How to submit code changes for consideration
I modified the PanelDue firmware to have a "WiFi Settings" dialog that allows the user to enter the SSID and password for their network. When they press Enter the specified SSID and Password is embeded in a M587 command. The intent is to make it easier for an end user to configure the WiFi settings of the DuetWiFi.
I would like to submit these changes for consideration to be added to the root code.
How do I go about doing this?
Thanks,
Mike -
Your best bet is to submit a pull request at
https://github.com/dc42/PanelDueFirmware -
The Pull request button is disabled. I suspect since I do not have write access? Or maybe I need to make a branch first?
I made progress. Should I create a fork and upload to the fork?
I think I submitted a pull request. It would be from MichaelM4.
Thanks, I'll take a look at it when I start work on the next major PanelDueFirmware release.
Did you find and look over the code changes I submitted?
Thanks,
Mike -
I'm sorry, I can't see your pull request at https://github.com/dc42/PanelDueFirmware/pulls.
I must have done it wrong. You can see the code here
