    Provisional firmware 1.16 work list
    Firmware wishlist
    10
    38
    6.0k
      @Adamfilip:
      Grid Leveling 🙂
      That is the headline item planned for 1.17.
      • iDeveloundefined
        iDevelo
        @dc42:
        Here is an update. The priority for release 1.16 is now support for the DueX2/DueX5, including support for dual X-carriages. The DueX5 is imminent but I have a major exhibition coming up in my other line of business (which is proving that safety-critical software is correct). So I need to alter the 1.16 feature list. Here is the original list, annotated with updates:
        • Change heater tuning method to work with unusually weak or strong heaters without having to change the P parameter deferred to 1.17
        • Support Steinhart-Hart C coefficient for thermistors deferred to 1.17
        • Allow any commands from different input sources to be executed concurrently as long as they use different resources deferred to 1.17
        • Make triggers execute immediately instead of waiting for macros etc. to complete first. Only one trigger will execute at a time, however trigger 0 will preempt any other trigger. deferred to 1.17
        • Support config-override.g file in conjunction with M500 and related commands deferred to 1.17
        • Stepper drivers beyond the first 5 will be assumed to be simple enable/step/direction drivers and not TMC2660, unless the DueX5 is detected already implemented in 1.15e
        • Relative option in G92 command (for baby stepping) deferred to 1.17
        • Investigate/fix "Temperature rising much more slowly than the expected 0.0C" heater fault message, and other unusual heater fault reports already fixed in 1.15e
        • Investigate/fix reports of incorrect behaviour when using small amounts of extruder pressure advance already fixed in 1.15e
        • Investigate/fix reports of Z probe type 4 not working can't reproduce this
        • Investigate/fix reported issue of print pausing at the corners of a print can't reproduce this
        New major items added:
        • DueX2 and DueX5 support
        • Support for two independent X-carriages
        A couple of new minor items (already implemented):
        • Support for bed tilt calibration on delta printers
        • Support for the S parameter in the G4 command
        And some more bug fixes that have already been done:
        • Generic messages (e.g. some error messages) were not sent to PanelDue in the correct format, so they were not displayed
        • When using an analog Z probe, probing sometimes terminated earlier than it should have done and this resulted in an incorrect Z position
        • If probing fails (either because the Z probe was triggered at the start of the probing move, or because it wasn't triggered before the end of the move), bed compensation or delta calibration was attempted anyway.
        I will have my printer ready for IDEX at the weekend. Anything I should be concerned or look out for?
          @iDevelo:
          Version 1.16alpha1 is already on GitHub. It supports the extra U axis that you need for IDEX, including configuring and homing it. I will probably commit beta2 tomorrow, which allows tool X axis mapping to be defined and reported, but not used yet. By the weekend I hope to have beta3 released with X axis mapping fully implemented.
          • iDeveloundefined
            iDevelo
            Thanks 🙂
              Version 1.16 beta 2 is out. New features in this release:
              • More work on supporting a variable number of axes
              • X axis mapping can be defined in the M563 command. This is not yet complete, so although the mapping is stored and reported to DWC, movement is not mapped yet.
              • The number of axes is reported to DWC and to PanelDue
              • Sending M307 A-1 C-1 D-1 disables the PID for a heater channel, allowing its pin and driver to be used for other purposes
              • Fan minimum speed support. You can set a minimum speed for a fan such that any request to use a lower speed other than zero selects the minimum speed instead. The default is 5% which is the lowest that works for me.
              • Fan blip support. When a fan is turned on, it is run at full power for a configurable blip time (default 0.1 seconds). This lets you use PWM values that are too low to get the fan moving but high enough to keep it moving.
              Along with this I have released version 1.15 of PanelDue firmware to support additional axes if they are configured - just U on the 4.3 inch panel, but U. V and W on the 5 and 7 inch panels.
              • Alex9779undefined
                Alex9779
                Thanks for the fan stuff, I just tried it out and it works flawlessly!
                • DjDemonDundefined
                  DjDemonD
                  How do you find time to do all this David when a lot of other firmwares have large teams and seem to move very slowly?
                  www.precisionpiezo.co.uk
                    Some things - like the fan blip - need little design effort and are quick and easy to implement. Other things - like IDEX and particularly grid-based bed compensation - need a lot more thought beforehand and care to get right, because there are important usability considerations and they interact with other existing or planned features
                    It helps that the Duet WiFi is a joint venture between my company and T3P3, giving me a get a share of the profit on Duet WiFi sales. So this is no longer just a spare-time activity for me.
                    Large teams sometimes slow down development too.
                      Version 1.16 beta 5 is out. New in this release:
                      • X axis mapping. This completes support for independent dual X carriages.
                      • The I1 parameter in M558 command is supported, allowing the Z probe reading to be inverted.
                      • Better error handling when Z probing fails.
                      • Commands such as M201 and M906 show the correct number of extruder values
                      • Bug fix: remapping the bed heater to another heater channel was supported in the M140 command but not in most other bed heater related commands.
                      Now I need to finish adding support for the DueX2 and DueX5 before I release 1.16.
                        Version 1.16 beta 10 is out. New in this release:
                        • Added DueX2/DueX5 support, including up to 10 drives, 8 heaters and 8 fans on the Duet WiFi. You will need DWC 1.13 if you want to use heater 7.
                        • Report expansion board type in electronics string (displayed by M115 and by DWC 1.13)
                        • Added Z probe type 6 (switch on E1 endstop connector)
                        • Support heater 6 on Duet 0.8.5 (untested and probably incomplete). You need to send a M307 H6 command with valid model parameters to enable heater 6, and Fan 1 will be disabled (they share the same control signal).
                        • Changed M42 pin numbering, see https://duet3d.com/wiki/Using_servos_and_controlling_unused_I/O_pins
                        • Added M280 servo support, see https://duet3d.com/wiki/Using_servos_and_controlling_unused_I/O_pins
                        • Allow separate firmware un-retract speed to be configured in M207
                        • Allow negative extra un-retraction in M207
                        • You can disable a fan by sending M106 P# I-1, then its control pin can be used as for general purpose output (M42) or a servo (M280). Caution: the polarity may not be what you expect.
                        • If you disable a heater using M307 H# A-1 C-1 D-1 then its control pin becomes available for general purpose output (M42) or a servo (M280).
                        • Removed support for Duet WiFi prototype 1 board
                        • Support expansion connector pin PB6 and use it by default for a cooling fan tacho input
