sd card o detect
  • Just strat to connect promega but did not work on web , also sd card o detect any one can explain me how to load file to run maestro
    M122
    SENDING:M122
    RepRapFirmware for Duet 2 Maestro version 2.01beta1(RTOS) running on Duet Maestro 1.0
    Board ID: 07DGM-95F62-FU3TD-6IKDD-3SW6S-18GVK
    Used output buffers: 1 of 20 (2 max)
    Static ram: 22412
    Dynamic ram: 91836 of which 0 recycled
    Exception stack ram used: 200
    Never used ram: 16616
    Tasks: NETWORK(ready,2044) HEAT(blocked,1324) MAIN(running,4264)
    Mutexes: FilamentSensors(null) DHT(null) W5500(null) TelnetGCodeReply(null) HttpGCodeReply(null) Telnet(null) HTTP(null) SD1(null) SD0(null) DirSearch(null) FileSystem(null) Aux(null) USB(null) MessageBox(null) ToolList(null) SPI(null) Malloc(null) NetworkGCodeInput(null) NetworkGCodeInput(null) FileInfoParser(null)
    Last reset 00:03:06 ago, cause: power up
    Last software reset time unknown, reason: Hard fault, spinning module Platform, available RAM 38560 bytes (slot 0)
    Software reset code 0x4030 HFSR 0x40000000, CFSR 0x00008200, ICSR 0x0400f803, BFAR 0xf88e6871, SP 0x200042cc
    Stack: 0043c831 0043c6f4 41000000 20007698 00000000 00000000 200043a0 00000000 0043c831 00000000 00000000 00000000 004422c5 00000001 20007be4 00000000 00000000 200078e0 00442a93 20007be4 ffffffff 20007be4 00442657 200078e0
    Error status: 0
    [ERROR] Error status: 0
    Free file entries: 10
    SD card 0 detected, interface speed: 15.0MBytes/sec
    MCU temperature: min 21.6, current 25.4, max 25.5
    Supply voltage: min 0.0, current 0.1, max 0.1, under voltage events: 0, over voltage events: 0
    Driver 0: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 0
    Driver 1: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 0
    Driver 2: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 0
    Driver 3: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 0
    Driver 4: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 0
    Slowest loop: 4581228.50ms; fastest: 0.07ms
    Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
    Scheduled moves: 0, completed moves: 0
    Bed compensation in use: none
    Bed heaters = 0, chamberHeaters = -1 -1
    Segments left: 0
    Stack records: 0 allocated, 0 in use
    Movement lock held by null
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is idle in state(s) 0
    serial is ready with "M122" in state(s) 0
    aux is idle in state(s) 0
    daemon is idle in state(s) 0
    queue is idle in state(s) 0
    lcd is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 4581228.50ms; fastest: 0.01ms
    HTTP sessions: 0 of 8
    Interface state: 0
    ok B:2000.0 /0.0
    ok B:2000.0 /0.0
