    Setting Motor Currents- M906
    Firmware installation
    • sinned6915
      sinned6915 last edited by sinned6915
      I am tying to learn about setting motor currents, M906. Not sure if this post goes here in FW Installation or Tweaking forum.
      1. If you are using stepstick / stepper drivers with digipots to set Vref, would you use M906 at all ? I used the online configurator and didnt think about it, the M906 is in my config.sys file even though I am using DVR8825's all around, because I choose the wrong board to config with.
      2. If you have a mixed system with digipot boards and a stepper driver boards that are capable to have the current set by firmware, do the values in M906 for digipot drivers matter? Using 0's here does not feel comfortable.
      Example- X & Y have SD6128s, Current Limit is VREF*2, Motors are 2A, current would be 1.0a or 1000ma.
      Z, E0 and E1 are DRV8825's, all at Current Limit is VREF*2, Motors are 1.5A.
      M906 X1000 Y1000 Z0 E0:0 I0
      Thanks in advance
      Dennis
      Stephen6309 1 Reply Last reply Reply Quote 0
      • Stephen6309
        Stephen6309 @sinned6915 last edited by
        @sinned6915 M906 controls the stepper current on the drivers on the Duet and the DueX boards. For the 8825s, it won't set the current.
        • sinned6915
          Stephen-
          I am trying to determine if I can MIX digipot drivers and FW current set drivers on the same system. I am working towards 3 independent Z leveling screws.
          Can you have mixed stepper drivers in the system?
          On my stepstick breakout board I will have all DRV8825's for the three Z motors.
          The X, Y, E0 & E1 will be the current setting kind.
          M569 P0 S1 ; Drive 0 goes forwards X
          M569 P1 S1 ; Drive 1 goes forwards Y
          M569 P2 S1 T1.9:1.0:0.65:0.65 ; Drive 2 goes forwards Z1
          M569 P3 S1 ; Drive 3 goes forwards E0
          M569 P4 S1 ; Drive 4 goes forwards E1
          M569 P5 S1 T1.9:1.0:0.65:0.65 ; Drive 5 goes forwards Z2
          M569 P6 S1 T1.9:1.0:0.65:0.65 ; Drive 6 goes forwards Z3
          M584 X0 Y1 Z2:5:6 ; three Z motors connected to driver outputs 2, 5 and 6
          M671 X-15: 100:215 Y190:-10:190 S0.5 ; leadscrews at rear left, front middle and rear right ; There is and extra space in there on purpose at X-15 b/c unicode chars displaying
          M906 X1000 Y1000 Z0:0:0 E800:800
          • Veti
            Veti last edited by
            are you using the LPC port? if so the LPC port does not support the M906 command at all.
              dc42 administrators @sinned6915 last edited by
              @sinned6915 said in Setting Motor Currents- M906:
              Yes you can. The M906 and M350 settings for the external drivers will be ignored.
              • sinned6915
                Thank you gents
