PanelDue 7i blank screen after firmware update
Firmware installation
630
    Giblte535
    I bought a Duet3D version of the integrated PanelDue 7i back in February, and saw that newer firmware was available from DC42. I followed the instructions on David Crocker's Solutions blog, used the 1.9.1 Bossa program to burn version 1.23.2 firmware (a 164KB image named PanelDue-5.0i-7.0i.bin).
    It appears to have worked (Bossa writes and verifies the image successfully), but the screen is blank. The LCD's backlight is on, but the screen is dark. The Erase button does nothing when pressed or held. The reset button appears to reset the USB comms. It behaves the same whether it's on USB alone, connected to a Duet, or powered standalone from a bench supply.
    The Bossa program doesn't adapt to non-standard font size, and the UI is difficult to use as a result, so I tried Bossac at the latest release (1.7.0) but it fails on verify. Apparently, that's a known issue.
    I tried the two most current firmware releases, both logo and nologo.
    What else should I check?
    Is there a more correct way to update the firmware?
      DaveA
      The Erase button will erase the firmware you just loaded leaving you with no firmware installed.
      You should not need to press the erase button.
        Did you remember to check the Erase All, Boot To Flash, and Lock boxes when you flashed the firmware? Or used the equivalent command line options when running bossac.
        I've not heard of failing on verify being a "known issue". Verify certainly works in Bossa, I use it all the time. It would fail if you also checked Security.
        undefined 1 Reply Last reply 2 Jun 2019, 16:27 Reply Quote 0
          Giblte535
          That makes sense.
          I only press it as part of the firmware update though. It's part of Crocker's instructions.
            Giblte535 @dc42
            @dc42 Thanks. I did not check those boxes but will try that when I'm done typing. I followed the instructions to the letter with bossac, and I see no instructions for using the GUI on the blog, presumably because of the visual issues of the GUI.
            I'd MUCH rather use command line anyway.
            Thanks again.
              Giblte535
              That solved it. Thank you sir!
              undefined 1 Reply Last reply 2 Jun 2019, 16:42 Reply Quote 0
                Giblte535 @Giblte535
                @giblte535 Note for trying to use bossac:
                The -e option in the instructions will fail if the firmware was erased with the button.
                But here is what I was talking about with the bossac problem. Verify fails and the screen stays blank.
                $ ./bossac.exe --port=COM13 -w -v -b PanelDue-5.0i-7.0i.bin
                Atmel SMART device 0x289b09e0 found
                Write 168276 bytes to flash (329 pages)
                [==============================] 100% (329/329 pages)
                done in 4.156 seconds
                Verify 168276 bytes of flash
                Verify failed
                Page errors: 297
                Byte errors: 145433
                If I dig into the source and figure out why that is, I'll update this post. Thank you again!
                  Thanks. I wasn't aware that there were still issues with the GUI version of Bossa on certain monitors. I know there was an issue with version 1.8 on high dpi monitors, but I was told that version 1.9 fixed that.
                  2 out of 8
