    Any current gudies to firmware compilation under Linux?
    Firmware developers
    1.0k
      dc42 administrators @DocTrucker
      @doctrucker said in Any current gudies to firmware compilation under Linux?:
      Program "xtensa-lx106-elf-g++" not found in PATH
      You don't need to build the DuetWiFiSocketServer project, which is the one that uses that compiler, unless you want to connect an ESP module to add WiFi support. The SAME70XPLD board has Ethernet already.
      • DocTruckerundefined
        DocTrucker
        Ok, I get that but which bit of your build instructions did I miss to get that working for a standard Duet Wifi build?
        I've not started to try to compile or build yet, that was just a warning on eclipse as soon as the projects were opened.
          This bit: https://github.com/dc42/DuetWiFiSocketServer/blob/master/README.md. You don't need it to build RepRapFirmware, only if you want to build DuetWiFiServer.
            DocTrucker
            Thankyou.
              DocTrucker
              Ok, slow progress and I can see the missing pin definitions in Pins_SAME70xpld.h vs Pins_Duet3_V05.h starting around line 64 on the former, 73 on the latter.
              I am also seeing a lot of "type 'size_t' could not be resolved" errors. Any hints on getting shot of that so I can continue?
              Also when I right click on the RepRapFirmware project in the project explorer, select 'Build Configurations', I only see a SAME70XPLD. I don't see a *_RTOS. Is this just because the SAME70 post dates the introcduction of RTOS and so there was never an offering without? Where in the source is Eclipse getting all the data for these 'Build Configurtations'?
                DocTrucker
                Any links to general guides to the ReprapFirmware would also be appreciated.
                  All RRF3 builds are with RTOS. The build configurations are defined in the Eclipse project settings.
                    I have committed some changes to the Pins files for the SAME70XPLD configuration so that it builds. The pin table still needs to be filled in.
                      DocTrucker
                      Thanks. I've been through the schematic for the radds 1.6, and the xpld board and am getting an idea of what is usable without altering jumpers or using extra jumper wires.
                      Are there any overview docs of the reprap firmware other than the code's internal documentation? It's a fair old jump going from a little tinkering in the arduino editor with marlin to using eclipse and reprap firmware! Most of my current stock of questions are noddy ones that will come out in the wash when I can see how all the code files fit together.
                        Sorry, there are no overview docs except the readme file. But for RRF3 on SAME70XPLD, if you are using the latest source code on the -v3-dev branch then you shouldn't need to change anything except the Pins.h file. Use the version of it for Duet3_V05 as a model. Everything else is configured using GCode in the config.g file on the SD card.
                        It helps if the STEP pins to the drivers are all on the same 32-bit MCU port. But you probably won't have that choice as you are using off-the-shelf boards. So you will need to change the 3 functions at the end of Pins.h. For guidance on how to do this, take a look at the same 3 functions at the ends of Platform.h in the dev branch of RRF, in particular how they were implemented for Radds/Due.
                        When I built the SAME70XPLD configuration a few days ago, it compiled with no errors, just a few warnings caused by the pin table being empty.
                        HTH David
