    Issues with resurrecting
    Firmware installation
    • jaurandundefined
      jaurand
      Hello All. having some issues with getting prints to resume after a failure. The errors I am getting are:
      12:09:19 PMError: M24: Cannot print, because no file is selected!
      12:09:14 PMM916
      Error: M23: GCode file "CFFFP_Liner Rail Y1 .gcode" not found
      12:07:08 PMError: M24: Cannot print, because no file is selected!
      12:07:02 PMM106 P0 S0.06
      What could I be missing here?
      resurrect.g
      ; File "CFFFP_Liner Rail Y1 (1).gcode" resume print after print paused at 2019-05-01 12:04
      M140 P0 S85.0
      G10 P0 S265 R265
      T0 P0
      G92 X185.298 Y171.427 Z0.400
      M98 Presurrect-prologue.g
      M106 P0 S0.00
      M106 P2 S0.00
      M106 P3 S0.00
      M106 P4 S0.00
      M106 P5 S0.00
      M106 P6 S0.00
      M106 P7 S0.00
      M106 P8 S0.00
      M106 S0.00
      M116
      M290 S0.000
      G92 E0.00000
      M83
      M23 CFFFP_Liner Rail Y1 (1).gcode
      M26 S86148 P0.000
      G0 F6000 Z2.400
      G0 F6000 X185.298 Y171.427
      G0 F6000 Z0.400
      G1 F1800.0 P0
      M24
      M116 ; wait for temperatures
      G28 X Y ; home X and Y, hope that Z hasn't moved
      G1 X180 Y40 F6000 ; go to first bed probe point and home Z
      M83 ; relative extrusion
      G1 E4 F3600 ; undo the retraction that was done in the M911 power fail script
      Thank you!
      • jaurandundefined
        jaurand
        I forgot to add the failure I had been having is a heater failure. From what I can tell from extra searching, you cannot resume a cancelled print, and in this case the heat failure is causing the print to be cancelled.
          The problem is that the name of your GCode file contains space characters, and the current stable firmware omits the quote characters around the filename in the M23 command. This is fixed in the most recent beta. Meanwhile, if you edit the resurrect.g file inserting double quote marks around the filename, you will be able to resume it.
