    Dynamic axis minima and maxima
    CNC
    • kalera
      kalera last edited by
      I'm using the Duet wifi for my cnc router and its working great.
      When I start a milling operation, I set the machine's zero point to a suitable location on my stock. Currently I'm just using G92 X0 Y0 Z0 to set my zero point. What I would like to do also is set the axis minima and maxima according to the current position.
      I'll give an example of the steps I want to take:
      • Let's say I have a machine that can move X500 and Y500
      • I home the machine
      • I manually move the machine to the spot where I want to start machiening (lets say x100 Y100)
      • Then I want to call the macro which sets the minima to X-100 Y-100 and X400 Y400 for the maxima
      • After that I want to use G92 to set everything to 0
      Is it possible to do this?
      • DocTrucker
        DocTrucker last edited by DocTrucker
        It maybe easier to leave the machine coordinaye system constant but use tool offset to set a specific point within the macine to (0,0,0)?
        G10 P0 Xa Yb Zc
        ...will offset tool 0 relative to the machine coordinates.
        Alive: 1 Ormerodish machines. 1 Custom Cantilever. 3 P3Steel. 1 Ciclopish scanner. In build: 1 P3Steel. Controllers: 2 Duet 2 , 2 D0.6, 1 D0.8.5, 1 D3 v0.5, 1 RAMPS/DRV8825, 1 Uno/Scan Card.
        • A Former User
          A Former User last edited by
          Isn't this what the work coordinate system is for?
          https://duet3d.dozuki.com/Wiki/Gcode#Section_G54_to_G59_3_Select_coordinate_system
          DocTrucker 1 Reply Last reply Reply Quote 0
          • kalera
            Thanks guys, I can't believe I didn't see this in the GCode page, I went over it a few times already. I'm going to give this a try tomorrow
            A Former User 1 Reply Last reply Reply Quote 0
            • DocTrucker
              DocTrucker @Guest last edited by
              @bearer good shout. I'm coming from the v0.6/0.8.5 side of the fence so need to bodge a few things like that! 😄
              • A Former User
                A Former User @kalera last edited by
                No worries; been there done that, have a closet full of the t-shirts..
                I got lucky;)
                • kalera
                  @bearer I got a chance of testing it today and the work coordinate system works perfectly, this is exactly what I was looking for. Thanks!
