    PC connects fine to Duet-MAC won't see the server.
    Duet Web Control
    • Empiricusundefined
      Empiricus
      Weird Issue. Windows connects fine through Chrome to the Duet2 web interphase. When I put in the IP address of the duet into chrome on the MAC connection just times out. Any one knows what is going on?
        Can you ping the ip address from the Mac?
          Does the browser on your Mac only accept https connections by default? If so then you may need to put http:// explicitly before the IP address. I've seen this behaviour on some mobile devices.
          Empiricusundefined 1 Reply Last reply Reply Quote 0
            Empiricus @dc42
            @dc42 said in PC connects fine to Duet-MAC won't see the server.:
            http://
            Thought of that. No browser works with MacOS to connect to Duet. How do you check IP of duet without connecting through usb?
              Empiricus
              Anyway to ensure defined IP for the Duet? Octoprint doesn't have the problem for some reason
                If the duet is set to DHCP the router will have an IP assigned so you can check there, or if you want to define the up address that can be done in the config.g.
