: bossa [1422]
                  Path: /Applications/BOSSA.app/Contents/MacOS/bossa
                  Identifier: ShumaTech.BOSSA
                  Version: ???
                  Code Type: X86-64 (Native)
                  Parent Process: ??? [1]
                  Responsible: bossa [1422]
                  User ID: 501
                  Date/Time: 2019-01-04 01:55:44.959 -0500
                  OS Version: Mac OS X 10.11.6 (15G20015)
                  Report Version: 11
                  Anonymous UUID: FE0F58C0-2AE9-1D6E-0E29-A2AAB01BF59E
                  Sleep/Wake UUID: F19B3E3D-7953-41D0-BF56-CE93B63DABCA
                  Time Awake Since Boot: 8100 seconds
                  Time Since Wake: 1700 seconds
                  System Integrity Protection: enabled
                  Crashed Thread: 0
                  Exception Type: EXC_BREAKPOINT (SIGTRAP)
                  Exception Codes: 0x0000000000000002, 0x0000000000000000
                  Exception Note: EXC_CORPSE_NOTIFY
                  Application Specific Information:
                  dyld: launch, loading dependent libraries
                  Dyld Error Message:
                  Library not loaded: /usr/local/opt/libpng/lib/libpng16.16.dylib
                  Referenced from: /Applications/BOSSA.app/Contents/MacOS/bossa
                  Reason: image not found
                  Binary Images:
                  0x7fff6386a000 - 0x7fff638a1a47 dyld (360.22) <C8E77F6D-CE86-3C5B-8576-2584A799B51E> /usr/lib/dyld
                  0x7fff8c6ed000 - 0x7fff8c6fbfff com.apple.opengl (12.1.0 - 12.1.0) <B9CE1265-6D68-3BE3-8345-90F9402F5DF3> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
                  0x7fff8e412000 - 0x7fff8e412fff com.apple.Carbon (154 - 157) <8F6ED602-5943-3E29-A793-BC331E2C183D> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
                  0x7fff8f233000 - 0x7fff8f233fff com.apple.Cocoa (6.11 - 22) <807787AB-D231-3F51-A99B-A9314623C571> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
                  0x7fff8f871000 - 0x7fff8fa17ff7 com.apple.audio.toolbox.AudioToolbox (1.13 - 1.13) <370E95BC-956C-3962-86CC-0A14CF6A0389> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
                  0x7fff9c5b4000 - 0x7fff9c5b5ffb libSystem.B.dylib (1226.10.1) <2CBB584D-A69C-36AA-A432-8E4E334EA589> /usr/lib/libSystem.B.dylib
                  0x7fff9ca27000 - 0x7fff9ca9cfff com.apple.framework.IOKit (2.0.2 - 1179.50.3) <80452F8B-D168-3848-A5F6-3CF96EBEDD5D> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
                  Model: MacBookPro8,2, BootROM MBP81.004F.B00, 4 processors, Intel Core i7, 2.2 GHz, 8 GB, SMC 1.69f3
                  Graphics: Intel HD Graphics 3000, Intel HD Graphics 3000, Built-In
                  Graphics: AMD Radeon HD 6750M, AMD Radeon HD 6750M, PCIe, 512 MB
                  Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1333 MHz, 0x859B, 0x435434473353313333394D2E43313646314B
                  Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1333 MHz, 0x859B, 0x435434473353313333394D2E43313646314B
                  AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xD6), Broadcom BCM43xx 1.0 (5.106.98.102.30)
                  Bluetooth: Version 4.4.6f2, 3 services, 18 devices, 1 incoming serial ports
                  Network Service: Wi-Fi, AirPort, en1
                  Serial ATA Device: Samsung SSD 850 EVO 500GB, 500.11 GB
                  Serial ATA Device: MATSHITADVD-R UJ-8A8
                  USB Device: USB 2.0 Bus
                  USB Device: FaceTime HD Camera (Built-in)
                  USB Device: Hub
                  USB Device: Apple Internal Keyboard / Trackpad
                  USB Device: BRCM2070 Hub
                  USB Device: Bluetooth USB Host Controller
                  USB Device: Hub
                  USB Device: IR Receiver
                  Thunderbolt Bus: MacBook Pro, Apple Inc., 25.1
                    To upload firmware to a Duet WiFi/Ethernet you can use Bossa 1.8 or 1.9, or SAMBA 2.16 or 2.17. To upload to a Maestro you need Bossa 1.9 (SAMBA would also work if you had a compatible processor/board definition for it).
                    NOVAprintundefined 3 Replies Last reply Reply Quote 0
                      NOVAprint
                      @dc42 Here we go so I am using Bassa, the 64 bit version as list, although my computer says it is a 32 bit version I go to write Duet2 combined firmware and it starts out, gets to around 18 percent and says that it has failed to write. the bossa window says that it is connected to ATSAM4S8. I clicked verify, and it would get to around 90 percent and then say that it was not able to complete and then just make sure that know how is boss, BOSSA says that if cannot connect after a few minutes. I reset the board. I did not see anything about moving the jumper back perhaps I need to do that. The board appeared after the reset was done.
                      aidarundefined 1 Reply Last reply Reply Quote 0
                        NOVAprint @dc42
                        @dc42 BOSSA direct quote FLASH COMMAND FAILED
                        I have tried to write to flash I tried to write in general, nothing works ojh BTW the BOSSA directions I seem to be missing if BOSSA works I am not sure how to make it work. Just to keep everyone on the same page this is the BOSSA 1.91
                          NOVAprint @dc42
                          @dc42 Even better I tried SAMBA and used the board code at91sam4e8-ek (invalid chip ID) and the com port that SAMBA came up with and the program said that it could not connect with the device. I used SAMBA 2.18 and also 2.17 just in case I was messing up. Down three days I a just not in a good place right now. Is it possible that the Maestro has a different designator for the board somehow? The first identifier on the SAMBA seemed to connect, but I did not try to use it. It seemed like that would mess things up even more.
                            NOVAprint @dc42
                            @dc42 I made a mistake and endorsed the at91sam484s8-ek and the SAMBA worked. Pronterface detects the board, but it will not actually talk to the Maestro, it says that it is connecting...., the board is detected, but that is just about it. Also the screen in terminal will not report anything back. maybe I will go to the fallback two and see if I can get it to actually work, but I do not have the IP number. Fallback two did not work either.
                            • aidarundefined
                              aidar @NOVAprint
                              @novaprint Duet combined firmware is for DuetWifi/DuetEthernet board. As you have Maestro you should use DuetMaestroFirmware.bin
                                Can you confirm that the firmware you flashed was DuetMaestroFirmware.bin? In SAMBA, after writing it did you compare/verify it?
                                  NOVAprint @dc42
                                  @dc42 Was that the right thing to do the identifier? WAs that an actual mistake or was I supposed to do that? I will compare right now.
                                    NOVAprint @dc42
                                    @dc42 Ok so, I loaded the wrong version of the software onto the at91sam4s8-ek. I used the duet maestro firmware and it works the firmware did not evaporate, but it really did give me a hell of a time I suspect that I tried to load teh combined firmware in the inital problem that presented as well. Lost three days because I read someowhere that it was recommneded that the combined be used, but if you have a Maestro, use the maestro bin, not anything else, until something changes.
                                      NOVAprint
                                      Now my motors are making more noise, is there a simple way to address that? more noise after the new firmware which of course should not be happening any ideas?
                                      patakopecekundefined 1 Reply Last reply Reply Quote 0
                                        At least this should be a one time operation. Now that you're up and running the firmware update for 2.02+ consists of uploading a single zip file to the settings>general page on the DWC.
                                        • patakopecekundefined
                                          patakopecek @NOVAprint
                                          @novaprint you propably had stealthchop on, so just turn it on again
                                          NOVAprintundefined 1 Reply Last reply Reply Quote 1
                                            NOVAprint @patakopecek
                                            @patakopecek I think that you may be right, how do I put stealth chop on again? I think that I went to this:
                                            M569 P0 S1 D3 F1 ; Drive 0 goes forwards,
                                            M569 P1 S1 D3 F1 ; Drive 1 goes forwards,
                                            M569 P2 S1 D3 F1 ; Drive 2 goes forwards,
                                            I think that the D3 now represents stealth chop, unless there is some other thing that i am missing.
