    End stops config with DC IR probe
    Firmware installation
    • Prawnabie
      Prawnabie last edited by
      Hi all,
      In the command M574 X# Y# Z# S#, do I need to omit the Z if I am using the ir probe for z homing and bed levelling or does the m558 command override whatever I put?
      Also is is best to configure the sensor with the bed and nozzle heated or not?
      Thanks
      Shaun
        The M574 command overrides M558 now. So use Z0 in M574 to use a Z probe for Z homing.
        Assuming your want to do bed probing with the nozzle and bed at printing temperatures, then it's best to calibrate the Z probe trigger height at operating temperature too.
