    crashed duetwifi while installing Webcontrol
    Firmware installation
    • KevinOundefined
      KevinO
      Hey,
      i just crashed my Webcontrol while installing it.. now the duet connetcs per Wifi and i can see it but when iam connecting it it shows me a blank sheet. So i think the Webcontrol is crashed. is ther any option to install the Webcontrol via FTP ? and how can i make it ?
        Assuming that you are running main firmware 1.19 or later, I suggest you move the SD card to a PC and check whether the Duet Web Control files in the /www folder of the SD card are intact.
        • A Former User?
          A Former User
          if you can connect to http and get a 404 error you're missing Duet Web Control (DWC) files that should have been in the /www folder on your sd card.
          But you can activate ftp and upload either the classic DWC or the 2.0 version to /www on your sd card.
          This should give you a reference for what the SD card should have looked like: https://github.com/T3P3/Duet/tree/master/Duet2/SD Card Contents
