    Problem G02/G03 commands DuetWiFiFirmware-1.17e
    Firmware installation
    • RubenG
      RubenG last edited by
      I was trying to use my printing system as a laser engraver using the Inkscape Laser Tool Plug-In.
      This program outputs a gcode with G01 and G02/G03 commands.
      Currently, I am using a Duet Wifi so I installed the DuetWiFiFirmware-1.17e which includes the G02/G03 commands recognition.
      However, the machine was not responding as I was expecting. Then I erased the Duet Wifi and installed everything again, without success.
      So I tried the following code the find the problem. For now, I just used a pencil to plot the movement.
      G90
      G21
      G01 X10 Y25
      G02 X10 Y25 I20 J0 F125
      In my case the X -axis is mirrored which should not matter in my opinion.
      And when trying:
      G01 X10 Y25
      G03 X10 Y25 I20 J0 F125
      It gave the response shown in the blue dotted line.
      As I understand the G02/G03 commands, the machine should start its circular motion directly at X10 Y25 instead of moving to the Y25+ radius first.
      Is there a way this problem can be solved?
        Please can you check that image link because it doesn't work for me.
        • RubenG
          Is it visible now?
            Yes, it's visible now. I'll try that out tomorrow.
            • RubenG
              Is there any progress on the G2/G3 commands?
