ANOTHER "No known networks found" error
Let me try it on my new laptop
Same story on the new laptop I'm afraid.
What does VIN power mean? Power taken from the Ender3 printer? -
If that's the case, I had better try it in the morning. It's getting late here.
Ah... Voltage in or Vin. And it takes presedence over USB power. Amazing what a little Google research will turn up...
Hi again,
OK, Duet now powered by Ender3. See photo.
However, dire warnings from the board (via YAP)
This is weird, because as far as I can see, the heater isn't powered at all. Switched it off. But I'll go look at the URL it mentions
It would appear that you do not have a valid config.g loaded. It probably has the default that came with the board.
You will need to create one for your printer using the online configurator tool.
I'll point to the Ender 3 Duet Maestro guide I posted a link to earlier again as it goes through the process of using the configurator. Most of the details will still apply for the Duet Wifi anyway.
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+2:+Configuration/38
@duncan-rtfm said in ANOTHER "No known networks found" error:
The warning about the heater is based on the default heater settings in your config file and based on the heater model the firmware uses it estimates that if there were a heater fault that left the heater stuck in the powered state it could reach that heat. Now in your case you don't have the correct heater values entered and you haven't run a PID tune, so it doesn't have an accurate estimate.
What does the result of M122 look like now?
I've checked M122 with the Vin power off, and on - compared them, and they seem identical. I can post the Vin power on version if you like, but that's an awful lot of text. Any particular section you actually need to look at?
I have also gone into the config.g file, and hard coded the network settings as per a post I found on the forum, like this:
;*** NetworkingM552 S1 ; Turn network on
M555 P2
M550 Duncan's Ender3 ; Set machine name
M551 DuetPassword ; Set password (for Duet Web interface, not for WiFi network)
M587 S"MySSID" P"MyPassword" ;Set SSID and network key password for WiFi network.
M552 S1 ; Enable networkBut of course, the issue is with establishing a wifi connection to begin with, so this rather convenient piece of code is useless.
Mainly want to know what the last part about the wifi says.
With Vin power:
=== Network ===
Slowest loop: 0.27ms; fastest: 0.00ms
HTTP sessions: 0 of 8- WiFi -
Network state is changing mode
WiFi module is idle
Failed messages: pending 0, notready 0, noresp 1
Failed to get WiFi status
ok
Error retrieving WiFi status message: bad reply format version
WiFi module is idle
- WiFi -
I have also set the default gateway (in the config.g) to that of my router, and set an arbitrary fixed IP address, like so:
M552 P192.168.0.200 ; IP address
M554 P192.168.0.1 ; Gateway
But when I ping the address, I get the following:
I'm wondering if my WiFi module might be faulty?
If you send these commands via yat what does it return?
M552 ; report wifi status
M552 S0 ; disable wifi module
M552 S1 ; enable wifi module
M588 S"*" ; clear all WiFi networks
M587 S"MySSID" P"MyPassword" ; add wifi network
M552 S1 ; enable wifi module -
Here you go...
WiFi module is idle
M552 S
WiFi module is changing mode
ok
ok
M588 S"*" ; clear a
ok
ok
ll WiFi networks
M587 S"OPTUS_975D61" P"limaskoses42657" ; add wifi network
M588: Failed to reset the WiFi module to factory settings
ok
M587: Failed to add SSID to remembered list
ok
ok
WiFi module is idle -
I sent these as a text file. Would it be better to send each individually?
Send each command in YAT one at a time, if that's what you're asking.
I have just spent some time working my way through the online configurator, and this is the result - at least it is a bit different... But still no coconut...
RepRapFirmware for Duet 2 WiFi/Ethernet Version 2.02(RTOS) dated 2018-12-24b1
Executing config.g...Error: M587: Failed to add SSID to remembered list
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled
Warning: M918 command is not supported
Warning: Macro file config-override.g not found. -
M587 won't work from config.g, it needs to be sent from the terminal.
If it still won't work when sent through YAT, I'm all out of ideas. It may be a faulty wifi module. DC42 would have to confirm.
