Not able to upload files
  • Disclosure: This is happening on a Chinese cloned Duet Wifi
    I'm not able to upload files anymore.
    This happened after a long print. Nothing special, maybe more vibrations than usual.
    When I upload gcode or system files to the duet it always shows me "network error". Printing files uploaded by the PC works without problems, also reading config files.
    What I've tried:
    I've checked the sdcards using the procedure from https://www.walduk.at/2016/06/23/verifying-sdcards/ which does an md5sum over the whole space and they are good.
    The one I'm using right now is a 4GB card. Formatted with dos partition, one primary over the while size. Filesystem was created with
    sudo mkfs.vfat -F 16  -s 128 -S 512 /dev/mmcblk0p1
    I've tried various firmware versions for the ARM und ESP8266 and discovered no differences regarding this problem. I went up and down the DWC releases. This is the output of M122:
    RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03beta3 running on Duet WiFi 1.02 or later
    Board ID: 08DGM-9T6BU-FG3S4-6J9FD-3S86R-KBRZF
    Used output buffers: 1 of 20 (15 max)
    Static ram: 25632
    Dynamic ram: 93524 of which 132 recycled
    Exception stack ram used: 272
    Never used ram: 11512
    Tasks: NETWORK(ready,412) HEAT(blocked,916) MAIN(running,3840) IDLE(ready,196)
    Owned mutexes:
    Last reset 00:13:22 ago, cause: software
    Last software reset at 2019-04-16 22:41, reason: User, spinning module GCodes, available RAM 6736 bytes (slot 0)
    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x04433000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
    Error status: 0
    Free file entries: 10
    SD card 0 detected, interface speed: 12.0MBytes/sec
    SD card longest block write time: 6.5ms, max retries 0
    MCU temperature: min 30.1, current 31.4, max 31.4
    Supply voltage: min 1.6, current 1.7, max 1.7, under voltage events: 0, over voltage events: 0, power good: no
    Driver 0: ok, SG min/max not available
    Driver 1: ok, SG min/max not available
    Driver 2: ok, SG min/max not available
    Driver 3: ok, SG min/max not available
    Driver 4: ok, SG min/max not available
    Date/time: 2019-04-19 12:26:09
    Cache data hit count 2987855252
    Slowest loop: 8.17ms; fastest: 0.07ms
    I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
    Hiccups: 0, FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
    Bed compensation in use: none
    === MainDDARing ===
    Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
    === AuxDDARing ===
    Heater 1 is on, I-accum = 0.0
    Segments left: 0, aux move: no
    Movement lock held by null
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is idle in state(s) 0
    serial is ready with "M122" in state(s) 0
    aux is idle in state(s) 0
    daemon is idle in state(s) 0
    queue is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 202.11ms; fastest: 0.08ms
    HTTP sessions: 1 of 8
    - WiFi -
    Network state is running
    Failed messages: pending 0, notready 0, noresp 1
    WiFi firmware version 1.23
    WiFi MAC address b4:e6:2d:60:af:ab
    WiFi Vcc 3.28, reset reason Turned on by main processor
    WiFi flash size 4194304, free heap 23768
    WiFi IP address 192.168.178.35
    WiFi signal strength -55dBm, reconnections 0, sleep mode modem
    ok
    The configuration is default except for
    ; Communication and general
    M111 S1
    M550 PDuetTest					; Machine name and Netbios name (can be anything you like)
    M551 Preprap                   			; Machine password (used for FTP)
    M550 P"Anycubic Kossel"                     ; Set machine name
    M552 S1                                     ; Enable network
    M587 S"asdf" P"asdf"              ; Configure access point. You can delete this line once connected
    M586 P0 S1                                  ; Enable HTTP
    So what's interesting is the whole sd card stuff with M111 S1 P10 enabled:
    M20
    Read 0 1 2688
    Read 0 1 3200
    Begin file list
    something.gcode
    empty.gcode
    End file list
    ok
    M22
    SD card 0 may now be removed
    ok
    M21
    Read 0 1 0
    Read 0 1 2048
    SDHC card mounted in slot 0, capacity 3.97Gb
    ok
    M39
    ok
    Read 0 1 0
    Read 0 1 2048
    ok
    I've checked the hardware. I know that you pay up to 30% of the product's value in China and I ordered the cheapest. So I was hoping that it's just a bad solder joint which is still working with capacitive coupling, but I discovered nothing. Here are pictures of the clone.
    This is the sdcard slot. All pins seem good.
    2_1555670989266_sd-slot.jpg 1_1555670989266_solder-joints-sd-slot.jpg 0_1555670989266_sd-slot-top.jpg
    Right now I'm really disappointed. The board cost me 94 USD and 6 weeks of waiting. The Duet is roughly 50% more or 50 USD. I've invested 16 hours of my work time into debugging this shit and it's still not working. If I had bought the original, I would have at least my piece of mind by sending it in and not worrying about it. Warranty is difficult in China, even with Aliexpress.
  • I've tried various sd card related commands
    M39
    Read 0 1 2176
    Read 0 1 2177
    Read 0 1 2178
    Read 0 1 2179
    Read 0 1 2180
    Read 0 1 2181
    Read 0 1 2182
    Read 0 1 2183
    Read 0 1 2184
    Read 0 1 2185
    Read 0 1 2186
    Read 0 1 2187
    Read 0 1 2188
    Read 0 1 2189
    Read 0 1 2190
    Read 0 1 2191
    Read 0 1 2192
    Read 0 1 2193
    Read 0 1 2194
    Read 0 1 2195
    Read 0 1 2196
    Read 0 1 2197
    Read 0 1 2198
    Read 0 1 2199
    Read 0 1 2200
    Read 0 1 2201
    Read 0 1 2202
    Read 0 1 2203
    Read 0 1 2204
    Read 0 1 2205
    Read 0 1 2206
    Read 0 1 2207
    Read 0 1 2208
    Read 0 1 2209
    Read 0 1 2210
    Read 0 1 2211
    Read 0 1 2212
    Read 0 1 2213
    Read 0 1 2214
    Read 0 1 2215
    Read 0 1 2216
    Read 0 1 2217
    Read 0 1 2218
    Read 0 1 2219
    Read 0 1 2220
    Read 0 1 2221
    Read 0 1 2222
    Read 0 1 2223
    Read 0 1 2224
    Read 0 1 2225
    Read 0 1 2226
    Read 0 1 2227
    Read 0 1 2228
    Read 0 1 2229
    Read 0 1 2230
    Read 0 1 2231
    Read 0 1 2232
    Read 0 1 2233
    Read 0 1 2234
    Read 0 1 2235
    Read 0 1 2236
    Read 0 1 2237
    Read 0 1 2238
    Read 0 1 2239
    Read 0 1 2240
    Read 0 1 2241
    Read 0 1 2242
    Read 0 1 2243
    Read 0 1 2244
    Read 0 1 2245
    Read 0 1 2246
    Read 0 1 2247
    Read 0 1 2248
    Read 0 1 2249
    Read 0 1 2250
    Read 0 1 2251
    Read 0 1 2252
    Read 0 1 2253
    Read 0 1 2254
    Read 0 1 2255
    Read 0 1 2256
    Read 0 1 2257
    Read 0 1 2258
    Read 0 1 2259
    Read 0 1 2260
    Read 0 1 2261
    Read 0 1 2262
    Read 0 1 2263
    Read 0 1 2264
    Read 0 1 2265
    Read 0 1 2266
    Read 0 1 2267
    Read 0 1 2268
    Read 0 1 2269
    Read 0 1 2270
    Read 0 1 2271
    Read 0 1 2272
    Read 0 1 2273
    Read 0 1 2274
    Read 0 1 2275
    Read 0 1 2276
    Read 0 1 2277
    Read 0 1 2278
    Read 0 1 2279
    Read 0 1 2280
    Read 0 1 2281
    Read 0 1 2282
    Read 0 1 2283
    Read 0 1 2284
    Read 0 1 2285
    Read 0 1 2286
    Read 0 1 2287
    Read 0 1 2288
    Read 0 1 2289
    Read 0 1 2290
    Read 0 1 2291
    Read 0 1 2292
    Read 0 1 2293
    Read 0 1 2294
    Read 0 1 2295
    Read 0 1 2296
    Read 0 1 2297
    Read 0 1 2298
    Read 0 1 2299
    Read 0 1 2300
    Read 0 1 2301
    Read 0 1 2302
    Read 0 1 2303
    Read 0 1 2304
    Read 0 1 2305
    Read 0 1 2306
    Read 0 1 2307
    Read 0 1 2308
    Read 0 1 2309
    Read 0 1 2310
    Read 0 1 2311
    Read 0 1 2312
    Read 0 1 2313
    Read 0 1 2314
    Read 0 1 2315
    Read 0 1 2316
    Read 0 1 2317
    Read 0 1 2318
    Read 0 1 2319
    Read 0 1 2320
    Read 0 1 2321
    Read 0 1 2322
    Read 0 1 2323
    Read 0 1 2324
    Read 0 1 2325
    Read 0 1 2326
    Read 0 1 2327
    Read 0 1 2328
    Read 0 1 2329
    Read 0 1 2330
    Read 0 1 2331
    Read 0 1 2332
    Read 0 1 2333
    Read 0 1 2334
    Read 0 1 2335
    Read 0 1 2336
    Read 0 1 2337
    Read 0 1 2338
    Read 0 1 2339
    Read 0 1 2340
    Read 0 1 2341
    Read 0 1 2342
    Read 0 1 2343
    Read 0 1 2344
    Read 0 1 2345
    Read 0 1 2346
    Read 0 1 2347
    Read 0 1 2348
    Read 0 1 2349
    Read 0 1 2350
    Read 0 1 2351
    Read 0 1 2352
    Read 0 1 2353
    Read 0 1 2354
    Read 0 1 2355
    Read 0 1 2356
    Read 0 1 2357
    Read 0 1 2358
    Read 0 1 2359
    Read 0 1 2360
    Read 0 1 2361
    Read 0 1 2362
    Read 0 1 2363
    Read 0 1 2364
    Read 0 1 2365
    Read 0 1 2366
    Read 0 1 2367
    Read 0 1 2368
    Read 0 1 2369
    Read 0 1 2370
    Read 0 1 2371
    Read 0 1 2372
    Read 0 1 2373
    Read 0 1 2374
    Read 0 1 2375
    Read 0 1 2376
    Read 0 1 2377
    Read 0 1 2378
    Read 0 1 2379
    Read 0 1 2380
    Read 0 1 2381
    Read 0 1 2382
    Read 0 1 2383
    Read 0 1 2384
    Read 0 1 2385
    Read 0 1 2386
    Read 0 1 2387
    Read 0 1 2388
    Read 0 1 2389
    Read 0 1 2390
    Read 0 1 2391
    Read 0 1 2392
    Read 0 1 2393
    Read 0 1 2394
    Read 0 1 2395
    Read 0 1 2396
    Read 0 1 2397
    Read 0 1 2398
    Read 0 1 2399
    Read 0 1 2400
    Read 0 1 2401
    Read 0 1 2402
    Read 0 1 2403
    Read 0 1 2404
    Read 0 1 2405
    Read 0 1 2406
    Read 0 1 2407
    Read 0 1 2408
    Read 0 1 2409
    Read 0 1 2410
    Read 0 1 2411
    Read 0 1 2412
    SD card in slot 0: capacity 3.97Gb, free space 3.96Gb, speed 12.00MBytes/sec, cluster size 64kb
    ok
    So I've tried uploading stuff. This is the output of an empty gcode file:
    Read 0 1 2688
    Read 0 1 3200
    Read 0 1 2688
    Read 0 1 3200
    Write 0 1 3200
    Read 0 1 2688
    Read 0 1 3200
    Write 0 1 3200
    Read 0 1 2688
    Read 0 1 3200
    Write 0 1 3200
    Read 0 1 2688
    Read 0 1 3200
    No problems here. The same with a 2.8kb big file containing valid gcode:
    Read 0 1 2688
    Read 0 1 3200
    Write 0 1 3200
    Read 0 1 2176
    Preallocating 2834 bytes returned 0
    Write 0 5 3328
    Write 0 1 2176
    Write 0 1 2432
    Read 0 1 3333
    Write 0 1 3333
    Read 0 1 3200
    Write 0 1 3200
    Read 0 1 2688
    Read 0 1 3200
    Write 0 1 3200
    Read 0 1 2688
    Read 0 1 3200
    Read 0 1 2688
    Read 0 1 3200
    Read 0 1 2688
    Read 0 1 3200
    Read 0 1 2688
    Read 0 1 3200
    Read 0 4 3328
    Read 0 1 3332
    Read 0 1 3333
    Read 0 4 3328
    But if I continue the same file to 5,1kb it doesn't work anymore with this output:
    Read 0 1 2688
    Read 0 1 3200
    Write 0 1 3200
    Read 0 1 2176
    Preallocating 5185 bytes returned 0
    Write 0 5 3328
    Write 0 1 2176
    Write 0 1 2432
    Read 0 1 3333
    Write 0 1 3333
    Read 0 1 3200
    Write 0 1 3200
    Read 0 1 2688
    Read 0 1 3200
    Read 0 1 2688
    Read 0 1 3200
    Write 0 1 3200
    Read 0 1 2176
    Write 0 1 2176
    Write 0 1 2432
    I've attached the 5,1kb file.0_1555670429300_much.gcode
    You can use M122 P104 to test writing to the SD card without involving the network. You can optionally specify the file size in Mbytes using the S parameter, default 10Mb.
  • @dc42 Thanks a lot for your help! Do you have patreon / paypal?
    M122 P104 S3500
    ok
    Testing SD card write speed...
    SD write speed for 3500.0Mbyte file was 1.44Mbytes/sec
    So it seems I'm on the wrong track
    I uploaded the much.gcode file with networking debugging enabled:
    New conn on socket 0 for local port 80
    Found responder
    Received 549 bytes
    Received 1460 bytes
    New conn on socket 1 for local port 80
    Found responder
    Received 359 bytes
    Found responder
    Received 359 bytes
    Found responder
    Received 359 bytes
    Found responder
    Received 359 bytes
    Found responder
    Received 359 bytes
    Received 1460 bytes
    Found responder
    Received 359 bytes
    Found responder
    Received 359 bytes
    Found responder
    Received 359 bytes
    Found responder
    Received 359 bytes
    Found responder
    Received 359 bytes
    Found responder
    Received 359 bytes
    Found responder
    Received 359 bytes
    Found responder
    Received 359 bytes
    Found responder
    Received 359 bytes
    Found responder
    Received 359 bytes
    Received 1460 bytes
    Found responder
    Received 359 bytes
    Found responder
    Received 359 bytes
    Found responder
    Received 359 bytes
    Found responder
    Received 359 bytes
    Found responder
    Received 359 bytes
    Found responder
    Received 359 bytes
    Found responder
    Received 359 bytes
    Found responder
    Received 359 bytes
    Found responder
    Received 359 bytes
    Found responder
    Received 359 bytes
    Found responder
    Received 359 bytes
    Found responder
    Received 359 bytes
    Found responder
    Received 359 bytes
    Found responder
    Received 359 bytes
    Found responder
    Received 359 bytes
    Found responder
    Received 359 bytes
    Found responder
    Received 359 bytes
    Found responder
    Received 359 bytes
    Found responder
    Received 359 bytes
    Found responder
    Received 359 bytes
    Found responder
    Received 359 bytes
    Found responder
    Received 359 bytes
    Received 911 bytes
    Found responder
    Received 359 bytes
    Found responder
    Received 359 bytes
    Found responder
    Received 359 bytes
    And with Webserver Debugging enabled:
    HTTP req, command words { POST /rr_upload HTTP/1.1 }, parameters { name=0:/gcodes/much.gcode time=2019-4-19T12:57:53 }
    Start uploading file 0:/gcodes/much.gcode length 15521
    HTTP connection accepted
    HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=1 }
    Sending JSON reply, length 636
    HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=2 }
    Sending JSON reply, length 1370
    Wifi Debugging gives me zero output
  • This is what chrome and firefox say with F12:
    1_1555696607566_Screenshot_20190419_181144.png 0_1555696607566_Screenshot_20190419_181316.png
    I've attached the pretty long lines as text files:
    1_1555696698947_line19.txt 0_1555696698947_line34.txt
  • Success! Thanks a lot dc42, I wouldn't have dared to suspect the Wifi network without your help. I've change the access point I'm connecting to and right now it's uploading at 500kb/s.
    I really appreciate the software you've created here. If you give me some paypal link I'll send you some money. And, for what it's worth, my 3rd printer will get a original duet.
    Now I will investigate why my fritz box's network doesn't work with the cloned duet.
    EDIT: WPA2 (CCMP) does't work. WPA (TKIP) works.
  • So what was the resolution to this issue? I have the same problem, my machine keeps getting assigned different Web addreses and the last two have given me trouble with uploads.
  • @avion23 How do you change the access point? I have my access point as the router. FIOS-TWHNX
  • @novaprint I came home today and was able to upload the print that I could not upload earlier today. This does not solve the problem, it doe describes it.
  • @NOVAprint I've changed the encryption cipher for the Wifi in my router. WPA2 (CCMP) does't work. WPA (TKIP) works.
    In my fritz box there is also a button to always assign the same ip to some device. Maybe your's too? Try changing down from WPA2 to WPA and post a screenshot if it still doesn't work.
