    New edge firmware 1.17dev8 (replaces 1.17dev7)
    Firmware wishlist
    5.0k
    • auserundefined
      auser
      Removed Duet WiFi prototype 1 build
      Please excuse my ignorance: does this impact the duetwifi beta boards?
        No, prototype 1 was for internal testing and only 2 boards were ever made.
          I just found a bug in 1.17dev7: after you have printed a file from SD card, you need to reset the printer before you can do any further movement. Will be fixed soon.
          • heathmancundefined
            heathmanc
            Maybe I don't know how to use this new feature, but I homed my printer, did an autocalibrate and put the settings in the config file, did a G29 and then reset the controller. I put the G29 S1 into my startup script, but when I went to print, everything was WAY skewed, like not even resembling the part.. So, at this point, I rehomed, autocalibrated, ran a G29, and the print the file without the G29 in the beginning of it, same result. What am I doing wrong? Grid is defined with M557 R70 S20.
            Charles
              Can you post the heightmap.csv file generated by a G29 that giving you bad results?
                heathmanc
                RepRapFirmware height map file v1 generated at 2016-11-08 16:06
                xmin,xmax,ymin,ymax,radius,spacing,xnum,ynum
                -60.00,60.10,-60.00,60.10,70.00,20.00,7,7
                0,0,0.119,0.070,0.194,0,0
                0,0.012,0.088,-0.040,0.056,0.037,0
                0.044,-0.005,-0.044,0.182,0.068,0.008,0.013
                0.037,-0.010,-0.007,0.140,0.025,-0.023,-0.007
                -0.018,-0.088,-0.057,0.138,0.036,-0.082,-0.181
                0,0.050,-0.087,-0.075,-0.006,-0.038,0
                0,0,-0.024,0.025,-0.049,0,0
                  I can't see anything wrong with your height map, although you have a couple of fairly large errors at y=-60 and X= +/- 20mm. What sort of skew are you getting?
                    heathmanc
                    I haven't let it print more than a couple of perimeters, it's pretty wild and I can't even make out what the part is.
                      Is it just the Z height that is behaving wildly, or X and Y as well?
                        OK, I think I found a problem that could explain what you are seeing. I suggest you roll back to dev6 until I have dev8 ready.
                          heathmanc
                          Ok, done! Glad I'm not completely crazy. The x and y are really skewed, z axis does some crazy things as well, especially when pausing the print.
                            I have just released 1.17dev8, which fixes the issues I introduced in 1.17. I don't anticipate making any more major changes before 1.17 release, just fixes for any new bugs.
                            • Adamfilipundefined
                              Adamfilip
                              Cant seem to get it working
                              Updated. restarted several times
                              "No valid grid defined for G29 bed probing" is error
                              this is in my config.g
                              M557 X20:260 Y0:240 S10 ; define a grid covering the XY area indicated with the specified grid spacing
                              Sending G29 to activate
                                Adamfilip
                                hmm when i increased Spacing from S10 to S20 it started working.
                                  With your original M557 command, you should get an error message saying that there are too many probe points - except if the M557 command is in config.g then you won't see the message.
                                    Adamfilip
                                    Ok.. What is the max limit of points?
                                    • Firebug24kundefined
                                      Firebug24k
                                      DC42, on my delta I don't use any XY offset for your IR probe when running G30 autocalibration and it works fine. When I run G29 grid levelling after, should I have entered an XY offset via G31 first or not? My probe is offset about -40mm in the Y direction.
                                        Adamfilip
                                        Grid leveling is working incredibly well. Never had such a good first layer over my entire bed.
                                        Thank you DC42
                                          I'm glad it's working well for you!
                                          The maximum number of points is currently 121 on the wired Duet and 441 on the Duet WiFi. However, the underlying grid is rectangular so when using a circular probing area the actual max number of points is about pi/4 times these values.
                                          You should configure the probe offset. During auto calibration the probe offset is ignored.
                                          • 32034undefined
                                            32034
                                            @dc42:
                                            You mean that G29 should have the same X Y Z offsets as G31 in config.g?
                                            If Z probe section in config.g looks like this,
                                            [c]; Z probe section
                                            M558 P1 X0 Y0 Z1 H3 F100 T5000 ; Smart IR Z probe, used for homing Z axis, dive height 3mm, probe speed 100mm/min, travel speed 5000mm/min
                                            G31 P500 X-60.0 Y0.0 Z1.30 ;Set the probe height and threshold
                                            [/c]
                                            then bed.g should look like this for Auto bed compensation?
                                            [c]; bed.g
                                            ; M561 ; clear any bed transform, otherwise homing may be at the wrong height
                                            G28 ; home the printer
                                            M557 X10:275 Y15:190 S25 ; define a grid covering the XY area indicated with 25mm grid spacing
                                            G29 X-60.0 Y0 Z1.30 ;probe levelling grid with prob offsets from config.g
                                            [/c]
                                            Edited. Removed .1 from G29
