Exclude Region
  • As a recent convert from marlin, there are a few plugins/features that I have used previously that I think would be a great addition to the duet ecosystem.
    • Exclude Region
      print multiple objects say 3 for this example, if one lifts from the bed during print you simply select that object and exclude, the print continues but skips the g code for the excluded object allowing the other 2 objects to still be printed.
    • Automatic Shutdown:
      Enable automatic system shutdown after finishing a print job, duet turns off but power remains on.
    • Printer Statistics
      Statistics of your 3D Printer, Number of success / fails / cancels / errors
    Thanks for your suggestions. Automatic shutdown is already possible. The other two are already on the firmware wish list.
  • Thanks for the update, is there an updated wish list somewhere?
    I did look here before posting here: https://forum.duet3d.com/topic/938/firmware-wishlist-and-priorities-for-duet-wifi-and-duet-ethernet/101 but the thread seams to end in December 2018.
    I did notice that number 3. Logging of various events, including print start/pause/resume/cancel/end, and error messages. Done in 1.20 which I believe is this https://duet3d.dozuki.com/Wiki/Logging text based solution could you confirm? Ill have to take a look at this but it would be nice to have a GUI for this in DWC.
