    Duet Wifi for CNC. Work coordinates and mesh bed leveling issue
    CNC
    • marius-hundefined
      marius-h
      Hello
      Im using my Workbee CNC to isolation mill some PCB. And i want to be able to use the mesh bed leveling to be able to cut 0.05 depth into the copper.
      Im using v style engraving bits and they have different cut width dependent on the depth of the cut.
      Im able to get mesh bed leveling to work like this:
      Navigate over to my PCB. I set the right work coordinates for x,y,z.
      Then i add the probe: M558 P4 C2 I1 H0.5 F60
      The probe map that i need to make need to be set in machine cordinates. like this: M557 X130:170 Y126:166 S3
      Then i run a G30 to reset the Z height for the machine cordinates.
      Then i run the; G29 to run the map.
      After all this is done i run the job from work cordinates. But i think the mesh bed leveling is offsetting the unused machine cordinates, and not the work coordinates.
      Anyone have any tips on how to get this to work?
      dc42undefined Mito Kafanderundefined 2 Replies Last reply Reply Quote 0
        dc42 administrators @marius-h
        @marius-h said in Duet Wifi for CNC. Work coordinates and mesh bed leveling issue:
        Hello
        Please try firmware 2.03RC3 and se whether this is still a problem.
        • Mito Kafanderundefined
          Mito Kafander @marius-h
          @marius-h did you get it working?
