    temperature sensor pin number change
    Firmware developers
    • go
      go last edited by go
      I tried to change pin slot for DuetWifi According to our PIN numbers on board.
      It does work if I flash it using Sam-Ba.
      It doesn't using GCode if I use M997 S0 after putting newly compiled Duet2CombinedFirmware.bin and iap4e.bin on the SD card.
      By saying it doesn't work it should be displaying 2000C for dismounted thermistor. It displays 112C.
      I compiled and replaced iap4e.bin after changing CoreNG/variants/variants.cpp
      replaced iap4e.bin. Didn't affect the mapping again.
      How does iap4e.bin affect mapping? Which file should I change on In application project?
      Thanks,
      go 1 Reply Last reply Reply Quote 0
      • go
        go @go last edited by go
        @go
        can't post text akismet spam filter blocks it.
        so more detailed file names and variables are below...
        RepRapFirmware/src/DuetNG/Pins_DuetNG.h
        constexpr Pin TEMP_SENSE_PINS[NumThermistorInputs] = { 45, 44, 47, 61, 62, 63, 59, 18 }; // Thermistor pin numbers
        to
        constexpr Pin TEMP_SENSE_PINS[NumThermistorInputs] = { 45, 47, 44, 61, 62, 63, 59, 18 }; // Thermistor pin numbers
        Compiled it...
        after compilation works if flash using Sam-Ba and it doesn't if I flash using gcode.
          There is no difference between flashing with Bossa or using M997. So I suspect that the binary that M997 is installing is not the one you thought it was.
          • go
            @dc42 said in temperature sensor pin number change:
            There were two firmwares on the SD card. One for before 1.20 one for 2.0+. Having these both on the SD card causes problems. Now it has resolved.
            Thanks,
