    RepRapFirmware 2.03beta1 available
    Firmware installation
    9
    21
    3.1k
      @boldnuts, thanks for reporting this. Unfortunately I won't be able to look into it until next week due to other commitments. So I suggest you revert to 2.02 for now.
      • insertnamehereundefined
        insertnamehere @boldnuts
        @boldnuts said in RepRapFirmware 2.03beta1 available:
        On my cartesian with 2 independent Z axis for bed leveling the numbers don't converge as they do with 2.02.
        19:56:12: : Leadscrew adjustments made: -3.296 -0.516, points used 2, deviation before 2.035 after 0.000
        19:55:35: M98 P""0:/macros/X Axis callibration"": Leadscrew adjustments made: -2.407 -0.295, points used 2, deviation before 1.458 after 0.000
        19:54:52: : Leadscrew adjustments made: -1.442 -0.159, points used 2, deviation before 0.868 after 0.000
        19:54:19: M98 P""0:/macros/X Axis callibration"": Leadscrew adjustments made: -0.568 0.256, points used 2, deviation before 0.288 after 0.000
        19:53:48: G28
        19:53:08: G28
        19:52:42: Connection established!
        19:52:42: Page Load complete!
        I have the same problem with bed levelling.
        With 2.03b1 the 2 independent Z axis levelling moves are divergent.
        Reverted back to 2.02 and levelling works correctly.
          dc42 administrators @insertnamehere
          @insertnamehere, thanks for confirming this fault.
          • garyd9undefined
            garyd9 @dc42
            RRF 2.03b1, WifiServer 1.23b1 Possible issue or regression with the new firmware (or the new wifiserver):
            I had to reboot all my access points this morning twice and afterwards I found that my duet/wifi (board 1.04) wasn't auto-reconnecting to the wifi. The PanelDue console display showed the first disconnect and reconnect, and then showed "lost connection, auto reconnecting" followed by "timeout trying to connect."
            I thought that newer versions would endlessly keep retrying to reconnect.
            After I used a macro that stops/starts the wifi module, it connected fine.
            I've attached a picture of the PanelDue console page after restarting the wifi module:
            • atfphotoundefined
              atfphoto
              Hello!
              Wow! I've been away for a bit but I came back today for some software updates and I noticed one line in the new firmware notes that grabbed me.
              "Support for additional towers on delta printers (up to 6 in total)"
              I spent many years on the road as an operator with the Skycam (Flying Camera on Wire System) for the Olympics, NFL, NBA, etc. and it's a four-point system with the four reels arranged in a square or rectangle all sending cable out to a camera spar (and a bunch of other stuff, blah blah).
              One reason I made my giant delta printer was it reminded me of a three-point Skycam.
              By creating the ability to use four or more towers/motors, you have opened up another use for the Duet 3D which is creating and controlling hardware for camera systems.
              Did I read the notes right? We can make delta systems with four motors and towers - "quad printers"?
              Thanks!
              A
              Monolith Delta Kossel - 1800mm x 700mm - Duet 3D Ethernet
                dc42 administrators @atfphoto
                Yes you could do that.
                atfphotoundefined 1 Reply Last reply Reply Quote 0
                • atfphotoundefined
                  atfphoto @dc42
                  @dc42 That is so exciting.
                  Another new project. Ha!
                  Will there eventually be some additional documentation on how to configure things?
                  If you have four motors for movement with a fifth for the extrusion head, will the "Machine Status" list the motors as numbers or how will that be visualized (Instead of X, Y, Z .. 1,2,3,4)?
                  Very exciting!
                  Thanks,
                  A
                    How to configure more than 3 towers is already documented, at the end of the wiki page on confguring RRF for a delta printer.
                    • atfphotoundefined
                      atfphoto
                      Thanks!
                      A
                      • john parkundefined
                        john park
                        Good. thanks.. ^
                        • gavatron3000undefined
                          gavatron3000
                          CoreXZ working as normal so far. Took a little bit to work out the matrix thing within M669 but working as expected. Also stall detection is working for me, had to increase the sensitivity of one of my additional axes which wasn't a problem. And no issues so far with the wifi server
