dwc broken after 2.02 upgrade
Duet Web Control
    Sir printsalot
    Can't connect after 2.02 firmware upgrade through dwc. no theres no usb communication despite the win driver being install. dwc opens but won't connect with no error. just says connecting forever. I pulled sd card and checked config.g for network info. It's correct. router shows it's online. lights all look good. what now?
    it's ethernet.
      Does the Duet show up in the Device Manager when connected?
      Which lights are lit up when it's connected to USB?
      You may be able to go through the fall back procedures to get back up and running. https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Fallback_procedure_Num_1
      If you follow through on those, at what point does it fail?
      1 out of 2
