SD card issue
I was doing some rewiring on my delta and for some reason like a dummy i took out my sd card and then lost it. I have followed all the steps on th wiki several times and on M997 S0 i get[ SENDING:M997 S0
M997: Firmware binary "Duet2CombinedFirmware.bin" not found]
so then I run M21 and get [SENDING:M21
M21: Cannot mount SD card 0: code 13] -
M997 s0 is to update the firmware. But if you're just replacing the SD card you shouldn't need to do that.
The SD card not mounting is a problem though. What do you have the SD card formatted as?
FAT32 with no label
@mfoltz and the SD card mounts properly in your PC?
Is it inserted correctly?
Do you have another as card to test with?
just tried a different card. worked. thanks
