duet 3D laser monitor calibration
  • Hardware info:
    Duet Board:
    Duet WiFi 1.02 or later
    Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.04RC1 (2019-07-14b1)
    Duet WiFi Server Version: 1.23
    Laser sensor:
    Duet 3D laser filmaent sensor ver. 2,0
    Config code:
    M591 D0 P5 C3 R10:300 E3.0 S1
    G-code read out:
    M591 D0: Duet3D laser filament monitor v1 on input 3, enabled, allow 10% to 300%, check every 3.0mm, no data received
    Set up:
    Monitor is mounted after E0 motor (it will dectect clocked nozze + when their is no movement on filament)
    Issue:
    Issue 1: how do i change the dection on wich tyoe of filmaent monitor i am using. it is a v2 but the firmware feedback says it is a v1?
    Issue 2: the print is stopped every 2% of a print because it detect af filment run out or to little movement. o do not understand how the settings work it make no sense to me at all
    Issue 3: related to issue 2 - i dont undertand how i calibrate it
    Hoe there is one or two out there that can help be a bit 🙂
    Sincerly thanks in advance 😉
