    Workbee CNC 1500 x 1500 Belt - Duet Z Axis Issue
    CNC
    • grezmel
      grezmel last edited by
      I am in the process of commissioning a Workbee CNC 1500 x 1500 Belt, standard set up from Ooznest. The X & Y axis travel seems spot on, however, when I run the attached G Code, The Z Axis mount travels too far and the bottom of the mount hits the deck.
      The Gcode was created in Fusion 360 and the simulation ran as expected. When I measure the travel on the Z Axis by sending 25, 50mm code to the machine, the measurements are fine.
      Can anyone assist, 0_1557575473497_Waste Board.txt please?
      Thanks
      • Catalin_RO
        Catalin_RO last edited by
        Where is you Z0 relative to the workpiece?
        grezmel 1 Reply Last reply Reply Quote 0
        • grezmel
          grezmel @Catalin_RO last edited by grezmel
          @catalin_ro said in Workbee CNC 1500 x 1500 Belt - Duet Z Axis Issue:
          Z0 is set to bottom left - I have run a test with the Z at full height and zero'd at full height as it should only move down a max of 6mm for the board I'm trying to machine, however, the Z axis moves all of the way to the bottom hitting the board. All other Axis appears to be working fine.
          Catalin_RO 1 Reply Last reply Reply Quote 0
          • Catalin_RO
            Catalin_RO @grezmel last edited by
            @grezmel you have Z-5.6 and Z-7 in your G0/G1 commands. You might have to re-check how have you defined your workspace in Fusion 360 when generating the GCode.
            • A Former User
              A Former User last edited by
              fusion post proc probably does either g28 or g54 g92 z0 at the start which can cause issues if your machine isn't set up right.
